Components of the Best Keyless Door Locks
The best keyless door locks are wonders of home automation. For most of human history, locks have always been mechanical. But, automatic door locks transformed our idea of how a lock should be.
The problem with mechanical locks is that they could be picked. People with ill-intentions found a way to hack the mechanism of the lock. Using lock-picking tools, people could imitate the twists and turns of a real key to unlock a lock.
The invention of the best keyless door locks brought a solution to lock-picking. If lock-picks imitate a real key to unlock a lock, why not just phase the key out?
Keyless door locks are remarkable, not just because they broke the key-lock tandem. They are remarkable because they embody a lot of innovation. These innovations makes up the traits of the best keyless door locks.
Best Keyless Door Locks Cut down the Need for Physical Key
As the name suggests, the best keyless door locks are keyless. This is one of the wonders of the best smart door lock.
It is already embedded in the human mind that locks cannot stand alone without keys. But, the best keyless door locks completely changed our view of what should a lock be. This is because the best keyless door locks are functional without a key.
Some models of smart locks retained the physical key. They only added automation features to make it smart.
Most best keyless door locks, though, completely took off the physical key. A remote or an app is used in place of the physical key. Some models even allow voice command.
Best Keyless Door Locks Are Wireless
Another wonder of the best keyless door locks is its wireless control. You do not have to physically interact with the lock just to lock and unlock it. All you had to do is use a remote control to unlock it.
Well, some of the best keyless door locks comes with an app. This allows you to control your lock even if you are at the office or travelling abroad. You no longer have to worry about forgetting to lock your doors.
Some models of the smart lock even allow integration to virtual assistants. These virtual assistants include Amazon Alexa and Google Assistant.
Different wireless protocols are use among models of smart door lock. Some models use Bluetooth, while some use Wi-Fi. Some models use Z-Wave, while some use Zigbee.
Best Keyless Door Locks Uses Encryptions
Another important component of the best keyless door locks is the encryption. Though encryption, keyless door lock can secure the signal coming in and out of it. This is so that your signals will not be hacked by anyone outside of your home automation system.
Different systems of encryption are used by different models of smart door locks. Look for the best keyless door locks that use the strongest system of encryption. This is so that you can assure yourself that your smart lock is secure.
Best Keyless Door Locks Are Energy-efficient
The best keyless door locks consume minimum power. Some models of the best keyless door locks do not even eat up space in electricity bills at all. This is because those models instead use batteries that could take up to a year or two before running out of power.
Best Keyless Door Locks Could Be Integrated
When buying a smart door lock, keep in mind that you will be integrating it into your home automation system. So, look for the best keyless door locks that could be easily integrated into a smart home system.
The best keyless door locks could be easily connected to other smart devices. One such device that could be connected to a smart door lock is a motion sensor. With this set up, the smart lock will automatically unlock when the motion sensor senses you.
You could integrate various devices with your smart door lock. It is up to you how you personalize your smart home.
See these features found in the best keyless door locks. Look for the best keyless door locks to ensure that you will get the best home automation experience.
Do you want to experience the benefits of the best keyless door locks? Experts here, at Vera Control, can help you with anything about home automation. Get in touch with us at +1 (866) 966-2272. You can also send us your thoughts at info@getvera.com.
See Also |
