{"product_id":"zbm5-switchman-zigbee-smart-wall-switch-supports-no-neutral-and-neutral-wire-detach-relay-mode-works-with-home-assistant","title":"ZBM5 Switchman Zigbee Smart Wall Switch Supports No Neutral and Neutral Wire Detach Relay Mode Works with Home Assistant","description":"\u003cdiv\u003e\n\u003cdiv\u003e\n\u003cp\u003eSONOFF ZBM5 SwitchMan Zigbee Smart Wall Switch Supports No Neutral and Neutral Wire Detach Relay Mode Works with Home Assistant\u003c\/p\u003e\n\u003cp\u003eSupports both No Neutraland Neutral Wire\u003cbr\u003eSONOFF SwitchMan Zigbee smart Wall Switch\u003c\/p\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Se3d138cfdfb04e329fcc655471381a6df.jpg\"\u003e\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\u003cp\u003eNote: The supported SONOFF Zigbee Hub is needed.\u003c\/p\u003e\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003e【Support Both No Neutral \u0026amp; With Neutral Wire】The ZBM5 is designed to adapt to your home’s wiring configuration. Whether or not a neutral wire is available, it can be easily connected and used.\u003cbr\u003e【Compatible with Multiple Zigbee Hubs】 ZBM5 integrates with Zigbee hubs, such as SONOFF NSPanel Pro, SONOFF iHost, SONOFF ZB Bridge-P, SONOFF ZB Bridge-U, ZBDongle-E\/P.\u003cbr\u003e【Works with Home Assistant】ZBM5 seamlessly integrates with third-party open-source platforms, such as Home Assistant( Zigbee Dongle is required, e.g. SONOFF ZBDongle-P\/ ZBDongle-E), making it perfect for your home automation needs.\u003cbr\u003e【Detach Relay Mode】With the detach relay enabled, smart lights won’t lose power when the wall switch is turned off, allowing them to remain smart at all times. *Supports connecting smart lights only in the neutral required mode.\u003cbr\u003e【Fully Functional】ZBM5 has all the most basic functions, like remote APP control, voice control, timing schedule, smart scene, etc, making your life more convenient.\u003c\/p\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S80799283d3314ad5b5b65828573a4b60q.jpg\"\u003e\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eDirectly compatible withthe Majority Wiring\u003c\/p\u003e\n\u003cp\u003eThe ZBM5 is designed to adapt to your home's wiring configuration.Whether or not a neutral wire is availableit can be easily connected and used.\u003c\/p\u003e\n\u003cdiv\u003e\n\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S8ee55185f5c9484d83033bc3def8d8685.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S70bd7b520ce74506b9c61604ac6b6a69z.jpg\"\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003ePut Smart Home Control in Your Hands\u003c\/p\u003e\n\u003cp\u003eYou can view the switch status anytime in the eWeLink app or remotely control the switches, managing your home's switches from your phone\u003c\/p\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S2fd88f1684ef47bd91fa442748d62e16P.jpg\"\u003e\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eSchedule Lights Off for a Healthier Routine\u003c\/p\u003e\n\u003cp\u003eSet a timer in the app to turn off the lights\u003cbr\u003eautomatically in the livingroom and bedroom late at night, ensuring a peaceful sleep.\u003c\/p\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sa7a9788df8e44e48b0ad299562b5a20ep.jpg\"\u003e\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eSmart Scenes for a Convenient Life\u003c\/p\u003e\n\u003cp\u003eZigbee Two-Way Control\u003cbr\u003eSet up smart scenes with the Zigbee wireless button to control the bedroom light together.\u003cbr\u003e\u003cbr\u003eAutomation\u003cbr\u003eWork with the Zigbee sensor to automaticallyturn lights on or off for you.\u003c\/p\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S4b6e154fbf53469c99432274df1b51bas.jpg\"\u003e\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eDetach Relay For Wiring Smart Bulb\u003c\/p\u003e\n\u003cp\u003eWith the detach relay enabled, smart lights won't lose power when the wall switch is turned off, allowing them to remain smart at all times.\u003c\/p\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Saf497231139147788d2c729f6ca9b1efE.jpg\"\u003e\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eEffortless Control withYour Voice\u003c\/p\u003e\n\u003cp\u003eYou can control the switch when you're busy with a simple voice command.\u003c\/p\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S497832ceeeec448f9de90f3a1c80e6bdR.jpg\"\u003e\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eA Piece of open-Source Platform Solution\u003c\/p\u003e\n\u003cp\u003eEasily integrate your device into open-source platforms via Zigbee2MQTT or ZHA, creating a smart home solution that works seamlessly with devices from various manufacturers.\u003c\/p\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S8256d68ddeff4028a7f925216d51637fG.jpg\"\u003e\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eWorks with Apple Home Via Matter Bridge\u003c\/p\u003e\n\u003cp\u003eAll solutions integrate SONOFF zigbee devices into your Apple ecosystm via Matter Bridge, enabling seamless interconnected device control.\u003c\/p\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S103fd777a197449787c48b32e8502cfed.jpg\"\u003e\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eZigbee Hub compatibility\u003c\/p\u003e\n\u003cp\u003e*Requires the compatible SONOFF Zigbee hub.\u003c\/p\u003e\n\u003cdiv\u003e\n\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sda63ccdb773f47b4861e5c02333856d4r.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sc9d866f4339047d6a56323f22a2a83bcZ.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S9859b0a020fc491bb6c20c9c5aa992bf4.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sc3c35a1b40544c7f978e93b9f9c400ccv.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S8200fa2a09d64e3e8799f5267297ca0dT.jpg\"\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003c\/div\u003e","brand":"Sonoff","offers":[{"title":"Zbm5-1C-120W","offer_id":54123921539365,"sku":"bcf0ce96-3e31-4c30-bced-0b7f26908959","price":86.76,"currency_code":"USD","in_stock":true},{"title":"Zbm5-2C-120W","offer_id":54123921572133,"sku":"f186eea5-f3e4-492b-81c6-af23ecb8b376","price":96.96,"currency_code":"USD","in_stock":true},{"title":"Zbm5-3C-120W","offer_id":54123921604901,"sku":"2000238b-b1b1-45ef-82b8-6eb9f65fcda2","price":104.16,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0771\/4632\/5285\/files\/Sc50884f4eccf460595a8d28a600e1a02y.webp?v=1792398825","url":"https:\/\/www.ezlo.com\/products\/zbm5-switchman-zigbee-smart-wall-switch-supports-no-neutral-and-neutral-wire-detach-relay-mode-works-with-home-assistant","provider":"Ezlo - Property Empowered","version":"1.0","type":"link"}
