{"product_id":"for-zigbee-smart-fingerbot-plus-switch-button-pusher-touch-arms-fingerbot-works-with-tuya-smart-life-control-for-alexa-google","title":"For Zigbee Smart Fingerbot plus Switch Button Pusher Touch Arms Fingerbot Works with Tuya Smart Life Control for Alexa Google","description":"\u003cdiv\u003e\n\u003cp\u003e\u003cspan\u003e\u003cstrong\u003e\u003cspan\u003e*Universal Compatibility.\u003c\/span\u003e\u003c\/strong\u003e\u003c\/span\u003e\u003cspan\u003e\u003cspan\u003e Effortlessly control buttons and switches on coffee makers, vacuum cleaners, and office PCs.\u003c\/span\u003e\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e\u003cstrong\u003e\u003cspan\u003e*\u003c\/span\u003e\u003c\/strong\u003e\u003c\/span\u003e\u003cstrong\u003eTotal control via the Smart Life app\u003c\/strong\u003e: Schedule routines, customize arm movements, and monitor device status anytime, anywhere.\u003cstrong\u003e(Requires a gateway\u003c\/strong\u003e\u003cspan\u003e\u003cspan\u003ecompatible with \u003c\/span\u003e\u003c\/span\u003e\u003cstrong\u003eTuya Zigbee ; 2.4GHz Wi-Fi compatible.)\u003c\/strong\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e\u003cstrong\u003e*Modular \u0026amp; Replaceable Arms.\u003c\/strong\u003e\u003c\/span\u003e\u003cspan\u003e Features a modular design with replaceable arms to fit any button type. \u003c\/span\u003e\u003cspan\u003e\u003cspan\u003e3D printing templates are also available for DIYers.\u003c\/span\u003e\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e\u003cstrong\u003e\u003cspan\u003e*Hands-Free Voice Control.\u003c\/span\u003e\u003c\/strong\u003e\u003c\/span\u003e\u003cspan\u003e\u003cspan\u003e Fully compatible with Alexa and Google Home—just say the word to activate your appliances.\u003c\/span\u003e\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e\u003cstrong\u003e\u003cspan\u003e*Powered by CR2 Battery.\u003c\/span\u003e\u003c\/strong\u003e\u003c\/span\u003e\u003cspan\u003e\u003cspan\u003e Reliable performance with easy battery replacement to ensure your smart home never sleeps.\u003c\/span\u003e\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e\u003cspan\u003eInstallation steps:\u003c\/span\u003e\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e\u003cstrong\u003e\u003cspan\u003e1.Clean:\u003c\/span\u003e\u003c\/strong\u003e\u003c\/span\u003e\u003cspan\u003e\u003cspan\u003e Wipe the surface of the panel.\u003c\/span\u003e\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e\u003cstrong\u003e\u003cspan\u003e2.Stick:\u003c\/span\u003e\u003c\/strong\u003e\u003c\/span\u003e\u003cspan\u003e\u003cspan\u003e Use the provided 3M double-sided tape.\u003c\/span\u003e\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e\u003cstrong\u003e\u003cspan\u003e3.Calibrate:\u003c\/span\u003e\u003c\/strong\u003e\u003c\/span\u003e\u003cspan\u003e\u003cspan\u003e Connect to the App and adjust the arm's movement for the perfect press.\u003c\/span\u003e\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e\u003cstrong\u003e\u003cspan\u003e4.Wait:\u003c\/span\u003e\u003c\/strong\u003e\u003c\/span\u003e\u003cspan\u003e\u003cspan\u003e Let it settle for 24 hours for maximum adhesion.\u003c\/span\u003e\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e\u003cstrong\u003eSafety \u0026amp; Usage Notice:\u003c\/strong\u003e\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cul\u003e\n\u003cli\u003e\u003cp\u003e\u003cspan\u003e\u003cstrong\u003eNot Waterproof:\u003c\/strong\u003e\u003c\/span\u003e\u003cspan\u003eThis device is strictly for indoor use.\u003c\/span\u003e\u003cspan\u003e\u003cspan\u003eDo not install on underwater or outdoor equipment\u003c\/span\u003e\u003c\/span\u003e\u003cspan\u003e.\u003c\/span\u003e\u003cspan\u003e\u003cspan\u003e*\u003c\/span\u003e\u003c\/span\u003e\u003cspan\u003e\u003cstrong\u003e\u003cspan\u003eEnvironment Limits:\u003c\/span\u003e\u003c\/strong\u003e\u003c\/span\u003e\u003cspan\u003eAvoid humid or high-temperature environments (-10°C to 45°C \/ 14°F to 113°F)\u003c\/span\u003e\u003cspan\u003e\u003cspan\u003eto protect battery stability\u003c\/span\u003e\u003c\/span\u003e\u003cspan\u003e.\u003c\/span\u003e\u003c\/p\u003e\u003c\/li\u003e\n\u003cli\u003e\u003cp\u003e\u003cspan\u003e\u003cstrong\u003eObstruction Warning:\u003c\/strong\u003e\u003c\/span\u003e\u003cspan\u003eEnsure the arm's path is clear.\u003c\/span\u003e\u003cspan\u003e\u003cspan\u003eObstructing the movement may cause the arm to detach or damage the internal motor\u003c\/span\u003e\u003c\/span\u003e\u003cspan\u003e.\u003c\/span\u003e\u003c\/p\u003e\u003c\/li\u003e\n\u003cli\u003e\u003cp\u003e\u003cspan\u003e\u003cstrong\u003eBattery Care:\u003c\/strong\u003e\u003c\/span\u003e\u003cspan\u003ePowered by a replaceable CR2 3.0V battery.\u003c\/span\u003e\u003cspan\u003e\u003cspan\u003eReplace promptly if the arm movement becomes weak or unresponsive\u003c\/span\u003e\u003c\/span\u003e\u003cspan\u003e.\u003c\/span\u003e\u003c\/p\u003e\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cul\u003e\u003cli\u003e\u003cp\u003e\u003cspan\u003e\u003cstrong\u003e\u003cspan\u003eImportant: A Hub for tuya zigbee Required.\"\u003c\/span\u003e\u003c\/strong\u003e\u003c\/span\u003e\u003cspan\u003e\u003cstrong\u003e\u003cspan\u003e\"This device must be used with a Gateway compatible with tuya zigbee for App and Voice control\u003c\/span\u003e\u003c\/strong\u003e\u003c\/span\u003e\u003c\/p\u003e\u003c\/li\u003e\u003c\/ul\u003e\n\u003cp\u003e\u003cspan\u003e\u003cstrong\u003eWhy we recommend the Multi-Mode Gateway?\u003c\/strong\u003e\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003col\u003e\n\u003cli\u003e\u003cp\u003e\u003cspan\u003e\u003cstrong\u003eSuperior Stability:\u003c\/strong\u003e\u003c\/span\u003eEnsures your Fingerbot stays online\u003cspan\u003e24\/7\u003c\/span\u003ewithout signal drops.\u003c\/p\u003e\u003c\/li\u003e\n\u003cli\u003e\u003cp\u003e\u003cspan\u003e\u003cstrong\u003eFuture-Proof:\u003c\/strong\u003e\u003c\/span\u003ecompatible with TUYA Zigbee, Bluetooth, and Mesh—ready for all your future smart home upgrades\u003c\/p\u003e\u003c\/li\u003e\n\u003c\/ol\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S88f71a2420ad467a8c9fcc3259c69c25M.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/Sb693ea8e7bf2409f810d1dc5f2085c64w.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/Sc3376b355fe54d51a1edb1df8496c717x.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/Sac5c1dab9a704dd882586061f6513061C.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S78bc2408cd4044d7a6dfdec555a973acQ.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S35a7dcd82a424833b59969165f1c72bcQ.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/Sd809d63ccf4646a3a4284e8a8d871d8ap.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S377f8a654d184b7aa85f493c3c6e5230S.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S2e3e90d8681b4aa18c2b295d0a56c2afR.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S9a78ea28172442c1bddcab260463a91fh.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S3555dc0d7892461184982b946a662cd86.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S5bfbbeac762246e6b7a5eb93c53fa44cu.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/See43ba63d071414ba68f18576ed9e667N.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S6381184a22634cc2a8231e057b0345cfS.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/Sf7e1a26a1e4849cdabcd1a4d2865f6407.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S0291971e73334ddc90c5655908456317G.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/Sc1ed3cad12c9424081d3ccceccb1588ei.jpg\"\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003c\/div\u003e","brand":"Vivilife","offers":[{"title":"Black Fingerbot \/ No Plug","offer_id":52929367015717,"sku":"19254f58-d503-4d0d-a2bc-72fe35897de5","price":70.55,"currency_code":"USD","in_stock":true},{"title":"White Fingerbot \/ No Plug","offer_id":52929367048485,"sku":"97a9ddf0-27a2-433e-b952-4dbb9b2530c4","price":70.97,"currency_code":"USD","in_stock":true},{"title":"Kit A \/ No Plug","offer_id":52929367081253,"sku":"552f348e-65d7-4aca-8021-f0d2b1948c96","price":82.78,"currency_code":"USD","in_stock":true},{"title":"Kit B \/ No Plug","offer_id":52929367114021,"sku":"3e972328-b1ca-486d-ae7d-4d7b47eb4252","price":83.34,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0771\/4632\/5285\/files\/Sa5f551b93d914952847ca378c4f5f313H.webp?v=1785509679","url":"https:\/\/www.ezlo.com\/products\/for-zigbee-smart-fingerbot-plus-switch-button-pusher-touch-arms-fingerbot-works-with-tuya-smart-life-control-for-alexa-google","provider":"Ezlo - Property Empowered","version":"1.0","type":"link"}
