{"product_id":"tuya-zigbee-addressable-cob-led-strip-light-kit-rgbic-ws2811-high-density-spi-flexible-smart-tape-lamp-room-decor-5m-10m-20m-25m","title":"Tuya Zigbee Addressable COB LED Strip Light Kit RGBIC WS2811 High Density SPI Flexible Smart Tape Lamp Room Decor 5M 10M 20M 25M","description":"\u003cdiv\u003e\u003cdiv\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cdiv\u003e \u003cspan\u003e\u003cstrong\u003eWarning: \u003c\/strong\u003e\u003c\/span\u003e \u003c\/div\u003e\n\u003cdiv\u003e \u003cspan\u003e\u003cstrong\u003eNever turn on the LED strip while it is still coiled on the reel or kept coiled for a long time, as heat cannot dissipate properly and this may cause the LED strip to overheat and burn out!\u003c\/strong\u003e\u003c\/span\u003e \u003cbr\u003e \u003c\/div\u003e\n\u003cp\u003eNotice\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003e1. Please re-set the pixel number in the APP before using, if not set the pixel number, the led strip may not work properly (the pixel number = length*20, for examle: 10m led strip is 10*20=200).\u003cbr\u003e\u003cbr\u003e2. If you find the R\/G\/B wire sequence of the led strip is different from the controller, you can reset the R\/G\/B sequence in the APP.\u003cbr\u003eIf you don't know how to reset it, can ask us for help.\u003c\/strong\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003ch4\u003e🌟【Product Overview】\u003c\/h4\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003ePremium high-density smart chasing color LED strip kit designed for ambient home decoration, ceiling lighting, and commercial showroom setup for global smart home enthusiasts.\u003c\/p\u003e\n\u003ch4\u003e🚀【Key Features】\u003c\/h4\u003e\n\u003cul\u003e \u003cli\u003e\u003cp\u003e▫️ \u003cstrong\u003eDot-Free Illumination:\u003c\/strong\u003e 720 LEDs\/m COB technology provides smooth linear light without dark spots compared to old SMD strips.\u003c\/p\u003e\u003c\/li\u003e \u003cli\u003e\u003cp\u003e▫️ \u003cstrong\u003eAddressable Dream Color:\u003c\/strong\u003e WS2811 IC architecture allows 160 million colors, rich dynamic chasing modes, and customized DIY lighting effects.\u003c\/p\u003e\u003c\/li\u003e \u003cli\u003e\u003cp\u003e▫️ \u003cstrong\u003eSmart Ecosystem Sync:\u003c\/strong\u003e Full integration with Tuya, Smart Life, Alexa, Google Assistant, and Philips Hue for responsive voice control.\u003c\/p\u003e\u003c\/li\u003e \u003cli\u003e\u003cp\u003e▫️ \u003cstrong\u003eStable Mesh Connection:\u003c\/strong\u003e Zigbee connection offers zero lag response, ultra-stable signal, and supports multi-group controller synchronization.\u003c\/p\u003e\u003c\/li\u003e \u003cli\u003e\u003cp\u003e▫️ \u003cstrong\u003eMusic \u0026amp; Timing Function:\u003c\/strong\u003e Built-in high sensitivity microphone syncs lights to your favorite music rhythm. Features scheduled automatic on\/off timers.\u003c\/p\u003e\u003c\/li\u003e \u003cli\u003e\u003cp\u003e▫️ \u003cstrong\u003eCuttable \u0026amp; Flexible:\u003c\/strong\u003e Strong self-adhesive back tape allows easy bending. Can be cut every 50mm at marked lines for exact custom fitting.\u003c\/p\u003e\u003c\/li\u003e \u003c\/ul\u003e\n\u003ch4\u003e📐【Specifications】\u003c\/h4\u003e\n\u003cul\u003e \u003cli\u003e\u003cp\u003e🔹 \u003cstrong\u003eStrip Width:\u003c\/strong\u003e 12mm\u003c\/p\u003e\u003c\/li\u003e \u003cli\u003e\u003cp\u003e🔹 \u003cstrong\u003eStrip Thickness:\u003c\/strong\u003e 2.5mm to 3.0mm\u003c\/p\u003e\u003c\/li\u003e \u003cli\u003e\u003cp\u003e🔹 \u003cstrong\u003eLED Quantity:\u003c\/strong\u003e 720 LEDs per meter\u003c\/p\u003e\u003c\/li\u003e \u003cli\u003e\u003cp\u003e🔹 \u003cstrong\u003ePCB Color Available:\u003c\/strong\u003e White \/ Black\u003c\/p\u003e\u003c\/li\u003e \u003cli\u003e\u003cp\u003e🔹 \u003cstrong\u003ePower Consumption:\u003c\/strong\u003e 15W per meter\u003c\/p\u003e\u003c\/li\u003e \u003cli\u003e\u003cp\u003e🔹 \u003cstrong\u003eColor Rendering Index (CRI):\u003c\/strong\u003e RA \u0026gt; 90\u003c\/p\u003e\u003c\/li\u003e \u003cli\u003e\u003cp\u003e🔹 \u003cstrong\u003eLighting Color:\u003c\/strong\u003e SPI RGB IC (Chasing Color)\u003c\/p\u003e\u003c\/li\u003e \u003cli\u003e\u003cp\u003e🔹 \u003cstrong\u003eIC Type:\u003c\/strong\u003e WS2811 IC (1 IC controls 5cm strip, 20 ICs\/m)\u003c\/p\u003e\u003c\/li\u003e \u003cli\u003e\u003cp\u003e🔹 \u003cstrong\u003eMinimum Cut Unit:\u003c\/strong\u003e 50mm\u003c\/p\u003e\u003c\/li\u003e \u003cli\u003e\u003cp\u003e🔹 \u003cstrong\u003eControl Range:\u003c\/strong\u003e 30 Meters (2.4G Remote Handle)\u003c\/p\u003e\u003c\/li\u003e \u003cli\u003e\u003cp\u003e🔹 \u003cstrong\u003eController Feature:\u003c\/strong\u003e Power-off State Memory Function\u003c\/p\u003e\u003c\/li\u003e \u003c\/ul\u003e\n\u003ch4\u003e📦【Package Includes】\u003c\/h4\u003e\n\u003cul\u003e \u003cli\u003e\u003cp\u003e🎁 \u003cstrong\u003eFor 1M - 5M Kit:\u003c\/strong\u003e 1 x COB LED Strip, 1 x Tuya Zigbee Controller, 1 x 2.4G Remote Control (Battery Not Included), 1 x Power Adapter.\u003c\/p\u003e\u003c\/li\u003e \u003cli\u003e\u003cp\u003e🎁 \u003cstrong\u003eFor 10M Kit:\u003c\/strong\u003e 1 x 10M COB LED Strip, 1 x Tuya Zigbee Controller, 1 x 2.4G Remote Control (Battery Not Included), 1 x Power Transformer, 1 x EU Plug Cable, 1 x Spare 90-Degree L-Shape Corner Connector.\u003c\/p\u003e\u003c\/li\u003e \u003cli\u003e\u003cp\u003e🎁 \u003cstrong\u003eFor 20M Kit:\u003c\/strong\u003e 2 x 10M COB LED Strip, 1 x Tuya Zigbee Controller, 1 x 2.4G Remote Control (Battery Not Included), 2 x Power Transformer, 2 x EU Plug Cable, 1 x Spare 90-Degree L-Shape Corner Connector.\u003c\/p\u003e\u003c\/li\u003e \u003cli\u003e\u003cp\u003e🎁 \u003cstrong\u003eFor 25M Kit:\u003c\/strong\u003e 2 x 10M COB LED Strip + 1 x 5M COB LED Strip, 1 x Tuya Zigbee Controller, 1 x 2.4G Remote Control (Battery Not Included), 2 x Power Transformer, 2 x EU Plug Cable, 1 x Spare 90-Degree L-Shape Corner Connector.\u003c\/p\u003e\u003c\/li\u003e \u003cli\u003e\u003cp\u003e🎁 \u003cstrong\u003eFor 30M Kit:\u003c\/strong\u003e 3 x 10M COB LED Strip, 1 x Tuya Zigbee Controller, 1 x 2.4G Remote Control (Battery Not Included), 2 x Power Transformer, 2 x EU Plug Cable, 1 x Spare 90-Degree L-Shape Corner Connector.\u003c\/p\u003e\u003c\/li\u003e \u003c\/ul\u003e\n\u003ch4\u003e🔧【How to Use】\u003c\/h4\u003e\n\u003cul\u003e \u003cli\u003e\u003cp\u003e📌 \u003cstrong\u003eStep 1:\u003c\/strong\u003e Connect the LED strip to the Tuya Zigbee controller matching the arrow marks carefully.\u003c\/p\u003e\u003c\/li\u003e \u003cli\u003e\u003cp\u003e📌 \u003cstrong\u003eStep 2:\u003c\/strong\u003e Connect the controller to the included power transformer\/adapter, then plug into your wall outlet.\u003c\/p\u003e\u003c\/li\u003e \u003cli\u003e\u003cp\u003e📌 \u003cstrong\u003eStep 3:\u003c\/strong\u003e Turn on your Tuya Zigbee Gateway, pair the controller in the Smart Life App, and enjoy smart lighting.\u003c\/p\u003e\u003c\/li\u003e \u003c\/ul\u003e\n\u003ch4\u003e🛑【Important Notes】\u003c\/h4\u003e\n\u003cul\u003e \u003cli\u003e\u003cp\u003e❗️ \u003cstrong\u003eGateway Required:\u003c\/strong\u003e This kit does NOT connect to WiFi directly. A compatible Tuya Zigbee Gateway Hub is strictly required.\u003c\/p\u003e\u003c\/li\u003e \u003cli\u003e\u003cp\u003e❗️ \u003cstrong\u003eHeat Warning:\u003c\/strong\u003e Never light up the LED strip while it is tightly wound on the plastic reel. Unroll completely before powering on.\u003c\/p\u003e\u003c\/li\u003e \u003cli\u003e\u003cp\u003e❗️ \u003cstrong\u003eVoltage Alert:\u003c\/strong\u003e Never connect the LED strip or controller directly to AC 220V mains power. Always use the provided power transformer.\u003c\/p\u003e\u003c\/li\u003e \u003cli\u003e\u003cp\u003e❗️ \u003cstrong\u003eDirection Indicator:\u003c\/strong\u003e Pay close attention to the print arrows on the strip when connecting. Reversing the input direction will burn the IC chips.\u003c\/p\u003e\u003c\/li\u003e \u003cli\u003e\u003cp\u003e❗️ \u003cstrong\u003eExtension Wire:\u003c\/strong\u003e If your transformer is far from the strip head, you must prepare an extra 2-pin extension cable yourself.\u003c\/p\u003e\u003c\/li\u003e \u003cli\u003e\u003cp\u003e❗️ \u003cstrong\u003eRemote Battery:\u003c\/strong\u003e The 2.4G remote handle requires batteries which are not included due to international shipping regulations.\u003c\/p\u003e\u003c\/li\u003e \u003c\/ul\u003e\n\u003cp\u003e━━━━━━━━━━━━━━━━━━━━━━━\u003c\/p\u003e\n\u003ch3\u003e💬【FAQ】\u003c\/h3\u003e\n\u003cp\u003e━━━━━━━━━━━━━━━━━━━━━━━\u003c\/p\u003e\n\u003cul\u003e \u003cli\u003e\n\u003cp\u003e\u003cstrong\u003eQ1: Can I connect this LED strip kit directly to my home WiFi router without a hub?\u003c\/strong\u003e\u003c\/p\u003e \u003cul\u003e \u003cli\u003e\u003cp\u003e💡 A1: No. This is a Zigbee version kit. You must have a Tuya Zigbee Gateway hub to connect it to the Smart Life or Tuya App.\u003c\/p\u003e\u003c\/li\u003e \u003c\/ul\u003e\n\u003c\/li\u003e \u003cli\u003e\n\u003cp\u003e\u003cstrong\u003eQ2: Does the package include everything needed for quick installation?\u003c\/strong\u003e\u003c\/p\u003e \u003cul\u003e \u003cli\u003e\u003cp\u003e💡 A2: Yes, it is a plug-and-play complete kit. However, if the transformer is far from the light strip, you need to buy a 2-pin extension cable. Remote batteries are also not included.\u003c\/p\u003e\u003c\/li\u003e \u003c\/ul\u003e\n\u003c\/li\u003e \u003cli\u003e\n\u003cp\u003e\u003cstrong\u003eQ3: Can I cut the light strip and use it to turn a 90-degree corner on my wall?\u003c\/strong\u003e\u003c\/p\u003e \u003cul\u003e \u003cli\u003e\u003cp\u003e💡 A3: Yes. The strip can be cut every 50mm. Kits above 10 meters include a free 90-degree L-shape corner connector for tool-free corner installation.\u003c\/p\u003e\u003c\/li\u003e \u003c\/ul\u003e\n\u003c\/li\u003e \u003cli\u003e\n\u003cp\u003e\u003cstrong\u003eQ4: Is it safe to leave the light strip turned on while it is inside the packaging box or reel?\u003c\/strong\u003e\u003c\/p\u003e \u003cul\u003e \u003cli\u003e\u003cp\u003e💡 A4: Absolutely not. Lighting the strip while rolled up causes extreme heat accumulation and will burn out the LEDs and IC chips instantly. Always unroll it first.\u003c\/p\u003e\u003c\/li\u003e \u003c\/ul\u003e\n\u003c\/li\u003e \u003cli\u003e\n\u003cp\u003e\u003cstrong\u003eQ5: Is this light strip kit suitable for outdoor garden or bathroom illumination?\u003c\/strong\u003e\u003c\/p\u003e \u003cul\u003e \u003cli\u003e\u003cp\u003e💡 A5: No. This kit is designed for indoor decoration lighting such as living room ceilings, bedroom walls, and commercial displays. Keep away from water.\u003c\/p\u003e\u003c\/li\u003e \u003c\/ul\u003e\n\u003c\/li\u003e \u003c\/ul\u003e\n\u003cdiv\u003e \u003cdiv\u003e \u003cdiv\u003e \u003cp\u003e\u003cbr\u003e\u003c\/p\u003e \u003cdiv\u003e \u003cp\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S1c802785f3474aec86e73fe3aef5fcb2D.jpg\"\u003e\u003c\/p\u003e \u003cp\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S9412e7723350428285b32742db8020f37.jpg\"\u003e\u003c\/p\u003e \u003cp\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S8fd04ab7044647898b4642690c58d7a6o.jpg\"\u003e\u003c\/p\u003e \u003cp\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S5f53d2b4242d45dd83d45b9b3260fd96s.jpg\"\u003e\u003c\/p\u003e \u003cp\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S6a3bfeb7fb2c40a9966ce03b7eef571by.jpg\"\u003e\u003c\/p\u003e \u003cp\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S0ae439c97e274e36b9123200bdb8a7cdH.jpg\"\u003e\u003c\/p\u003e \u003cp\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/Sce7c36a7e9ba44e6aa447199c4c11898p.jpg\"\u003e\u003c\/p\u003e \u003cp\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S33412e390e6e4389a831eef61005709fc.jpg\"\u003e\u003c\/p\u003e \u003cp\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S27f7a94df7b74cee96f361bacfb85028h.jpg\"\u003e\u003c\/p\u003e \u003cp\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/Sf37fa13e14ec4586aed260d473d0ec174.jpg\"\u003e\u003c\/p\u003e \u003cp\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/Sa2a946518a5b463da4c7bebf95f5da7fM.jpg\"\u003e\u003c\/p\u003e \u003cp\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S435a174586cd43b8b5d080fd31cc7c2ck.jpg\"\u003e\u003c\/p\u003e \u003cp\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S4486021517834f78967628c97edcd7888.jpg\"\u003e\u003c\/p\u003e \u003cp\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S3fbf66faeaf0431ea034d99a4f5fae9dI.jpg\"\u003e\u003c\/p\u003e \u003cp\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S6595170a76514dab8aaf01d7f1e4e626m.jpg\"\u003e\u003c\/p\u003e \u003cp\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S7884fd04a95344e9b140660f6a1d1f8a1.jpg\"\u003e\u003c\/p\u003e \u003cp\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/Sf8d58621d0f34ddabce288e7d8f48b4eR.jpg\"\u003e\u003c\/p\u003e \u003cp\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/Se65aa1d3adf64305bcbd716480a4ccfdh.jpg\"\u003e\u003c\/p\u003e \u003cp\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S200ef64ecdab47cca72eb8c7aeb5bd04K.jpg\"\u003e\u003c\/p\u003e \u003cp\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S003a5ac21b92446d887284b49b915d20e.jpg\"\u003e\u003c\/p\u003e \u003cp\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/Sa1cd74489c334bf0bceb9081a4336cf53.jpg\"\u003e\u003c\/p\u003e \u003cp\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/Sd03c2df9d9494e71a5f6fb8546a5a9a8v.jpg\"\u003e\u003c\/p\u003e \u003c\/div\u003e \u003cdiv\u003e \u003cbr\u003e \u003c\/div\u003e \u003cp\u003e\u003cbr\u003e\u003c\/p\u003e \u003c\/div\u003e \u003c\/div\u003e \u003c\/div\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cdiv\u003e \u003cbr\u003e \u003c\/div\u003e\n\u003cdiv\u003e \u003cspan\u003e\u003cstrong\u003eAbout the remote:\u003c\/strong\u003e\u003c\/span\u003e \u003c\/div\u003e\n\u003cdiv\u003e \u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sd03132cfd0804354bad1b7ae53b6925d3.jpg\"\u003e \u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S945b27a35b0d47bd8ed481c5b742716ao.jpg\"\u003e \u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S330b0b5c35bd415ea6f2984381e1a24aH.jpg\"\u003e \u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S30b5f26e305f4ad5852ca64b9d931cb4H.jpg\"\u003e \u003c\/div\u003e\n\u003cdiv\u003e \u003cdiv\u003e \u003cbr\u003e \u003cbr\u003e \u003c\/div\u003e \u003cp\u003e\u003cstrong\u003eCertificates\u003c\/strong\u003e\u003c\/p\u003e \u003c\/div\u003e\n\u003cdiv\u003e \u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S7f6b7debf20741fea63b9170f8ab2a507.jpg\"\u003e \u003c\/div\u003e\n\u003cdiv\u003e \u003cp\u003eAbout Cooleeon Company\u003cbr\u003eSHENZHEN COOLEEON ELECTRONICS CO., LTD. was founded in 2012, who is a professional manufacturer of COB LED products.Our products ranges from indoor \u0026amp; outdoor lighting, car lights, truck lights, traffic lighting, decoration lighting, plant grow lights to high power LED etc. We also supply OEM \u0026amp; ODM service to design \u0026amp; produce customers’ own special products.\u003cbr\u003eAs a professional COB LED supplier, Cooleeon has excellent teams who focus on product development \u0026amp; design, quality control \u0026amp; inspection and company running. We own a 5,000 square meters factory with 30 automatic production lines and more than 100 staffs,daily output reach to 5,000,000 pieces, who is one of the largest COB manufacturer in China.\u003cbr\u003e“Quality first” is always Cooleeon People’s NO.1 goal. In order to supply high quality products and services, Cooleeon has built a modern quality management system which is in strict accordance with international standards. Till now, Cooleeon’s products have been sold to more than 100 countries \u0026amp; district, main market including North America, Europe, Middle East, Japan, Korea, Southeast Asia, South America etc. We also have gained very good public praise and feedback from out customers.\u003cbr\u003eIf you have any new ideas or concepts for the products, please contact us. We are glad to work together with you and finally bring you the satisfied products.\u003c\/p\u003e \u003c\/div\u003e\n\u003cdiv\u003e \u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S3889437860474300a8108e21e3a3a6116.jpg\"\u003e \u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Se6e7e218acb3444a829c4585738120558.jpg\"\u003e \u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sb667c9ebbe584f458dd19c2f82101a58n.jpg\"\u003e \u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S2cc47c6603684a2187e90a6e7421bf534.jpg\"\u003e \u003c\/div\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cdiv\u003e \u003cbr\u003e \u003c\/div\u003e\n\u003cdiv\u003e \u003cbr\u003e \u003c\/div\u003e\n\u003cbr\u003e\n\u003c\/div\u003e\u003c\/div\u003e","brand":"Cooleeon","offers":[{"title":"1M White Pcb Rc1 \/ 100V-240V Us Plug","offer_id":54619371995429,"sku":"91809aca-fa9c-41cb-8c8e-fded2efa4b38","price":123.65,"currency_code":"USD","in_stock":true},{"title":"3M White Pcb Rc1 \/ 100V-240V Us Plug","offer_id":54619371962661,"sku":"6143dc92-71f3-43ce-afd2-29b1b1370cf8","price":165.66,"currency_code":"USD","in_stock":true},{"title":"5M White Pcb Rc1 \/ 100V-240V Us Plug","offer_id":54619372060965,"sku":"d53d2557-57bc-456c-a903-a066cf3cdb2f","price":211.24,"currency_code":"USD","in_stock":true},{"title":"10M White Pcb Rc1 \/ 100V-240V Us Plug","offer_id":54619372028197,"sku":"7c41ed32-acb6-47bc-b157-5b5a81f41f4f","price":329.2,"currency_code":"USD","in_stock":true},{"title":"15M White Pcb Rc1 \/ 100V-240V Us Plug","offer_id":54619371864357,"sku":"d76f8d45-e819-47ad-ae1a-8955075f1d60","price":428.08,"currency_code":"USD","in_stock":true},{"title":"20M White Pcb Rc1 \/ 100V-240V Us Plug","offer_id":54619371831589,"sku":"0903d29d-970b-4a05-ab57-8c841b9837ed","price":508.56,"currency_code":"USD","in_stock":true},{"title":"25M White Pcb Rc1 \/ 100V-240V Us Plug","offer_id":54619371929893,"sku":"e42fb2a3-c33d-4d2d-b91f-0ccce685ec16","price":594.2,"currency_code":"USD","in_stock":true},{"title":"1M Black Pcb Rc1 \/ 100V-240V Us Plug","offer_id":54619371897125,"sku":"6c1974bb-da3b-41d4-b303-8533d4f7dccb","price":128.5,"currency_code":"USD","in_stock":true},{"title":"3M Black Pcb Rc1 \/ 100V-240V Us Plug","offer_id":54619371733285,"sku":"fd3410ec-5038-46cc-a049-de5b7ca4ee4c","price":170.83,"currency_code":"USD","in_stock":true},{"title":"5M Black Pcb Rc1 \/ 100V-240V Us Plug","offer_id":54619371700517,"sku":"a0c1f3cb-9959-4626-b2d6-a5156aa49091","price":215.76,"currency_code":"USD","in_stock":true},{"title":"10M Black Pcb Rc1 \/ 100V-240V Us Plug","offer_id":54619371798821,"sku":"eb77911a-dde2-4306-b57f-1405ed595010","price":334.04,"currency_code":"USD","in_stock":true},{"title":"15M Black Pcb Rc1 \/ 100V-240V Us Plug","offer_id":54619371766053,"sku":"e0aa266b-9833-44fe-a7f4-09c4c8b101fd","price":432.94,"currency_code":"USD","in_stock":true},{"title":"20M Black Pcb Rc1 \/ 100V-240V Us Plug","offer_id":54619371602213,"sku":"84a88bb2-c8cb-408d-90b8-a975cc9364ab","price":517.27,"currency_code":"USD","in_stock":true},{"title":"25M Black Pcb Rc1 \/ 100V-240V Us Plug","offer_id":54619371569445,"sku":"7b2b841e-5c7c-457f-9b94-1697250664f9","price":595.16,"currency_code":"USD","in_stock":true},{"title":"1M White Pcb Rc2 \/ 100V-240V Us Plug","offer_id":54619371667749,"sku":"72318530-f182-4096-9223-881ee98b5af6","price":139.16,"currency_code":"USD","in_stock":true},{"title":"3M White Pcb Rc2 \/ 100V-240V Us Plug","offer_id":54619371634981,"sku":"5c8182ef-11ea-4d23-8992-3b469576aea4","price":181.18,"currency_code":"USD","in_stock":true},{"title":"5M White Pcb Rc2 \/ 100V-240V Us Plug","offer_id":54619372519717,"sku":"6214db90-f528-4b7e-b83b-5556525912f2","price":226.74,"currency_code":"USD","in_stock":true},{"title":"10M White Pcb Rc2 \/ 100V-240V Us Plug","offer_id":54619372486949,"sku":"e3190611-e5ee-4e1a-92dc-69d256ca7d2e","price":342.77,"currency_code":"USD","in_stock":true},{"title":"15M White Pcb Rc2 \/ 100V-240V Us Plug","offer_id":54619372585253,"sku":"7f11bd22-4263-4b3d-b703-13dfad28e3f8","price":443.59,"currency_code":"USD","in_stock":true},{"title":"20M White Pcb Rc2 \/ 100V-240V Us Plug","offer_id":54619372552485,"sku":"02fcbaed-563d-4664-8d9b-8f17c2d6e019","price":527.95,"currency_code":"USD","in_stock":true},{"title":"25M White Pcb Rc2 \/ 100V-240V Us Plug","offer_id":54619372388645,"sku":"728a86d1-33f3-4dd7-81e9-6f70a75630f9","price":609.72,"currency_code":"USD","in_stock":true},{"title":"1M Black Pcb Rc2 \/ 100V-240V Us Plug","offer_id":54619372355877,"sku":"83258e86-9916-4140-b3ed-b89584152eb6","price":143.69,"currency_code":"USD","in_stock":true},{"title":"3M Black Pcb Rc2 \/ 100V-240V Us Plug","offer_id":54619372454181,"sku":"7170a7f5-6136-4401-9461-e2a074268a08","price":186.35,"currency_code":"USD","in_stock":true},{"title":"5M Black Pcb Rc2 \/ 100V-240V Us Plug","offer_id":54619372421413,"sku":"e8ea8698-01d9-4404-a63b-b3fbd29e2a5e","price":231.59,"currency_code":"USD","in_stock":true},{"title":"10M Black Pcb Rc2 \/ 100V-240V Us Plug","offer_id":54619372257573,"sku":"2d568e9d-109e-4694-a97a-b100728a0240","price":349.56,"currency_code":"USD","in_stock":true},{"title":"15M Black Pcb Rc2 \/ 100V-240V Us Plug","offer_id":54619372224805,"sku":"4bd6a2af-5111-43c0-bf66-7ca91a49f4f3","price":444.56,"currency_code":"USD","in_stock":true},{"title":"20M Black Pcb Rc2 \/ 100V-240V Us Plug","offer_id":54619372323109,"sku":"1ba18e04-7d8f-401f-8fa8-794e2a24656a","price":532.8,"currency_code":"USD","in_stock":true},{"title":"25M Black Pcb Rc2 \/ 100V-240V Us Plug","offer_id":54619372290341,"sku":"8497d82d-4e8c-491b-a61c-51313c2382eb","price":614.56,"currency_code":"USD","in_stock":true},{"title":"1M White Pcb Rc3 \/ 100V-240V Us Plug","offer_id":54619372126501,"sku":"3a447f1a-78af-453a-a21f-938c3cb80c07","price":139.16,"currency_code":"USD","in_stock":true},{"title":"3M White Pcb Rc3 \/ 100V-240V Us Plug","offer_id":54619372093733,"sku":"6d2913b3-af68-4f9e-a60c-74d7a5d19fd4","price":181.18,"currency_code":"USD","in_stock":true},{"title":"5M White Pcb Rc3 \/ 100V-240V Us Plug","offer_id":54619372192037,"sku":"7224568d-3d8a-4d3d-8ad7-c7bcfbbf66a3","price":226.74,"currency_code":"USD","in_stock":true},{"title":"10M White Pcb Rc3 \/ 100V-240V Us Plug","offer_id":54619372159269,"sku":"f8a603ef-c8f6-41d3-8b6b-afa51b173f54","price":342.77,"currency_code":"USD","in_stock":true},{"title":"15M White Pcb Rc3 \/ 100V-240V Us Plug","offer_id":54619372847397,"sku":"e48993c3-fc32-4424-895f-4a4e9aadb523","price":443.59,"currency_code":"USD","in_stock":true},{"title":"20M White Pcb Rc3 \/ 100V-240V Us Plug","offer_id":54619372814629,"sku":"3d3c7d90-0cec-41d0-adb3-514144d51cfe","price":524.07,"currency_code":"USD","in_stock":true},{"title":"25M White Pcb Rc3 \/ 100V-240V Us Plug","offer_id":54619372912933,"sku":"7dffc049-f752-4f2a-85b7-3471c16f9a18","price":609.72,"currency_code":"USD","in_stock":true},{"title":"1M Black Pcb Rc3 \/ 100V-240V Us Plug","offer_id":54619372880165,"sku":"ebe4316c-23bd-4fdc-8e1e-3acd217420d9","price":144.01,"currency_code":"USD","in_stock":true},{"title":"3M Black Pcb Rc3 \/ 100V-240V Us Plug","offer_id":54619372716325,"sku":"1b5bdddb-60df-4db1-b165-b1cc2d1133f3","price":186.35,"currency_code":"USD","in_stock":true},{"title":"5M Black Pcb Rc3 \/ 100V-240V Us Plug","offer_id":54619372683557,"sku":"e8393c34-d185-4d68-af67-51fb64029717","price":231.26,"currency_code":"USD","in_stock":true},{"title":"10M Black Pcb Rc3 \/ 100V-240V Us Plug","offer_id":54619372781861,"sku":"48011e4c-967c-4c91-961e-8fd11cf0ef67","price":349.56,"currency_code":"USD","in_stock":true},{"title":"15M Black Pcb Rc3 \/ 100V-240V Us Plug","offer_id":54619372749093,"sku":"f5979247-0c47-46ca-b304-a6f66b3d6f30","price":448.44,"currency_code":"USD","in_stock":true},{"title":"20M Black Pcb Rc3 \/ 100V-240V Us Plug","offer_id":54619372650789,"sku":"3ed9358c-4ba9-4ee7-837f-b61ad9fc1184","price":532.8,"currency_code":"USD","in_stock":true},{"title":"25M Black Pcb Rc3 \/ 100V-240V Us Plug","offer_id":54619372618021,"sku":"308c4e8c-b83e-4102-9784-47791e87a727","price":610.68,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0771\/4632\/5285\/files\/S82d69cee8f934dcea3ba528276089dfaj.webp?v=1795434721","url":"https:\/\/www.ezlo.com\/products\/tuya-zigbee-addressable-cob-led-strip-light-kit-rgbic-ws2811-high-density-spi-flexible-smart-tape-lamp-room-decor-5m-10m-20m-25m","provider":"Ezlo - Property Empowered","version":"1.0","type":"link"}
