{"product_id":"mini-24g-mmwave-radar-zigbee-presence-sensor-human-detector-occupancy-sensor-static-motion-detect-for-tuya-home-assistant-z2mqtt","title":"Mini 24G Mmwave Radar Zigbee Presence Sensor Human Detector Occupancy Sensor,Static\/Motion Detect,For Tuya\/Home Assistant Z2MQTT","description":"\u003cdiv\u003e\n\u003cp\u003eMini 24G Mmwave Radar Zigbee Presence Sensor Human Detector Occupancy Sensor,Static\/Motion Detect,For Tuya\/Home Assistant Z2MQTT\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e【What is the difference between these 2 options?】\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e*For Z2MQTT(bracket): Need work with zigbee2mqtt on home assistant via related gateway.Not support for tuya nor smart life gateway.\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e\u003cbr\u003e*Tuya Zigbee(bracket):Need work with tuya zigbee gateway,Also compatible with zigbee2mqtt on home assistant via related gateway.Not support for ZHA(zigbee home automation )\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eProduct name :Zigbee Occupancy Sensor\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eBattery: CR2450 Button Battery(Included)\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eWireless: Zigbee 3.0\u003cbr\u003eRadar: 24GHz\u003cbr\u003eWorking Voltage: DC 3.0V\u003cbr\u003eStandby current: \u0026lt;60uA\u003cbr\u003eDetection angle：≥ 80°\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eDetection distance ：≤ 5m\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e\u003cbr\u003e\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eFunction Description\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eZigbee Occupancy Sensor means zigbee human presence sensor,it can detect motion and static status.\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e• Click \"SET\" \" to turn on\/off the LED indicator light, which will stay on once to indicate it is turned on, Flashing 3 times, closing the meter\u003cbr\u003e• The default duration for someone to hold it is 30 seconds, which can be set on the app\u003cbr\u003e• The 24GHz radar version supports static detection and motion detection\u003cbr\u003e• There is a detection version available at 24GHz, with motion\/static sensitivity- The higher the value, the more sensitive it is If the default parameters trigger false alarms, please reduce the motion detection sen sitivity. If the static state cannot be maintained, you can increase the static detection sensitivity and Set. the 'Presence Keep Time' time to a Longer value.\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e•Create smart scene and linkage with other zigbee devices\u003c\/span\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sbae6d404c5b041bc86df4197e57b88d6k.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S832c942babcb4dd2b94361a59a1559f0k.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S52edfc0cd66b4036bc5389d7a7910389t.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sea9179d4950b40d6860a553cb80e0432R.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S83067511aff646a3b02fdb1579e1bdb5j.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S7c2bdc22c5ea4185bd33d6ebf217bc61v.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S44a111b066d549a9af8a01c221e0d2a8f.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S3356210412754873a9ca7b8e0f48417ax.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sa7ddbdcfd25f456dae814906d20dc967N.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sb8af3e31bcee458eaaa97b5228bde2c0D.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S75d6274cf6d0420b99729e18127773c87.jpg\"\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S2b99e3e461d04065a31f0aa635011cc9y.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S68db57326a394889a70d1fb38f70a4bcL.jpg\"\u003e\u003c\/p\u003e\n\u003c\/div\u003e","brand":"Forubest","offers":[{"title":"For Z2Mqtt(Bracket)","offer_id":53743958655269,"sku":"2b8bee16-c227-4049-8740-416333aa1ab0","price":23.66,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0771\/4632\/5285\/files\/S2b99e3e461d04065a31f0aa635011cc9y.webp?v=1788514297","url":"https:\/\/www.ezlo.com\/products\/mini-24g-mmwave-radar-zigbee-presence-sensor-human-detector-occupancy-sensor-static-motion-detect-for-tuya-home-assistant-z2mqtt","provider":"Ezlo - Property Empowered","version":"1.0","type":"link"}
