{"product_id":"ewelink-tuya-zigbee-smart-electric-linear-actuator-motor-controller-ac-110v-220v-2-ch-switch-rf433-2ch-pulse-module-wifi-relay","title":"Ewelink Tuya Zigbee Smart Electric Linear Actuator Motor Controller,Ac 110V 220V 2 Ch Switch,Rf433,2Ch Pulse Module Wifi Relay","description":"\u003cdiv\u003e\n\u003cdiv\u003e\n\u003cp\u003eNOTE\u003c\/p\u003e\n\u003cp\u003e1.The package only have 2 channel relay,it don't include the Electric Linear Actuator Motor\u003cbr\u003e2.It can't control the motor speed.it only can control the motor forward and reverse.\u003cbr\u003e3.If you need to make the RF433 Remote controller work with the relay,you need to add the RF433 remote controller in the app firstly\u003c\/p\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eTuya Zigbee eWelink Wifi Smart Switch Electric Linear Actuator Motor Controller,DC AC 12V 24V RF433,2CH Pulse Module Relay\u003c\/p\u003e\n\u003cp\u003eIt can't control the motor speed.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eAttention! Attention! Attention!\u003c\/p\u003e\n\u003cp\u003eThree types of TUYA\/ZIGBEE\/EWELINK brand motor controllers\u003c\/p\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eUse for Tuya Motor Controller\u003c\/p\u003e\n\u003cp\u003e1.Remotely give a pulse signal to turn on or turn off Lights,Lamps,pc and other home appliance.\u003cbr\u003e2.Remotelygive a pulse signal to turn on or turn off Garage Door,Door Access,Sliding Door.\u003cbr\u003e3.Remotely give a pulse signal to control DC Motor,AC Motor to Forward and reverse,such as linear motor\u003c\/p\u003e\n\u003cdiv\u003e\n\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sfdafc462021a48a4ad8da52dd20844bcl.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Se6d425a939d84616aa80ccb13c2a7c8b5.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sbbd529132cc04425908f6b7338b8dd40K.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S1f39333de85448cdbce558095024701a4.jpg\"\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\u003cp\u003eZigbee Motor Controller\u003c\/p\u003e\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S955bd9eaac80400e9a27ea5791b11bact.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S83c0fc39dd6142299e3ab18f91f50f08W.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sfb6fdaaf47164256b74a4096bea8c7a5Q.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sfb32bbf67c3c4ef49efb2b81db3838c3A.jpg\"\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\u003cp\u003eewelink Motor Controller\u003c\/p\u003e\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S733781baa2e94aed9cbdbacee7ba9731h.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Scd950082c14248b1b8b8d915fc350d13B.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S9ca9465508ab4cf4bfe1ae8eec3cb58f8.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S714178d04a5f48ec8fd87814d3040effN.jpg\"\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\u003cp\u003eOverview:\u003c\/p\u003e\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003e3 Working Mode:\u003c\/p\u003e\n\u003cp\u003e1.Self-locking : \u003cbr\u003eEach channel could be switched on\/off seperately.You can turn on\/turn off all channel at the same time.\u003cbr\u003e\u003cbr\u003e2.Interlocking mode :\u003cbr\u003eSwitch on any channel , other channels will be switched off automatically .\u003cbr\u003e\u003cbr\u003e3.Inching mode : \u003cbr\u003eSwitch on one channel,the channel will be automatically closed after 0.5seconds .Other channel is same as the channel.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\u003cp\u003eIf you need to change the mode,you need to change the working mode in app.\u003c\/p\u003e\u003c\/div\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S67891aeffadf4d67a859bf1361e84642t.jpg\"\u003e\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eFeatures:\u003c\/p\u003e\n\u003cp\u003e【Two Input Ports】\u003cbr\u003eYou could choose USB 5V port or the screw terminal port to supply power in the input to make the pcb board board work.\u003cbr\u003e【Dry Contact\/Passive Output】\u003cbr\u003e No matter how many power you supply in the input, the output don't have any power voltage\u003cbr\u003eIf you do not supply power in output port, the connectted home appliance can't work, you also need to supply power in output.\u003cbr\u003e【Timer】\u003cbr\u003eThe connectted home appliances can be automatically turned on\/off according to the time schedule.\u003cbr\u003eEach channel can set different time schedule.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eDifferent Ways to Control the WIFI Module\u003c\/p\u003e\n\u003cp\u003e【APP Remote Control】\u003cbr\u003eYou can control the connectted home appliance in Tuya or smart life APP anywhere and anytime.Such as light, electric kettle, electric rice cooker, electric curtain, etc.\u003cbr\u003e【RF433 Control】\u003cbr\u003eThe WIFI Module support RF433 Frequency,and you can control the WIFI module by RF433mhz remote controller.\u003cbr\u003e【Mobile Phone Control】\u003cbr\u003e When you go outside or at home,you could control the device in your smart phone by 2G\/3G\/4G Mobile Network or WIFI.\u003cbr\u003e(Note:The router need to onlinet.The WIFI module need to keep a close distance with the router and the wifi module need to online in Tuya Smart Life APP)\u003cbr\u003e【Voice Control 】\u003cbr\u003eCompatible with Alexa and Google Assistant, you can use the voice control to turn it on\/off the connectted home appliances . \u003cbr\u003e【Share Control】\u003cbr\u003eOne device can control by Multiple phones,you can share the wifi module with your family.So your family member also can control the module.\u003cbr\u003e【Group Control】\u003cbr\u003eone phone can control Multiple smart device.You can add the wifi module and other smart device in a group,and then turn on\/off all smart device at the same time.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sa02a6168d18b4adbafd9055333144fd14.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S8e2fbbe51d43413c916951ebd13b7f09d.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S60bce901de5e4b2f81bc67e7b63a78a32.jpg\"\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eSpecification:\u003c\/p\u003e\n\u003cp\u003eMaximum current≤ 10A\u003cbr\u003eInput 1: Micro USB 5V\u003cbr\u003eInput 2 (screw terminal port): :D C\/AC 7-32V AC 85-250V\u003cbr\u003eNO NC COM Output: Output Signal (Dry Contact)\u003cbr\u003eOperating temperature: -20-70°C\u003cbr\u003eOperating humidity: 40% to 80% RH\u003cbr\u003eWIFI standard: 2.4GHz, IEEE 802.11 b\/g\/n (5G not supported)\u003cbr\u003eSize: 120*38*25mm\u003cbr\u003eAPP: Tuya\/Smart Life\u003c\/p\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S76124d5f152f415a9a79a5ce7806b076e.jpg\"\u003e\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eTimer \u0026amp; Time Schedule\u003c\/p\u003e\n\u003cp\u003eSet time schedules to turn on\/off lights\u003c\/p\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sd20f6df0ffc84ef7b0c24f69577c431d5.jpg\"\u003e\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eShare Control\u003c\/p\u003e\n\u003cp\u003eShare the device with your family or friends so that they can also control the devices remotely\u003c\/p\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sb8aa09ad64a64588b4ccf03a40f0bf80V.jpg\"\u003e\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eAPP Control\u003c\/p\u003e\n\u003cp\u003eYou can remote turn on\/off household appliances and set timing schedules to turn on\/off the household appliances via app Tuya\/Smart life anywhere anytime.\u003cbr\u003esuch as lights, celectric curtains ,electric curtains fans.\u003c\/p\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Seee5c67f34894f8888837f2794ea527co.jpg\"\u003e\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eVoice Control\u003c\/p\u003e\n\u003cp\u003eCompatible with Google Assistant and Alexa\u003cbr\u003eVoice control to turn on\/off your home applicances\u003c\/p\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S84440a0263494b5ba2b27c50dcd38587O.jpg\"\u003e\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\u003cp\u003eTUYA Controller Operating Instructions\u003c\/p\u003e\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S8d8c6c01944e46ed991d799945f759dfo.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sf03827a8054a4075b7ec821077cfdb6dn.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S2134ea71e7864422817f846498810a8aO.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S0d714341137b4b46b64e0d0f416e6531R.jpg\"\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\u003cp\u003eeWelink Controller Operating Instructions\u003c\/p\u003e\u003c\/div\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S04684cc22c3c4f2a8cf06a6950534db6x.jpg\"\u003e\u003c\/div\u003e\n\u003cdiv\u003e\u003cp\u003eZigbee Controller Operating Instructions\u003c\/p\u003e\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S2dd70dfa235141f8be8eee78f05f0d041.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sfc0d2e1612564405b9afa2d9ab0ed38dC.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sb9cccb57b14944fcaad3a9f0b6e033d98.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S876894fd6e8441e296423bb0af0fb4d1K.jpg\"\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eHow to pair RF433 remote controller with with the devices.\u003c\/p\u003e\n\u003cp\u003e1.Press the RF433 pairing button for 4 seconds,and wait until the blue led indicator turn on.\u003cbr\u003e\u003cbr\u003e2.press any key of RF433 remote controller, and then you can pair the channel with one key of RF433 remote controller successfully\u003cbr\u003eIf you need to pair other key of the RF433 Remote controller and other channel, you need to repeat the step.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eHow to clear the pairing RF433 remote controller with with the devices.\u003c\/p\u003e\n\u003cp\u003e1.Press the RF433 pairing button for15 seconds,and wait until the blue led indicator turn off.\u003cbr\u003eIf you need to clear the pairing between other key of the RF433 Remote controller and other channel, you need to repeat the step.\u003c\/p\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sff5eefc040df41ce8094edccb0b03a95E.jpg\"\u003e\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sa4ef6081658f4a3e805e64c9531eee1dz.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sfbc532d3cd754dcdb9b1498b72d57739l.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S0165e46627b34e5ca1dd5a90362562b62.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S5cd8f319e38e4787b74a065c9d700e414.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S63b38f76eb5c469c96b3edf10ddb2d59e.jpg\"\u003e\n\u003c\/div\u003e\n\u003cbr\u003e\n\u003c\/div\u003e","brand":"Scimagic","offers":[{"title":"Zigbee Ac 85-250V","offer_id":54532491411749,"sku":"602ca431-d397-45e9-b29b-69cd570233fd","price":12.91,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0771\/4632\/5285\/files\/8b6cb6e620178475e4f11e9a30b56ff7.jpg?v=1794822019","url":"https:\/\/www.ezlo.com\/products\/ewelink-tuya-zigbee-smart-electric-linear-actuator-motor-controller-ac-110v-220v-2-ch-switch-rf433-2ch-pulse-module-wifi-relay","provider":"Ezlo - Property Empowered","version":"1.0","type":"link"}
