{"product_id":"ewelink-smart-zigbee-temperature-humidity-sensor-app-control-indoor-thermometer-monitor-home-automation-works-with-alexa-google-1","title":"Ewelink Smart Zigbee Temperature Humidity Sensor App Control Indoor Thermometer Monitor Home Automation Works with Alexa Google","description":"\u003cdiv\u003e\n\u003cp\u003e\u003cstrong\u003eEWelink Smart Zigbee Temperature Humidity Sensor App Control Indoor Thermometer Monitor Home Automation Works With Alexa Google\u003c\/strong\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003eProduct name : Zigbee temperature \u0026amp; humidity sensor\u003c\/p\u003e\n\u003cp\u003eBattery : CR2450 (Included)\u003c\/p\u003e\n\u003cp\u003eWireless : zigbee 3.0\u003c\/p\u003e\n\u003cp\u003eTemperature resolution : 0.1 C\u003c\/p\u003e\n\u003cp\u003eHumidity Resolution: 3%\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e【\u003c\/span\u003eSupport Zigbee 2mqtt \/ Home Assistant】\u003cbr\u003eNote :The zigbee sensor must be used with eWeLink zigbee gateway. Not supported Tuya\/Smart Life.\u003cbr\u003eIf you need to connect to a third-part smart device, please ensure that your third-party device has a built-in gateway, otherwise it may not be able to be added;\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e【\u003c\/span\u003eSimple Design \u0026amp; Easy Installation】It's a battery-operated sensor with low-battery notification on your mobile, adopts adhesive tape on the bottom to easily install it in any corner of your house , as the living room, baby room, bedroom, greenhouse, reptiles terrarium, equipment cabinet to monitor temperature and humidity remotely.Excellux global store\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003eHigh accuracy built-in Swiss-made sensor ensures accurate measurement of room temperature and humidity, the temperature is accurate up to ±0.2℃ while the humidity is ±2%RH, and always gives you the latest changes in the environment. which all readings can be checked on eWeLink APP\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e【Smart Scene To Trigger Devices or Alerts 】You can set a condition in the smart scene that is the fan is turn on\/off when the temperature reaches the limit value, or the dehumidifier in your room starts working once the humidity is over higher. You can set a smart scene to trigger alerts through events like high\/low temperature, high\/low humidity conditions and more. Excellux global store\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e【Support other third-part voice assistant 】 You can use one Ewelink gateway to add devices on ewelink app first ,then bind the device with yandex alice , alexa ,google assistant ,or smartthings,then use voice control to ask the temperature and humidity . Excellux global store\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e【Sharing Control】Simply share the sensor to your family on EweLink APP and they can directly check this temperature and humidity on their mobile phones without pairing it. Excellux global store\u003c\/p\u003e\n\u003cp\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S93728003f1294f89b3e6b4615965b5a2C.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sef3b40d2c7f04ae8bb77179bfdd1e12cl.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S0834b77743d1475b9a7e4e14754a9305r.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S60e16bf95c2f4dc9a82d41647abb5694y.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S9ade36e27a5f4e238fbdb76b3a866b97h.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S6dc673e64c8540d2ba2c577d4b182b3cb.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S5a3063833be840f6b6ad6b5d3eef8d47j.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S0e3a64752b12434db9616c1e939e8c86f.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S5a361d50d8f04fcb9dd392dab86113afN.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S000447b01ce246d2bec931869351b82d6.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Se3c679a06a0746bc9cffe77fc91d8ca4P.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S98ccafc10d6442699cae6b300d1a4c91T.jpg\"\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003c\/div\u003e","brand":"Ezlo - Property Empowered","offers":[{"title":"1Pcs","offer_id":52027452260645,"sku":"dc9f47f4-ba06-4edf-9c67-5bb40d75a3e7","price":14.87,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0771\/4632\/5285\/files\/9f6d9ad7dfd2905ada6408ed3edccec8.jpg?v=1771930723","url":"https:\/\/www.ezlo.com\/products\/ewelink-smart-zigbee-temperature-humidity-sensor-app-control-indoor-thermometer-monitor-home-automation-works-with-alexa-google-1","provider":"Ezlo - Property Empowered","version":"1.0","type":"link"}
