{"product_id":"tuya-zigbee-temperature-humidity-moisture-detector-smart-soil-tester-moisture-sensor-phone-app-realtime-monitor-for-home-garden-1","title":"Tuya Zigbee Temperature Humidity Moisture Detector Smart Soil Tester Moisture Sensor Phone App Realtime Monitor for Home Garden","description":"\u003cdiv\u003e\n\u003cdiv\u003e\u003cdiv\u003e\n\u003cp\u003e\u003cspan\u003e\u003cstrong\u003eDescription：\u003c\/strong\u003e\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003e\u003cspan\u003e1) Zigbee Hub Required:\u003c\/span\u003e\u003c\/strong\u003e\u003cspan\u003e Stardard zigbee 3.0 Version works with home assistant only.advice to use zigbee2mqtt ,not ZHA to get fully features.Tuya zigbee version can work with tuya zigbee hub and home assistant.\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e\u003cbr\u003e\u003c\/span\u003e\u003cstrong\u003e\u003cspan\u003e2)Waterproof:IPX4:\u003c\/span\u003e\u003c\/strong\u003e\u003cspan\u003ethe soil moisture sensor features an IPX4 waterproof rating for outdoor \u0026amp; garden use.\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003e\u003cspan\u003e3)App Remote Control:\u003c\/span\u003e\u003c\/strong\u003e\u003cspan\u003e Stay connected to your garden from anywhere in the world. Check your soil's temperature and humidity right from your smart phone.\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003e\u003cspan\u003e4) Water Shortage Warning:\u003c\/span\u003e\u003c\/strong\u003e\u003cspan\u003e Our smart system will gently remind you when it's time to water your plants, helping you keep your green friends happy and healthy.\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003e\u003cspan\u003e5) Smart Monitoring:\u003c\/span\u003e\u003c\/strong\u003e\u003cspan\u003e Keep track of air temperature, soil moisture,light intensity, so you always know what's happening in your garden.\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003e\u003cspan\u003e6) Comprehensive Measurement Range: \u003c\/span\u003e\u003c\/strong\u003e\u003cspan\u003eOur sensor accurately measures soil moisture from 0% to 100%, giving you complete insight into your plants' hydration needs.\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003e\u003cspan\u003e7) User-Friendly Design:\u003c\/span\u003e\u003c\/strong\u003e\u003cspan\u003e Compact, lightweight, and incredibly easy to use. Just plug it in and you're ready to go. With low power consumption, the batteries last a long time - making it the perfect companion for your garden care.\u003cbr\u003e\u003cbr\u003e\u003cbr\u003e\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e\u003cstrong\u003eProduct Specifications:\u003c\/strong\u003e\u003c\/span\u003e\u003cspan\u003e\u003cbr\u003e\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003e\u003cspan\u003e- Product Name:\u003c\/span\u003e\u003c\/strong\u003e\u003cspan\u003e Soil Moisture Sensor\u003c\/span\u003e\u003cbr\u003e\u003cstrong\u003e\u003cspan\u003e- Wireless Protocol:\u003c\/span\u003e\u003c\/strong\u003e\u003cspan\u003e Zigbee 3.0 (requires Zigbee hub to operate)\u003c\/span\u003e\u003cbr\u003e\u003cstrong\u003e\u003cspan\u003e- Soil Moisture Range:\u003c\/span\u003e\u003c\/strong\u003e\u003cspan\u003e 0%-100%\u003c\/span\u003e\u003cbr\u003e\u003cstrong\u003e\u003cspan\u003e- Temperature Resolution:\u003c\/span\u003e\u003c\/strong\u003e\u003cspan\u003e 0.1℃\u003c\/span\u003e\u003cbr\u003e\u003cstrong\u003e\u003cspan\u003e- Humidity Resolution:\u003c\/span\u003e\u003c\/strong\u003e\u003cspan\u003e 3%\u003cbr\u003e\u003c\/span\u003e\u003cstrong\u003e\u003cspan\u003e\u003cspan\u003e- \u003c\/span\u003e\u003c\/span\u003e\u003c\/strong\u003e\u003cstrong\u003e\u003cspan\u003eAir Temperature range:\u003c\/span\u003e\u003c\/strong\u003e\u003cspan\u003e-20~60°C\u003cbr\u003e\u003c\/span\u003e\u003cstrong\u003e\u003cspan\u003e\u003cspan\u003e- \u003c\/span\u003e\u003c\/span\u003e\u003c\/strong\u003e\u003cstrong\u003e\u003cspan\u003elluminance range:\u003c\/span\u003e\u003c\/strong\u003e\u003cspan\u003e0~150000 1x\u003c\/span\u003e\u003cbr\u003e\u003cstrong\u003e\u003cspan\u003e- Temperature Measurement Accuracy:\u003c\/span\u003e\u003c\/strong\u003e\u003cspan\u003e ±0.5℃\u003c\/span\u003e\u003cbr\u003e\u003cstrong\u003e\u003cspan\u003e- Humidity Measurement Accuracy: \u003c\/span\u003e\u003c\/strong\u003e\u003cspan\u003e±5%\u003c\/span\u003e\u003cbr\u003e\u003cstrong\u003e\u003cspan\u003e- Battery Type:\u003c\/span\u003e\u003c\/strong\u003e\u003cspan\u003e LR03AAA Battery *1pcs (not included)\u003c\/span\u003e\u003cbr\u003e\u003cstrong\u003e\u003cspan\u003e- Working Voltage:\u003c\/span\u003e\u003c\/strong\u003e\u003cspan\u003e DC1.5V\u003c\/span\u003e\u003cbr\u003e\u003cstrong\u003e\u003cspan\u003e- Standby Current:\u003c\/span\u003e\u003c\/strong\u003e\u003cspan\u003e ≤20uA\u003c\/span\u003e\u003cbr\u003e\u003cstrong\u003e\u003cspan\u003e- Standby Time:\u003c\/span\u003e\u003c\/strong\u003e\u003cspan\u003e ≥12 months\u003c\/span\u003e\u003cbr\u003e\u003cstrong\u003e\u003cspan\u003e- Temperature Unit Conversion: \u003c\/span\u003e\u003c\/strong\u003e\u003cspan\u003e℃-℉\u003c\/span\u003e\u003cbr\u003e\u003cstrong\u003e\u003cspan\u003e- Working Temperature:\u003c\/span\u003e\u003c\/strong\u003e\u003cspan\u003e -10℃-55℃\u003c\/span\u003e\u003cbr\u003e\u003cstrong\u003e\u003cspan\u003e- Working Humidity:\u003c\/span\u003e\u003c\/strong\u003e\u003cspan\u003e Max 99% RH\u003cbr\u003e\u003cbr\u003e\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e\u003cstrong\u003ePackage Contents:\u003c\/strong\u003e\u003c\/span\u003e\u003cbr\u003e\u003cspan\u003e- Soil Moisture Tester *1 (batteries not included)\u003c\/span\u003e\u003cbr\u003e\u003cspan\u003e- User Manual *1\u003cbr\u003e\u003c\/span\u003e\u003cimg src=\"https:\/\/sc04.alicdn.com\/kf\/H7fef37bd94ea424babb1a32c0df577ab0\/278577339\/H7fef37bd94ea424babb1a32c0df577ab0.jpg\"\u003e\u003cimg src=\"https:\/\/sc04.alicdn.com\/kf\/He0a9cef474b34c52a5ce9f047ec09cf7q\/278577339\/He0a9cef474b34c52a5ce9f047ec09cf7q.jpg\"\u003e\u003cimg src=\"https:\/\/sc04.alicdn.com\/kf\/H0e0b1f1d1c2e48e4ae15eef66d93b887M\/278577339\/H0e0b1f1d1c2e48e4ae15eef66d93b887M.jpg\"\u003e\u003cimg src=\"https:\/\/sc04.alicdn.com\/kf\/H8b16317fdae04a62983fb51362e30940L\/278577339\/H8b16317fdae04a62983fb51362e30940L.jpg\"\u003e\u003cimg src=\"https:\/\/sc04.alicdn.com\/kf\/H0358d3dc9c714e16999c97e8201eb6efM\/278577339\/H0358d3dc9c714e16999c97e8201eb6efM.jpg\"\u003e\u003cimg src=\"https:\/\/sc04.alicdn.com\/kf\/H1e3d263e07964b6ea135caba8b253822i\/278577339\/H1e3d263e07964b6ea135caba8b253822i.jpg\"\u003e\u003cimg src=\"https:\/\/sc04.alicdn.com\/kf\/H4eab4f1a28fa47d1b60babad659238edD\/278577339\/H4eab4f1a28fa47d1b60babad659238edD.jpg\"\u003e\u003cimg src=\"https:\/\/sc04.alicdn.com\/kf\/H203e792e7d944d4e9d5749dc2dc64d09L\/278577339\/H203e792e7d944d4e9d5749dc2dc64d09L.jpg\"\u003e\u003cimg src=\"https:\/\/sc04.alicdn.com\/kf\/Hf80e13d453da43eab55dfec1649c7731P\/278577339\/Hf80e13d453da43eab55dfec1649c7731P.jpg\"\u003e\u003cimg src=\"https:\/\/sc04.alicdn.com\/kf\/H5ccc6246b08946ab9766917a4ab62cdcI\/278577339\/H5ccc6246b08946ab9766917a4ab62cdcI.jpg\"\u003e\u003cimg src=\"https:\/\/sc04.alicdn.com\/kf\/H32470220d4414f5c84bf9bc3ee72848aq\/278577339\/H32470220d4414f5c84bf9bc3ee72848aq.jpg\"\u003e\u003cimg src=\"https:\/\/sc04.alicdn.com\/kf\/Hb3a6835010f943e0878f23939943d51aw\/278577339\/Hb3a6835010f943e0878f23939943d51aw.jpg\"\u003e\u003cimg src=\"https:\/\/sc04.alicdn.com\/kf\/H0f5f412f9a654665bded369254d8a206L\/278577339\/H0f5f412f9a654665bded369254d8a206L.jpg\"\u003e\u003cimg src=\"https:\/\/sc04.alicdn.com\/kf\/H024351a716aa45c9bf527d8e5a7a8f06l\/278577339\/H024351a716aa45c9bf527d8e5a7a8f06l.jpg\"\u003e\u003cimg src=\"https:\/\/sc04.alicdn.com\/kf\/H62afefce345e48dda053aa4458ef7c14z\/278577339\/H62afefce345e48dda053aa4458ef7c14z.jpg\"\u003e\u003cimg src=\"https:\/\/sc04.alicdn.com\/kf\/Hc9ac1f32dc5c46f3b6602e11e7f439afC\/278577339\/Hc9ac1f32dc5c46f3b6602e11e7f439afC.jpg\"\u003e\u003c\/p\u003e\n\u003c\/div\u003e\u003c\/div\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003c\/div\u003e","brand":"Haozee","offers":[{"title":"Type1","offer_id":54440643330341,"sku":"f61e1261-a9c9-4d03-914a-87e69401f71c","price":43.55,"currency_code":"USD","in_stock":true},{"title":"Type2","offer_id":54440643363109,"sku":"391d4691-cfff-4143-83fa-ff9af61575c8","price":46.37,"currency_code":"USD","in_stock":true},{"title":"Type3","offer_id":54440643428645,"sku":"a27eef2b-5897-4970-8bb2-280ebe314dc6","price":53.16,"currency_code":"USD","in_stock":true},{"title":"Type4","offer_id":54440643395877,"sku":"76eea590-3582-4d43-bb20-d95059201c39","price":55.67,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0771\/4632\/5285\/files\/S052195095a124d59ad0be4d4793e7fdfs.webp?v=1794301956","url":"https:\/\/www.ezlo.com\/products\/tuya-zigbee-temperature-humidity-moisture-detector-smart-soil-tester-moisture-sensor-phone-app-realtime-monitor-for-home-garden-1","provider":"Ezlo - Property Empowered","version":"1.0","type":"link"}
