{"product_id":"zigbee-3-0-smart-home-ultra-thin-mini-5-in-1-led-controller-work-with-tuya-smartthings-app-voice-rf-remote-control","title":"Zigbee 3.0 Smart Home Ultra Thin Mini 5 in 1 LED Controller Work with Tuya Smartthings APP Voice RF Remote Control","description":"\u003cdiv\u003e\n\u003cdiv\u003e\u003cdiv\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Hb92b593cba754fb78e4e58a5138641dcl.jpg\"\u003e\u003c\/div\u003e\n\u003cdiv\u003e\u003cstrong\u003e\u003cspan\u003e\u003cspan\u003e🔴Mini 5 in 1 Controller can work with ZigBee2mqtt.\u003c\/span\u003e\u003c\/span\u003e\u003c\/strong\u003e\u003c\/div\u003e\n\u003cp\u003e\u003cspan\u003e\u003cstrong\u003e🔴PLEASE NOTE: In order to maintain the smoothness of the maximum brightness,\u003c\/strong\u003e\u003c\/span\u003e\u003cspan\u003e\u003cstrong\u003eall lamp beads will not reach maximum brightness at the same time\u003c\/strong\u003e\u003c\/span\u003e\u003cspan\u003e\u003cstrong\u003e. When used it is usually warm white + cool white = 100% brightness, such as 100% warm white + 0% cool white, or 50% warm white + 50% cool white. Instead of 100% warm white + 100% cool white.\u003c\/strong\u003e\u003c\/span\u003e\u003c\/p\u003e\n\u003cdiv\u003e\u003cstrong\u003e\u003cspan\u003e\u003cspan\u003e🔴Please kindly note that our zigbee devices(Zigbee\/Plus\/Pro version Products) require zigbee gatewayswith standard protocol.(Such as SmartThings, Tuya, Conbee ect.)\u003c\/span\u003e\u003c\/span\u003e\u003c\/strong\u003e\u003c\/div\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003e\u003cspan\u003e\u003cspan\u003e🔴 If you don't have any gateway, please buy one 2.4G RF remote control or wall switch to work with Pro Version Products.\u003c\/span\u003e\u003c\/span\u003e\u003c\/strong\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003e\u003cspan\u003e\u003cspan\u003e🔴 2.4G RF Remote Control and Wall Switch only work with Pro Version Products.(Not ZigBee)\u003c\/span\u003e\u003c\/span\u003e\u003c\/strong\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cdiv\u003e\u003cdiv\u003e\u003cdiv\u003e\u003cdiv\u003e\u003cdiv\u003e\u003cdiv\u003e\u003cdiv\u003e\u003cdiv\u003e\u003cdiv\u003e\u003cdiv\u003e\u003cdiv\u003e\u003cdiv\u003e\u003cdiv\u003e\u003cp\u003e\u003cspan\u003e\u003cstrong\u003e🔴 \u003c\/strong\u003e\u003c\/span\u003e\u003cspan\u003e\u003cstrong\u003eThis device is only compatible with the GLEDOPTO 2.4G RF remote control and cannot be compatible with other remote controls.\u003c\/strong\u003e\u003c\/span\u003e\u003c\/p\u003e\u003c\/div\u003e\u003c\/div\u003e\u003c\/div\u003e\u003c\/div\u003e\u003c\/div\u003e\u003c\/div\u003e\u003c\/div\u003e\u003c\/div\u003e\u003c\/div\u003e\u003c\/div\u003e\u003c\/div\u003e\u003c\/div\u003e\u003c\/div\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Hcbf6800d2f1b46c0a041e07cc9b93b0f9.jpg\"\u003e\u003cspan\u003e🌟 \u003c\/span\u003e\u003cstrong\u003e\u003cspan\u003eMini 5 in 1 LED Controller:\u003c\/span\u003e\u003c\/strong\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eThere has five modes to connect with led strip: RGBCCT\/RGBW\/RGB\/CCT\/Dimmer, and different color indicator correspond to different functions.\u003cbr\u003eYou can click the \"opt\" button, short press once to switch one of functions that you want according to the different indicator color, then you can connect between the different port of controller and corresponding wires of your led strip.\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e🌟 \u003c\/span\u003e\u003cstrong\u003e\u003cspan\u003ePower On Status Settings:\u003c\/span\u003e\u003c\/strong\u003e\u003cspan\u003e\u003cbr\u003eLong press the \"opt\" key for 5 seconds, the indicator of device will flash in blue color for 3 times, it will go into the \"power on\/off status“ mode, and the device will save the previous status before power off.\u003cbr\u003e\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eIt will has two options state under:\u003cbr\u003e① if the device is powering on, after the electricity drop and power on again, the device will keep on;\u003cbr\u003e② if the device is powering off, after the electricity drop and power on again, the device will keep off.\u003cbr\u003eRepeat the operation again to cancel this function, the device will be on by default status when powered on. \u003cbr\u003e\u003cbr\u003e\u003c\/span\u003e\u003cspan\u003e🌟\u003c\/span\u003e\u003cstrong\u003e\u003cspan\u003eFrequency Settings:\u003c\/span\u003e\u003c\/strong\u003e\u003cspan\u003e\u003cbr\u003eIn order to be applicable to different power supplies, the frequency of device is selectable as 600Hz, 800Hz, 1000Hz, 2000Hz, 4000Hz and 8000Hz, and default frequency 1000Hz.\u003cbr\u003eOnce short press \"reset\" key, the frequency will switch into the next one. The indicator will flash in pink color and resume to previous color after \"off\" for 2 seconds. The indicator flashing times corresponding to different frequency.\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e(There has specifications in user manual.) \u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Heed1ecd779424b958b5a195baf1ff04fB.jpg\"\u003e\u003c\/p\u003e\n\u003cdiv\u003e\u003cdiv\u003e\u003cdiv\u003e\u003cdiv\u003e\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\u003c\/div\u003e\u003c\/div\u003e\u003c\/div\u003e\u003c\/div\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/HTB1ROTuLRLoK1RjSZFuq6xn0XXa5.jpg\"\u003e\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003e\u003cspan\u003e🔥 \u003c\/span\u003e\u003cspan\u003e16 million colors for your choice and make your life colorful, to create a relaxing and quiet atmosphere. Such as living room, kitchen, bedroom and so on.\u003c\/span\u003e\u003c\/p\u003e\n\u003cdiv\u003e\u003cbr\u003e\u003c\/div\u003e\n\u003cp\u003e\u003cspan\u003e🔥 \u003c\/span\u003e\u003cspan\u003eWhen adjusting the color temperature, the color lamp beads will automatically turn off to get a more accurate color temperure that you want,which can experience the more delicate atmosphere lighting effect;\u003c\/span\u003e\u003c\/p\u003e\n\u003cdiv\u003e\u003cbr\u003e\u003c\/div\u003e\n\u003cp\u003e\u003cspan\u003e🔥 \u003c\/span\u003e\u003cspan\u003eWhen adjusting the brightness from 1% to 100% that you want, making a vibrant atmosphere anytime.\u003c\/span\u003e\u003c\/p\u003e\n\u003cdiv\u003e\u003cbr\u003e\u003c\/div\u003e\n\u003cp\u003e\u003cspan\u003e🔥 \u003c\/span\u003e\u003cspan\u003eControl ways:\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e① APP Control: Requires to zigbee gateway such as SmartThings, Tuya ect., support APP control in Android\/IOS Phone;\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e② Voice Control: support Amazon Alexa\/Google Home\/Homekit via zigbee hub;\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e③ Remote Control: support 2.4G RF remote control\/wall switch directly, without zigbee hub;\u003c\/span\u003e\u003c\/p\u003e\n\u003cdiv\u003e\u003cbr\u003e\u003c\/div\u003e\n\u003cp\u003e\u003cspan\u003e🔥 \u003c\/span\u003e\u003cspan\u003eGroup: Create rooms, divide your strip lights into one room( to control lights together) or several rooms(to control lights in different room separately).\u003c\/span\u003e\u003c\/p\u003e\n\u003cdiv\u003e\u003cbr\u003e\u003c\/div\u003e\n\u003cp\u003e\u003cspan\u003e🔥 \u003c\/span\u003e\u003cspan\u003eSet the Scene that can adjust the different lights atmosphere in your room according to your needs.\u003c\/span\u003e\u003c\/p\u003e\n\u003cdiv\u003e\u003cbr\u003e\u003c\/div\u003e\n\u003cp\u003e\u003cspan\u003e🔥 \u003c\/span\u003e\u003cspan\u003eCompatible With Zigbee Gateway: it's using with zigbee light link(ZLL) standard protocol, zigbee transmission technology, mesh, multi signal at the same to to transmit, receive, anti interference ability.\u003c\/span\u003e\u003c\/p\u003e\n\u003cdiv\u003e\u003cdiv\u003e\u003cdiv\u003e\n\u003cdiv\u003e\u003cdiv\u003e\u003cbr\u003e\u003c\/div\u003e\u003c\/div\u003e\n\u003cp\u003e\u003cspan\u003eQ\u0026amp;A or more info, please contact us on line, and we will answer you in time.\u003c\/span\u003e\u003c\/p\u003e\n\u003c\/div\u003e\u003c\/div\u003e\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/HTB1U2DCLIbpK1RjSZFyq6x_qFXa9.jpg\"\u003e\u003cspan\u003eProduct Name: Zigbee Utral Thin Mini 5 in 1 LED Controller\u003cbr\u003eModel No.: GL-C-002P\u003cbr\u003eProduct Size: 70*36*10mm\u003cbr\u003eInput Voltage: DC5-24V\u003cbr\u003eProtection Rate: IP20\u003cbr\u003eTotal Power: 144W Max\u003cbr\u003eOutput Current\/Channel: 3A Max\u003cbr\u003eTotal Output Current: 6A Max\u003cbr\u003eApplications: Suitable For DC5-24V LED Light Strip\u003c\/span\u003e\n\u003c\/div\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/HTB1jajZLNjaK1RjSZKzq6xVwXXaM.jpg\"\u003e\u003cspan\u003e1pcs* ZIGBEE Mini 5 in 1 LED Strip Controller\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e1pcs* User Manual\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e1pcs* 3cm Stricker\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e1pcs* Wiring Tool\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/HTB1SwHKLNjaK1RjSZFAq6zdLFXak.jpg\"\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/H34d8f6731e2a4efa89cfabc59b2c1e3bJ.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/He198e2ffa9394c3ca36653b2c1583222B.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/H7e9bfccdee8144908f3757c9616b3dfef.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/H3e0c0fa568da40528a67de4f94f6707fd.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/H83722fd0c27a4cde929ef71121992344Q.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Hb45560c257a5436aacaf698daa23c1f66.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/H520981d13fd747f28d58ec803573bc5eZ.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Hf3d69e40dd3543d18521be1d4df0ab10B.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Hff9cb159e6b74877abf47deb67445dd7i.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/H58a76b3798b347c0903438cc8bdaf08co.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/H6ce6065e6591493cb4a1a4b6fb613500y.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/H10df9ac4a85648da89b8eb538326a52ed.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/H743dba5b46894d8e874506d17f45a2deB.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/H9cf40598406a424ca9cde7d1a716894er.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Hcaef2eaf3c3143f2b5dd0eddea214019B.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/H68d4053f68e14269849c3bcf576e3e31h.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/U63cfee2fe7084c9fa530a6da3bcb68b9n.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Hefbca4d335a74efe975d51812b7d97e2P.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/H2d6a26c6bd2f455f8bafbebe12e460639.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/He96d82e477ff4a528df7fb8fd0b44794y.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/H72160ab7b2e14aea9bb8bd230fa2debdr.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/H990fda53067d4d12b2e64afbf15ea321L.jpg\"\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/H35c251c85b124da1ab10b8319cfd2670U.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Hd1e9c26d94784b538b9639ebd31914a8S.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/H03f7c0b3750241f9979733dae7492919p.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Ha9147414b13a4e659aa44c858742428aD.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/H4a577ce40bae4cc3bd5005642d79fcd1n.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sb3f101b5bdc54ba3be6ff58247a3602er.jpg\"\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/HTB1YNnILQvoK1RjSZFwq6AiCFXaq.jpg\"\u003e\u003c\/p\u003e\n\u003cdiv\u003e\u003cdiv\u003e\u003cp\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/HTB1DLAoGxWYBuNjy1zkq6xGGpXa9.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/HTB1m680vTXYBeNkHFrdq6AiuVXaM.jpg\"\u003e\u003c\/p\u003e\u003c\/div\u003e\u003c\/div\u003e\n\u003cp\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Haf12e4c1a6664b24b1d19d47813f2d92I.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/He92c9068b8a6465da1e4ff1a60f79930r.jpg\"\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003c\/div\u003e\u003c\/div\u003e\n\u003cdiv\u003e\u003ckse:widget\u003e\u003c\/kse:widget\u003e\u003c\/div\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003c\/div\u003e","brand":"Gledopto","offers":[{"title":"1Pc Mini 5 In 1 \/ 3A Per Channel","offer_id":53882185220389,"sku":"fd0fb760-d6f0-439f-95be-239b5dfb70c5","price":23.78,"currency_code":"USD","in_stock":true},{"title":"1Pc Mini 5 In 1 \/ 6A Per Channel","offer_id":53882185580837,"sku":"debb98b2-f754-4000-abb7-86f75a65acd8","price":24.61,"currency_code":"USD","in_stock":true},{"title":"2Pcs Mini 5 In 1 \/ 3A Per Channel","offer_id":53882185253157,"sku":"472a8643-ef7c-4d9f-b221-b4e1f9517527","price":30.76,"currency_code":"USD","in_stock":true},{"title":"2Pcs Mini 5 In 1 \/ 6A Per Channel","offer_id":53882185548069,"sku":"6820df72-61f0-4af2-95c5-5618ba929a5c","price":33.18,"currency_code":"USD","in_stock":true},{"title":"3Pcs Mini 5 In 1 \/ 3A Per Channel","offer_id":53882185285925,"sku":"9b8b4542-6298-4934-869e-051601479005","price":38.75,"currency_code":"USD","in_stock":true},{"title":"3Pcs Mini 5 In 1 \/ 6A Per Channel","offer_id":53882185515301,"sku":"ab64bd09-0c6f-406c-a7c1-e74f09626512","price":41.84,"currency_code":"USD","in_stock":true},{"title":"4Pcs Mini 5 In 1 \/ 3A Per Channel","offer_id":53882185318693,"sku":"cf752c49-4b35-4e21-8421-67ecbe4cdda4","price":46.37,"currency_code":"USD","in_stock":true},{"title":"4Pcs Mini 5 In 1 \/ 6A Per Channel","offer_id":53882185482533,"sku":"cfa8e46e-583b-4137-bd8c-5ecf2047ccac","price":50.41,"currency_code":"USD","in_stock":true},{"title":"5M Led Strip Ip20 \/ 3A Per Channel","offer_id":53882185384229,"sku":"f8d70444-eed6-4835-bb8f-2f469ea2b434","price":38.58,"currency_code":"USD","in_stock":true},{"title":"5M Led Strip Ip20 \/ 6A Per Channel","offer_id":53882185416997,"sku":"be20d617-b343-4a91-b4b6-c97230866ebc","price":38.58,"currency_code":"USD","in_stock":true},{"title":"5M Led Strip Ip65 \/ 3A Per Channel","offer_id":53882185449765,"sku":"5a81f8cf-ed1d-4d0f-8cb4-7a368a9d443f","price":44.62,"currency_code":"USD","in_stock":true},{"title":"5M Led Strip Ip65 \/ 6A Per Channel","offer_id":53882185351461,"sku":"d2e36c91-dbdb-4de1-b9bc-8e8352533e2d","price":44.62,"currency_code":"USD","in_stock":true}],"url":"https:\/\/www.ezlo.com\/products\/zigbee-3-0-smart-home-ultra-thin-mini-5-in-1-led-controller-work-with-tuya-smartthings-app-voice-rf-remote-control","provider":"Ezlo - Property Empowered","version":"1.0","type":"link"}
