{"product_id":"smart-zigbee-3-0-temperature-and-humidity-sensor-tiny-remote-monitor-for-smart-home-assistant-zigbee2mqtt-ewelink","title":"Smart Zigbee 3.0 Temperature and Humidity Sensor Tiny Remote Monitor for Smart Home Assistant Zigbee2Mqtt Ewelink","description":"\u003cdiv\u003e\n\u003cp\u003e\u003cstrong\u003e\u003cspan\u003eLincukoo Smart Zigbee 3.0 Temperature And Humidity Sensor Tiny Remote Monitor for Smart Home Assistant zigbee2MQTT eWelink\u003c\/span\u003e\u003c\/strong\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003e\u003cspan\u003eImportant Note:\u003c\/span\u003e\u003c\/strong\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eThe EZ version only be used on Home Assistant or Ewelink platform, need zigbee gateway to use \u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003ch5\u003e\u003cstrong\u003e\u003cspan\u003eTiny Temperature \u0026amp; Humidity Sensor Description：\u003c\/span\u003e\u003c\/strong\u003e\u003c\/h5\u003e\n\u003ch5\u003e\u003cspan\u003e-This sensor can detect the real-time temperature \u0026amp; humidity, In App, you may see the current value or the history record to know about the temperature \u0026amp; humidity changing aroundyou \u003c\/span\u003e\u003c\/h5\u003e\n\u003ch5\u003e\u003cspan\u003e-The High accuracy sensor chip supports that the detect range is -20-60°C(±0.3°C) and 0-100RH(±3RH)\u003c\/span\u003e\u003c\/h5\u003e\n\u003ch5\u003e\u003cspan\u003e-If you want to use it at a fix point, you can use adhesive tape or screw, if you want to use it on different positions, you can also hang it at you need. \u003c\/span\u003e\u003c\/h5\u003e\n\u003ch5\u003e\u003cspan\u003e-2*AAA batteries can be used for 2yeas at least (the duration may vary depending on the usage environment), even if low battery alarm, stillcan last for 1-2months.\u003c\/span\u003e\u003c\/h5\u003e\n\u003ch5\u003e\u003cspan\u003e-Support linkage with other devices through gateway, such as turn on\/off the air-conditioner, humidifier……\u003c\/span\u003e\u003c\/h5\u003e\n\u003ch5\u003e\u003cstrong\u003e\u003cspan\u003eProduct information：\u003c\/span\u003e\u003c\/strong\u003e\u003c\/h5\u003e\n\u003ch5\u003e\u003cspan\u003eVersion：EZ\u003c\/span\u003e\u003c\/h5\u003e\n\u003ch5\u003e\u003cspan\u003ePlatform support：Home Assistant, Ewelink\u003c\/span\u003e\u003c\/h5\u003e\n\u003ch5\u003e\u003cspan\u003eTransmission Protocol ：Zigbee3.0\u003c\/span\u003e\u003c\/h5\u003e\n\u003ch5\u003e\u003cspan\u003eZigbee to MQTTsupport ：Yes\u003c\/span\u003e\u003c\/h5\u003e\n\u003ch5\u003e\u003cspan\u003eTransmission distance(max)：30meters\u003c\/span\u003e\u003c\/h5\u003e\n\u003ch5\u003e\u003cspan\u003eTemperature\/Humidity alarm setting ：No\u003c\/span\u003e\u003c\/h5\u003e\n\u003ch5\u003e\u003cspan\u003eBattery：2*AAA\u003c\/span\u003e\u003c\/h5\u003e\n\u003ch5\u003e\u003cspan\u003eLow battery alarm：App notification\u003c\/span\u003e\u003c\/h5\u003e\n\u003ch5\u003e\u003cspan\u003eIP grade ：IP64\u003c\/span\u003e\u003c\/h5\u003e\n\u003ch5\u003e\u003cspan\u003eSize：73*25*17mm\u003c\/span\u003e\u003c\/h5\u003e\n\u003ch5\u003e\u003cspan\u003eInstall mothed：Double-sided tape or hanging\u003c\/span\u003e\u003c\/h5\u003e\n\u003ch5\u003e\u003cspan\u003eCertification ：CE,Rohs,FCC\u003c\/span\u003e\u003c\/h5\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sc1025b2196ee46fc9eb6735ef5d729d5p.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sc66220f73f5648a78579417261808f83l.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sf97cb418c81545a78146c8818ff86dfcD.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sfe1f14ec31984c3985bbee4d5c089527q.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S1d8c12619a0c4e378e2fcc96a81ec9bcQ.jpg\"\u003e\u003c\/p\u003e\n\u003c\/div\u003e","brand":"Lincukoo","offers":[{"title":"White","offer_id":53632931660069,"sku":"bf1c7210-3530-42bf-9df1-eb39e707033a","price":24.5,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0771\/4632\/5285\/files\/S0e7fb4257991483188731e99d521e832E.webp?v=1787235965","url":"https:\/\/www.ezlo.com\/products\/smart-zigbee-3-0-temperature-and-humidity-sensor-tiny-remote-monitor-for-smart-home-assistant-zigbee2mqtt-ewelink","provider":"Ezlo - Property Empowered","version":"1.0","type":"link"}
