{"product_id":"zbminir2-zigbee-smart-switch-detach-relay-mode-external-switch-control-works-with-ewelink-zigbee-gateway-required-1-4pcs","title":"ZBMINIR2 Zigbee Smart Switch Detach Relay Mode External Switch Control Works with Ewelink Zigbee Gateway Required 1-4PCS","description":"\u003cdiv\u003e\n\u003cdiv\u003e\n\u003cp\u003eSONOFF ZBMINIR2 Zigbee Smart Switch Detach Relay Mode External Switch Control Works with eWeLink Zigbee Gateway Required 1-4PCS\u003c\/p\u003e\n\u003cp\u003eSONOFF ZBMINIR2 is an extremely compact Zigbee 3.0 smart switch, capable of being installed in EU-type\/86 type\/120 type mounting box and supporting a maximum load of 10A, compatible with various external switch types, upgrading your traditional external switch into a smart one, seamlessly integrating smart technology into your home for enhanced convenience and control.\u003cbr\u003e\u003cbr\u003eSONOFF ZBMINIR2 needs to be used with a Zigbee hub, such as SONOFF NSPanel Pro, SONOFF iHost, SONOFF ZB Bridge\/ZB Bridge-P\/ZB Bridge-U, SmartThings hub v3, Echo Plus 2nd…\u003cbr\u003e\u003cbr\u003eA reliable connection is crucial for your Zigbee network.ZBMINIR2, as a Zigbee router device with Turbo Mode', supports extending up to 64 Zigbee end devices, boosts signal strength, and expands coverage for optimal performance.\u003cbr\u003e\u003cbr\u003eAnnoyed by your smart bulb going offline when the external switch is off? Try 'Detach Mode'! Keep your smart bulb connected and worry-free, even with the external switch off. Worried about damage from sudden power restoration after an outage? Delay power-on is your solution, preventing harm from high currents when multiple loads turn on simultaneously.\u003cbr\u003e\u003cbr\u003eBased on the Zigbee 3.0 standard protocol, ZBMINIR2 seamlessly integrates with third-party open-source platforms, such as Home Assistant, Zigbee2MQT( Zigbee Dongle is required, e.g. SONOFF ZBDongle-P\/ ZBDongle-E) making it perfect for your home automation needs.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S5481fdba527f4ef39b82530d85fa98dfw.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S54f7c27c113e42bcb46bf7d4f2af2242Q.jpg\"\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S7195817944fd42bcb23c7ec9b249ebcaI.jpg\"\u003e\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eEffortlessly Smartify Your Existing Switch\u003c\/p\u003e\n\u003cp\u003eUpgrade your traditional external switch into a smart one, seamlessly integrating smart technology into your home for enhanced convenience and control.\u003c\/p\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Se7442a4876864552b9e8faee8d7f139cD.jpg\"\u003e\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eRich External Switch Types Support\u003c\/p\u003e\n\u003cp\u003eHighly flexible and compatible with various external switch types, ensuring wide usage and adaptability for all your needs.\u003c\/p\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S978214e721ff45788671c143389ad7ffK.jpg\"\u003e\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eGreat Solution for Using with Smart Bulb\u003c\/p\u003e\n\u003cp\u003eAnnoyed by your smart bulb going offline when the external switch is off? Try ‘Detach Mode’! Keep your smart bulb connected and worry-free, even with the external switch off.\u003c\/p\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S94a8e06ca4664429aaab7b0e7fe68554y.jpg\"\u003e\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eExpansive Zigbee Signal Coverage\u003c\/p\u003e\n\u003cp\u003eA reliable connection is crucial for your Zigbee network. ZBMINIR2, as a Zigbee router device with ‘Turbo Mode’, boosts signal strength and expands coverage for optimal performance.\u003c\/p\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sb6279c8b3d194cfd867650b16358c626c.jpg\"\u003e\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eDelay Power-on for Load Protection\u003c\/p\u003e\n\u003cp\u003eWorried about damage from sudden power restoration after an outage? Delay power-on is your solution, preventing harm from high currents when multiple loads turn on simultaneously.\u003c\/p\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S2191bba78a8c4c489aa50067a68f00b8z.jpg\"\u003e\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eSmart Covers Every Daily Details\u003c\/p\u003e\n\u003cp\u003eCarefully attend to every detail, ensuring convenience seamlessly integrates into all aspects of your daily routine.\u003c\/p\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sca7b0a064a5940c6b7d551360034d952L.jpg\"\u003e\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eEnsuring Safe Use with High Quality\u003c\/p\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sfd7b7dd51ec3484c9da9faeb178853baB.jpg\"\u003e\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eCompatible with Multiple Zigbee Hubs\u003c\/p\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S17ffc486300b4aecb8f657c2ad7f45c01.jpg\"\u003e\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eIntegration with Third-party Platforms\u003c\/p\u003e\n\u003cp\u003eBased on the Zigbee 3.0 standard protocol, it seamlessly integrates with third-party open-source platforms, making it perfect for your home automation needs.\u003c\/p\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Se4be5f8951d545d8bc5b8b3d4a3f3483c.jpg\"\u003e\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S48f516c54ccd4491b305efba30655ea6J.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S9bca2d91995242c3b6490b452f306f2cN.jpg\"\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eWorks with Apple Home Via Matter Bridge\u003c\/p\u003e\n\u003cp\u003eAll solutions integrate SONOFF Zigbee devices into your Apple ecosystem via Matter Bridge, enabling seamless interconnected device control.\u003c\/p\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S4c23eaa548514561b6e0c70e7d60402fo.jpg\"\u003e\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S1b2a3aa08e79443883cc807d4f9fe9fcl.jpg\"\u003e\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sa3676ba4bc824ecdad50f324450b770c1.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sde33c367105a4f2998f23cb9f11332284.jpg\"\u003e\n\u003c\/div\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003c\/div\u003e","brand":"Sonoff","offers":[{"title":"1Pc Zbminir2","offer_id":54097048895781,"sku":"cb21e215-f703-4cb0-bbfc-1b7e399ae9d2","price":29.97,"currency_code":"USD","in_stock":true},{"title":"2Pcs Zbminir2","offer_id":54097048928549,"sku":"25fb4ec1-6e23-4309-9364-d363974f92f3","price":68.62,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0771\/4632\/5285\/files\/38491a459228fefa6d75e28ecb013c12.jpg?v=1792162849","url":"https:\/\/www.ezlo.com\/products\/zbminir2-zigbee-smart-switch-detach-relay-mode-external-switch-control-works-with-ewelink-zigbee-gateway-required-1-4pcs","provider":"Ezlo - Property Empowered","version":"1.0","type":"link"}
