{"product_id":"smart-zigbee-soil-moisture-sensor-temp-humidity-light-fertility-meter-thermo-hygrometer-garden-automation-irrigation-detector","title":"Smart Zigbee Soil Moisture Sensor Temp Humidity Light Fertility Meter Thermo Hygrometer Garden Automation Irrigation Detector","description":"\u003cdiv\u003e\n\u003cp\u003e\u003cbr\u003e*Compatible zigbee hub is required ,they cannot work alone without related gateway.\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eWhat is the difference between these 6 options?\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e**3 In 1(For Z2MQTT):\u003c\/p\u003e\n\u003cp\u003eSoil moisture detection +Air temperature + Air Humidity ,\u003c\/p\u003e\n\u003cp\u003eNeed to work with zigbee2mqtt on home assistant via related gateway.\u003c\/p\u003e\n\u003cp\u003eNot support for ZHA(zigbee home automation ),Not support for tuya.\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e**4 In 1(For Z2MQTT):\u003c\/p\u003e\n\u003cp\u003eSoil moisture detection +Air temperature + Air Humidity + Luminance Detection ,\u003c\/p\u003e\n\u003cp\u003eNeed to work with zigbee2mqtt on home assistant via related gateway..\u003c\/p\u003e\n\u003cp\u003eNot support for ZHA(zigbee home automation ),Not support for tuya.\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e**5 In 1(For Z2MQTT):\u003c\/p\u003e\n\u003cp\u003eSoil moisture detection +Air temperature + Air Humidity + Luminance Detection +soil fertility ,\u003c\/p\u003e\n\u003cp\u003eNeed to work with zigbee2mqtt on home assistant via related gateway..\u003c\/p\u003e\n\u003cp\u003eNot support for ZHA(zigbee home automation ),Not support for tuya.\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e**3 In 1(For tuya zigbee):\u003c\/p\u003e\n\u003cp\u003eSoil moisture detection +Air temperature + Air Humidity ,\u003c\/p\u003e\n\u003cp\u003eNeed to work with tuya zigbee gateway,Also compatible with zigbee2mqtt on home assistant via related gateway..\u003c\/p\u003e\n\u003cp\u003eNot support for ZHA(zigbee home automation ).\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e**4 In 1(For tuya zigbee):\u003c\/p\u003e\n\u003cp\u003eSoil moisture detection +Air temperature + Air Humidity + Luminance Detection ,\u003c\/p\u003e\n\u003cp\u003eNeed to work with tuya zigbee gateway,Also compatible with zigbee2mqtt on home assistant via related gateway..\u003c\/p\u003e\n\u003cp\u003eNot support for ZHA(zigbee home automation ).\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e**5 In 1(For tuya zigbee):\u003c\/p\u003e\n\u003cp\u003eSoil moisture detection +Air temperature + Air Humidity + Luminance Detection +soil fertility,\u003c\/p\u003e\n\u003cp\u003eNeed to work with tuya zigbee gateway,Also compatible with zigbee2mqtt on home assistant via related gateway..\u003c\/p\u003e\n\u003cp\u003eNot support for ZHA(zigbee home automation ).\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003eParameters\u003c\/p\u003e\n\u003cp\u003eItem: Zigbee 3.0 Soil Humidity Temperature Tester\u003c\/p\u003e\n\u003cp\u003eBattery Type: 2 x LR03 AAA\u003cstrong\u003e\u003cspan\u003e(not included)\u003c\/span\u003e\u003c\/strong\u003e\u003cbr\u003eWireless Protocol: Zigbee 3.0(need zigbee gateway)\u003cbr\u003eSoil Moisture resolution: 3%\u003cbr\u003eTemperature Resolution: 0.1℃\u003cbr\u003eHumidity Resolution: 3%\u003c\/p\u003e\n\u003cp\u003eLight intensity Resolution: 1lux (only 4 in 1 version or only 5 in 1 version)\u003cbr\u003eTemperature Measurement Accuracy: ±0.5℃\u003cbr\u003eHumidity Measurement Accuracy: ±5%\u003cbr\u003eWorking Voltage: DC3V\u003cbr\u003eStandby Current: ≤20uA\u003cbr\u003eApp: for Smart Life,for tuya app\u003c\/p\u003e\n\u003cp\u003eDo not support for alexa or google assistant voice ,no voice control .\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003eInstallation Instructions\u003cbr\u003e1. Before inserting the sensor into the soil,please ensure that the surface of the \"soil moisture sensor\" is clean.\u003c\/p\u003e\n\u003cp\u003e2.Insert the sensor into the soil for no less than 2\/3. Ensure that the sensing surface of the moisture sensor is in contact with the soil.\u003c\/p\u003e\n\u003cp\u003e3. After insertion, wait for about 30 seconds~ 1 minute to detect the moisture level.\u003c\/p\u003e\n\u003cp\u003e4. When the moisture value differs by 3%, the air temperature value differs by 0.3°C, and the air humidity value differs by 5%, the data will be uploaded to the APP.\u003c\/p\u003e\n\u003cp\u003e5. Support create smart scene with other related zigbee products.\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/Sd288172b59d94b1484d22c56c873d2f6J.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/Sbeff1d6c78334d2bbfb4c3e8e405beb1G.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S06ec605255b74f6c9af306f5d37d10737.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/Sf6a3d5b41bd741d691869149a45d526dQ.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S11c8b7b9d0b948a8a58ba2e8b6e0ff3ct.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/Se224526452da44b78f4f289ef60acd00m.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S0f493050c1434e1193a9f84ca47959ba4.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/Sc842bcf5e78d4ada894354ff41ea3fd9P.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/Se162c236095841e280d0fe361a2a04f3L.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/Sf42fa024f32f4718939444a6f127150bi.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/Sae4064be6c1b4fbba95e5d1baf07db6at.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/Sd80abdef372d4f34972cb49873d6174bm.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S4586259ac401494482a5f24212c822f9L.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/Sdca0e369e5ba45cda0cec6cf1c3b75b6N.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S49b4e2f6c7304a0cafd07c4318da95a2Q.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/Sde55998051fb42208df29eb4d903cd8dn.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S27bf05f47e8b41f2abf3fe7a545c9addA.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/Sf10f177818ca4c599badee6d0d6b67d7F.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S96ee1aee735e407a8fa36f9f9e631657N.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/Sa953a60722b94efab2cc29dd2b1bde8db.jpg\"\u003e\u003c\/p\u003e\n\u003c\/div\u003e","brand":"Forubest","offers":[{"title":"For Z2M(3 In 1)","offer_id":53632751337765,"sku":"40b9cc13-ae47-42dc-901f-c103b61943aa","price":10.42,"currency_code":"USD","in_stock":true},{"title":"Tuya Zigbee(3 In 1)","offer_id":53632751370533,"sku":"bf290db1-526e-415f-91cb-76c342be9446","price":11.96,"currency_code":"USD","in_stock":true},{"title":"For Z2M(4 In 1)","offer_id":53632751468837,"sku":"c32c3812-53a7-4aaf-afa1-e6471de74d3a","price":11.39,"currency_code":"USD","in_stock":true},{"title":"Tuya Zigbee(4 In 1)","offer_id":53632751501605,"sku":"3e8ff835-c6f1-4f04-8ebe-dadb3020b026","price":20.62,"currency_code":"USD","in_stock":true},{"title":"For Z2M(5 In 1)","offer_id":53632751403301,"sku":"f7e3b04d-300d-41c8-893d-44e1b6bae666","price":20.59,"currency_code":"USD","in_stock":true},{"title":"Tuya Zigbee(5 In 1)","offer_id":53632751436069,"sku":"45fd3810-c2df-4759-8a36-bc95172f81fd","price":23.03,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0771\/4632\/5285\/files\/S056ed2734470417998375e43fecc4f4ed.webp?v=1787234816","url":"https:\/\/www.ezlo.com\/products\/smart-zigbee-soil-moisture-sensor-temp-humidity-light-fertility-meter-thermo-hygrometer-garden-automation-irrigation-detector","provider":"Ezlo - Property Empowered","version":"1.0","type":"link"}
