{"product_id":"smart-temperature-humidity-sensor-tuya-zigbee3-0-zigbee-2-mqtt-suppor-display-the-temperature-home-assistant","title":"Smart Temperature Humidity Sensor Tuya Zigbee3.0 Zigbee 2 MQTT Suppor Display the Temperature Home Assistant","description":"\u003cdiv\u003e\n\u003cp\u003e\u003cstrong\u003e\u003cspan\u003eLincukoo Smart Temperature Humidity Sensor Tuya Zigbee3.0 Zigbee 2 MQTT suppor display the temperature Home Assistant\u003c\/span\u003e\u003c\/strong\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e--It can detect and display temperature \u0026amp; humidity, internet time, comfort indicator in real time, linkage with other devices to bring you a comfortable environment in room\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e--It can be installed by magnetic, double-sided tape, or just place on table can used in any place at home\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e--Its detection range is-20-60°C(accuracy:±0.3°C) \/ 0-100%RH(accuracy:±3%), can sound alarm when reached your setting value\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e--You may check the curve of history record by day, month or year to know about the changing of temperature \u0026amp; humidity\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e--You may also set the temperature unit (C°\/F°), the accuracy, the alarm function in setting page\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e--High-capacity batteries can be used for 1year at least (the duration may vary depending on the usage environment) even if low battery alarm, still can last for 1-2months.\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003e\u003cspan\u003eProduct information:\u003c\/span\u003e\u003c\/strong\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eVersion:T04TZ\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003ePlatform Support:Tuya，Home Assistant\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eTransmission Protocol:Zigbee.30\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eZigbee 2 MQTT support:Yes\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eTransmission distance(max):40meters\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eDetection Range:-20-60°C(±0.3)\/0-100RH(±3)\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eSetting and calibration：Yes\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eSound alarm：Yes\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eBattery：2*AAA\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eLow battery alarm:App notification\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eInstall mothed:Magnetic, double-side tape\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eSize:75*44*17mm\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S3f4d870829b74fdc9bd42bef4f59aae3P.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sc8663016eaa1478296e1125dfe803a844.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sf29717e2f19243c4a5a7d1a02ad782efb.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sf24456211a2347cea588c6da33df719aX.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S7f780df1374b4a33a4104f28ba474851Q.jpg\"\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003c\/div\u003e","brand":"Lincukoo","offers":[{"title":"White","offer_id":53632779419941,"sku":"2c989b3f-7fd5-4958-83fc-6506b18f3fb0","price":46.3,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0771\/4632\/5285\/files\/S1a7429d21a134ce8be7f5acd247b1b13Y.webp?v=1787235044","url":"https:\/\/www.ezlo.com\/products\/smart-temperature-humidity-sensor-tuya-zigbee3-0-zigbee-2-mqtt-suppor-display-the-temperature-home-assistant","provider":"Ezlo - Property Empowered","version":"1.0","type":"link"}
