{"product_id":"1ch-zigbee-tuya-smart-relay-module-home-automation-7-32v-rf433mhz-remote-control-motor-light-garage-switch-work-with-alexa","title":"1CH Zigbee Tuya Smart Relay Module Home Automation 7-32V Rf433Mhz Remote Control Motor Light Garage Switch Work with Alexa","description":"\u003cdiv\u003e\n\u003cdiv\u003e\n\u003cp\u003e\u003cspan\u003e\u003cstrong\u003ePurchase Tips\u003c\/strong\u003e\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003eFor the device to connect to the mobile app, it must be paired with a supported Zigbee gateway, which needs to be purchased separately and can be linked with other compatible smart devices to realize automation scenarios.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eFunction\u003c\/p\u003e\n\u003cp\u003e【APP Remote Control】\u003cbr\u003eRequire Tuya Zigbee Hub. You can check the working state of the device in Tuya APP anywhere and anytime.\u003cbr\u003e【RF433mhz Control】\u003cbr\u003eThe device can be controlled by the RF433mhz Remote Controller.\u003cbr\u003e【Mobile Phone Control】\u003cbr\u003eRequire Tuya ZigBee Hub ,when you go outside or at home, your smart phone could control the device by 2.4Ghz WIFI or 2G\/3G\/4G Mobile Network.\u003cbr\u003e【Voice Control】\u003cbr\u003eRequire Tuya Zigbee Hub, you could voice control the device by Alexa\/Google Assistant.\u003cbr\u003e【Smart Linkage】 \u003cbr\u003e Cooperate with other zigbee products to achieve intelligent linkage. For example, with zigbee door magnetic sensing, to realize the light on immediately after opening the door\u003cbr\u003e【Group Control】\u003cbr\u003e Unified management of individual devices using gateways\u003cbr\u003e【Timing function】\u003cbr\u003e Lying in bed without turning off the lights fell asleep, it does not matter, the wall switch timing function to the point of turning off the lights, from the lights off do not worry about.\u003cbr\u003e【Two Working Modes】\u003cbr\u003e Self-locking, Inching\u003c\/p\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eWhat can I use it for?\u003c\/p\u003e\n\u003cp\u003e*Connect a light, remotely control the switch of the light.Connect a light, remotely control the switch of the light, and can also switch on and off regularly\u003cbr\u003e19:00 On 21:00 Off\u003cbr\u003e*Open your curtains regularly 7:00\u003cbr\u003e*Change the water for the fish tank regularly\u003cbr\u003e*Use mobile phone or voice control Garage door switch\u003cbr\u003e*Control your heater remotely\u003cbr\u003e*And your coffee machine\u003cbr\u003e*Connect a water pump, remote control or timer switch\u003cbr\u003eMore functions waiting for you to discover. DIY\u003c\/p\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\u003cp\u003eChecklist before using the device\u003c\/p\u003e\u003c\/div\u003e\n\u003cdiv\u003e\u003cp\u003eYou need to have a Zigbee gateway.\u003cbr\u003eTry to be close to the Zigbee gateway when pairing.\u003c\/p\u003e\u003c\/div\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S0de9e4c3c56145ac85524dc26b282b5ak.jpg\"\u003e\u003c\/div\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S90aac7e235bc4502b47f234b8d2533ab4.jpg\"\u003e\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eTiming Function\u003c\/p\u003e\n\u003cp\u003eyou can the time to turn on lights and turn on the fans in the office\u003c\/p\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S0146399ae9d844a2afa2766aa8845aa5s.jpg\"\u003e\u003c\/div\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S8b19ef10c29c460cb577087f01079bceq.jpg\"\u003e\u003c\/div\u003e\n\u003cdiv\u003e\u003cp\u003eRemote control of garage door opening and closing\u003c\/p\u003e\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S8f630e7cb56b443a8ce231842bfd43faE.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sb67bd4de1337425b9f3cbf4cf4b7bcb0l.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S9ab1b15f895a435482b8f05048d779c1i.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S1df92b27acbb41e692fdb0622f33c0327.jpg\"\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eGroup Control\u003c\/p\u003e\n\u003cp\u003eSet all of your smart switches in a group by Smart Life app. Then one-click to turn\/off all of your appliances or lightings by smartphone.\u003c\/p\u003e\n\u003cdiv\u003e\n\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S5eda21238ff5434b89cad691942f195cM.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Se273b48c58a6486b93d477e523802f1fb.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sbada9bd3bffe42cfb4ed9e2a4b8b31bfg.jpg\"\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eHands-Free Voice Control\u003c\/p\u003e\n\u003cp\u003eCompatible with Alexa \u0026amp; Google Home,the smart switch allows you to control lights on\/off with your voice\u003c\/p\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae03.alicdn.com\/kf\/Sd955ccf8009740f1b41db937d453a00av.jpg\"\u003e\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eFamily Sharing\u003c\/p\u003e\n\u003cp\u003eShare the control with family member.Enjoy the convenience and happiness together\u003c\/p\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S2701f38fa38245d6ba364583d1a2e4eeA.jpg\"\u003e\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\u003cp\u003eEnglish instructions\u003c\/p\u003e\u003c\/div\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae03.alicdn.com\/kf\/S3064b0a03f9a4a478ffdcede587f2a56Q.jpg\"\u003e\u003c\/div\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae03.alicdn.com\/kf\/Sc11aacf90006431cab421408a3cb97e0N.jpg\"\u003e\u003c\/div\u003e\n\u003cdiv\u003e\u003cp\u003e433MHz Remote Control:\u003c\/p\u003e\u003c\/div\u003e\n\u003cdiv\u003e\u003cp\u003eOperating voltage: DC12V (27A\/12V Without battery)\u003cbr\u003eTransmitting frequency: 433MHz\u003cbr\u003eEncoding Type: Learning code\u003cbr\u003eTransmission distance : 10-100M (Open field)\u003cbr\u003eFree screwdriver\u003c\/p\u003e\u003c\/div\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S3742e27b84714c1cb21f6094c152c391F.jpg\"\u003e\u003c\/div\u003e\n\u003cdiv\u003e\u003cp\u003eFAQ\u003c\/p\u003e\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eI don't have a gateway, can I connect directly to a wifi network?\u003c\/p\u003e\n\u003cp\u003eSorry, this one won't work, this one needs to be connected to a ZIGBEE gateway to work\u003c\/p\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eHow far away can the switch be connected to the gateway?\u003c\/p\u003e\n\u003cp\u003eAs indoor environments vary, the distance between the wireless switch and the gateway varies. Generally, the communication distance between the two is less than 20 metres and is better when no more than two walls are in between.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eHow many modes of switching are there?\u003c\/p\u003e\n\u003cp\u003eTwo types, Self-locking ,Inching\u003c\/p\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eWhat app do I use?\u003c\/p\u003e\n\u003cp\u003eTuya \/Smart life\u003c\/p\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eI'm not a professional electrician, can I install it myself?\u003c\/p\u003e\n\u003cp\u003eYes, it is very easy to install, just follow the connection drawings and you are ready to go.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eDo you have a switch for more channels?\u003c\/p\u003e\n\u003cp\u003eContact our customer service，We also have 2CH and 4CH 7-32V 85-250V\u003c\/p\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eWhen is the order shipped and how long does it take to arrive?\u003c\/p\u003e\n\u003cp\u003eWe will ship your order within 24 hours of placing it (except for holidays). Normal shipping time is 25-60 days, except for special shipping methods.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/H130ab57adaaf46e9aac30713fc4a1cfdr.jpg\"\u003e\u003c\/div\u003e\n\u003cbr\u003e\n\u003c\/div\u003e","brand":"Scimagic","offers":[{"title":"Zigbee Switch","offer_id":54532753883429,"sku":"acfbf9aa-f93e-4a0c-9392-9be1dfd231c4","price":12.61,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0771\/4632\/5285\/files\/4201a5515610ad94fb1f9265def05d34.jpg?v=1794823803","url":"https:\/\/www.ezlo.com\/products\/1ch-zigbee-tuya-smart-relay-module-home-automation-7-32v-rf433mhz-remote-control-motor-light-garage-switch-work-with-alexa","provider":"Ezlo - Property Empowered","version":"1.0","type":"link"}
