{"product_id":"wireless-zigbee-magnetic-door-window-detector-smart-home-anti-theft-contact-sensor-app-push-alert-alarm-need-zigbee-hub-gateway","title":"Wireless Zigbee Magnetic Door Window Detector Smart Home Anti-Theft Contact Sensor APP Push Alert Alarm Need Zigbee Hub Gateway","description":"\u003cdiv\u003e\u003cdiv\u003e\n\u003cp\u003e\u003cspan\u003e\u003cstrong\u003eNotice: \u003c\/strong\u003e\u003c\/span\u003e\u003c\/p\u003e \u003cp\u003e\u003cspan\u003e\u003cstrong\u003e1、This device only can work along with a Zigbee Geteway. You need to connect wifi with a zigbee gateway successfully before use such zigbee T\u0026amp;H sensor. \u003c\/strong\u003e\u003c\/span\u003e\u003c\/p\u003e \u003cp\u003e\u003cspan\u003e\u003cstrong\u003e2、Turn on the device and smart speaker (Alexa or Google Home speaker) , they will be connected automatically; \u003c\/strong\u003e\u003c\/span\u003e\u003c\/p\u003e \u003cp\u003e\u003cspan\u003e\u003cstrong\u003e3、The device is also compatible with eWeLink ZigBee Gateway Hub. If Smart is not available for the device, please connect it with the eWeLink ZigBee Gateway Hub.\u003c\/strong\u003e\u003c\/span\u003e\u003c\/p\u003e \u003cp\u003e\u003cbr\u003e \u003cspan\u003e\u003cspan\u003e\u003cstrong\u003eSpecifications:\u003c\/strong\u003e\u003c\/span\u003e\u003c\/span\u003e\u003c\/p\u003e \u003cp\u003e\u003cspan\u003eAPP Name: Smart Life\u003c\/span\u003e\u003c\/p\u003e \u003cp\u003e\u003cspan\u003eBattery type: AAA1.5V*2 (Not include battery in shipment)\u003c\/span\u003e\u003c\/p\u003e \u003cp\u003e\u003cspan\u003eInput Voltage: DC3V LR03\u003c\/span\u003e\u003c\/p\u003e \u003cp\u003e\u003cspan\u003eQuiescent Current: ≤10uA\u003c\/span\u003e\u003c\/p\u003e \u003cp\u003e\u003cspan\u003eAlarm Current: ≤160mA\u003c\/span\u003e\u003c\/p\u003e \u003cp\u003e\u003cspan\u003eLow Power Undervoltage: ≤2.7V\u003c\/span\u003e\u003c\/p\u003e \u003cp\u003e\u003cspan\u003eMagnetic Control Distance: ≥15mm\u003c\/span\u003e\u003c\/p\u003e \u003cp\u003e\u003cspan\u003eWorking temperature: -10℃~50℃\u003c\/span\u003e\u003c\/p\u003e \u003cp\u003e\u003cspan\u003eWorking Humidity: max 95%RH\u003c\/span\u003e\u003c\/p\u003e \u003cp\u003e\u003cspan\u003eWireless Type: Zigbee\u003c\/span\u003e\u003c\/p\u003e \u003cp\u003e\u003cspan\u003eZigBee Gateway Hub:Required\u003c\/span\u003e\u003c\/p\u003e \u003cdiv\u003e\n\u003cbr\u003e \u003c\/div\u003e \u003cp\u003e\u003cspan\u003e\u003cstrong\u003eFeature: \u003c\/strong\u003e\u003c\/span\u003e\u003c\/p\u003e \u003cp\u003e\u003cstrong\u003e\u003cspan\u003e1.Ready-to-Go:\u003c\/span\u003e\u003c\/strong\u003e\u003cspan\u003eThe Smart Door Sensor is ready-to-go, meaning it can be easily installed without any complicated setup or configuration.\u003c\/span\u003e\u003c\/p\u003e \u003cp\u003e\u003cstrong\u003e\u003cspan\u003e2.Control Channels\u003c\/span\u003e\u003c\/strong\u003e\u003cspan\u003e: With 2 control channels, you can easily control the door sensor from your smartphone or tablet.\u003c\/span\u003e\u003c\/p\u003e \u003cp\u003e\u003cstrong\u003e\u003cspan\u003e3. Alarm Alert:\u003c\/span\u003e\u003c\/strong\u003e\u003cspan\u003eWhenever\u003c\/span\u003e\u003cspan\u003ethe sensor is triggered to open\/close, it will send alarm to alert you that someone opens your door or window.\u003c\/span\u003e\u003c\/p\u003e \u003cp\u003e\u003cstrong\u003e\u003cspan\u003e4. Alarm Recording:\u003c\/span\u003e\u003c\/strong\u003e\u003cspan\u003eSupport checking open \/ close records and battery level on the app. Never worry about missing any important moments or running out of battery.\u003c\/span\u003e\u003c\/p\u003e \u003cp\u003e\u003cstrong\u003e\u003cspan\u003e5. Device Share:\u003c\/span\u003e\u003c\/strong\u003e\u003cspan\u003eSelect “Home Management” in the “Me” page to share your added sensors with family members. so that they can also monitor the status of doors\/windows.\u003c\/span\u003e\u003c\/p\u003e \u003cp\u003e\u003cspan\u003e\u003cstrong\u003e6. \u003c\/strong\u003e\u003c\/span\u003e\u003cspan\u003e\u003cstrong\u003e\u003cspan\u003eLow VoltageRemind:\u003c\/span\u003e\u003c\/strong\u003e\u003c\/span\u003e\u003cspan\u003eWhen battery level is low, it will automatically remind you to change batteries, never worry about running out of battery.\u003c\/span\u003e\u003c\/p\u003e \u003cp\u003e\u003cstrong\u003e\u003cspan\u003e7.Works with alexa and Google Assistant.\u003c\/span\u003e\u003c\/strong\u003e\u003c\/p\u003e \u003cp\u003e\u003cstrong\u003e\u003cspan\u003e8.Enjoy Your Smart Life\u003c\/span\u003e\u003c\/strong\u003e\u003cspan\u003e:When you leave home, it will push notification message to you when the door\/window opens or closes, so you can discover the intruder in time. Furthermore, you could share the device to your family members and track the history of sensor activities.\u003c\/span\u003e\u003c\/p\u003e \u003cp\u003e\u003cstrong\u003e\u003cspan\u003e9.Easy to Install:\u003c\/span\u003e\u003c\/strong\u003e\u003cspan\u003eNo complicated installation tools are required. The sensor can be installed with double-sided adhesive tape or screws(included) in just a few steps, and download an app \"Smart Life\" from GooglePlay or App Store to add the device to detect the status of your door\/window.\u003c\/span\u003e\u003c\/p\u003e \u003cp\u003e\u003cspan\u003e\u003cstrong\u003epackage List: \u003c\/strong\u003e\u003c\/span\u003e\u003c\/p\u003e \u003cp\u003e\u003cspan\u003e1xDoor Sensor (Not include battery)\u003c\/span\u003e\u003c\/p\u003e \u003cp\u003e\u003cspan\u003e1xUser Manual\u003c\/span\u003e\u003c\/p\u003e \u003cp\u003e\u003cspan\u003e1xDouble-sided tape\u003c\/span\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/Sef0ebf99b4f94fc5a4c31637c395543fu.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/Sf35109393d3043559dbe022f784dccb67.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/Scba3846a29e341ca9698fcd84d688ac29.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S4e6f5b3b4a7d4c0582ccadd864ba888bK.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S1f8f2598a2c9432397d888a18145c7531.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/Sa26d4dc4d56446a288e3bc4b86daa5feW.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S904206df0d154df888638ce10fa4b6dc9.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/Scdd2c06d2b604a6985af04e6db9f0ea4n.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S3e027a6ee05c4d0cb366c558e07320cbE.jpg\"\u003e\u003c\/p\u003e \u003c\/div\u003e\u003c\/div\u003e","brand":"ZigeeLink","offers":[{"title":"Zigbee3.0","offer_id":52849457561893,"sku":"5877b031-a533-4d6e-8709-368b4d70c677","price":14.12,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0771\/4632\/5285\/files\/S30898a51d2eb4c4ab5c3ee72ef1bcdd9a.webp?v=1784902574","url":"https:\/\/www.ezlo.com\/products\/wireless-zigbee-magnetic-door-window-detector-smart-home-anti-theft-contact-sensor-app-push-alert-alarm-need-zigbee-hub-gateway","provider":"Ezlo - Property Empowered","version":"1.0","type":"link"}
