{"product_id":"zigbee-smart-door-window-sensor-tuya-magnetic-detector-security-protection-open-closed-alarm-app-remote-works-with-alexa-google","title":"Zigbee Smart Door Window Sensor Tuya Magnetic Detector Security Protection Open Closed Alarm APP Remote Works with Alexa Google","description":"\u003cdiv\u003e\n\u003cp\u003e\u003cspan\u003e\u003cstrong\u003eNotice:\u003c\/strong\u003e\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e\u003cstrong\u003e1、This device only can work along with a Zigbee Geteway. You need to connect wifi with a zigbee gateway successfully before use such zigbee T\u0026amp;H sensor.\u003c\/strong\u003e\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e\u003cstrong\u003e2、Turn on the device and smart speaker (Alexa or Google Home speaker) , they will be connected automatically;\u003c\/strong\u003e\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e\u003cstrong\u003e3、The device is also compatible with eWeLink ZigBee Gateway Hub. If TUYA Smart is not available for the device, please connect it with the eWeLink ZigBee Gateway Hub.\u003c\/strong\u003e\u003c\/span\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S8ab88afb4e9443548aeefd030e2057508.jpg\"\u003e\u003cspan\u003e\u003cspan\u003e\u003cstrong\u003eSpecifications:\u003c\/strong\u003e\u003c\/span\u003e\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eAPP Name: Tuya Smart or Smart Life\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eBattery type: AAA1.5V*2 (Not include battery in shipment)\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eInput Voltage: DC3V LR03\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eQuiescent Current: ≤10uA\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eAlarm Current: ≤160mA\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eLow Power Undervoltage: ≤2.7V\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eMagnetic Control Distance: ≥15mm\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eWorking temperature: -10℃~50℃\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eWorking Humidity: max 95%RH\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eWireless Type: Zigbee\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003e\u003cspan\u003eZigBee Gateway Hub:Required\u003c\/span\u003e\u003c\/strong\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e\u003cstrong\u003eFeature:\u003c\/strong\u003e\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003e\u003cspan\u003e1.Ready-to-Go:\u003c\/span\u003e\u003c\/strong\u003e\u003cspan\u003eThe Tuya Smart Door Sensor is ready-to-go, meaning it can be easily installed without any complicated setup or configuration.\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003e\u003cspan\u003e2.Control Channels\u003c\/span\u003e\u003c\/strong\u003e\u003cspan\u003e: With 2 control channels, you can easily control the door sensor from your smartphone or tablet.\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003e\u003cspan\u003e3. Alarm Alert:\u003c\/span\u003e\u003c\/strong\u003e\u003cspan\u003eWheneverthe sensor is triggered to open\/close, it will send alarm to alert you that someone opens your door or window.\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003e\u003cspan\u003e4. Alarm Recording:\u003c\/span\u003e\u003c\/strong\u003e\u003cspan\u003eSupport checking open \/ close records and battery level on the app. Never worry about missing any important moments or running out of battery.\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003e\u003cspan\u003e5. Device Share:\u003c\/span\u003e\u003c\/strong\u003e\u003cspan\u003eSelect “Home Management” in the “Me” page to share your added sensors with family members. so that they can also monitor the status of doors\/windows.\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e\u003cstrong\u003e6.\u003c\/strong\u003e\u003c\/span\u003e\u003cspan\u003e\u003cstrong\u003e\u003cspan\u003eLow VoltageRemind:\u003c\/span\u003e\u003c\/strong\u003e\u003c\/span\u003e\u003cspan\u003eWhen battery level is low, it will automatically remind you to change batteries, never worry about running out of battery.\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003e\u003cspan\u003e7.Works with alexa and Google Assistant.\u003c\/span\u003e\u003c\/strong\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003e\u003cspan\u003e8.Enjoy Your Smart Life\u003c\/span\u003e\u003c\/strong\u003e\u003cspan\u003e:When you leave home, it will push notification message to you when the door\/window opens or closes, so you can discover the intruder in time. Furthermore, you could share the device to your family members and track the history of sensor activities.\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003e\u003cspan\u003e9.Easy to Install:\u003c\/span\u003e\u003c\/strong\u003e\u003cspan\u003eNo complicated installation tools are required. The sensor can be installed with double-sided adhesive tape or screws(included) in just a few steps, and download an app \"tuya\" or \"Smart Life\" from GooglePlay or App Store to add the device to detect the status of your door\/window.\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e\u003cstrong\u003epackage List\u003c\/strong\u003e\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e1xDoor Sensor (Not include battery)\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e1xUser Manual\u003c\/span\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S7d65d5dda9824b9081e44b538482868a9.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S97d0a7f86a954bfeb1c136ce5ff0e320P.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sdb0d7869292742c1a51b1d9a35ac6045C.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sc495c26a956540b19e06cba5ce6241b4y.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S4e8984bc0c684c3fa2e98c6172899929r.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sb976c7604b6345b0b3c6373f6079f835y.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sc80860f381f24fca97d6bc007eea72d6h.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S02edd332f884442ab1f5ab08d5691984Y.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S40736a56106f40e6a8d47226e0cad73bs.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sfa2aa21ff260422193fde543269e2bf6i.jpg\"\u003e\u003c\/p\u003e\n\u003c\/div\u003e","brand":"Ihseno","offers":[{"title":"Zigbee","offer_id":53899059069221,"sku":"ee4ec7c3-bf0e-41e8-ba85-8d5439f535b7","price":15.31,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0771\/4632\/5285\/files\/Sa654517659eb405b9cdac0690b685793k.webp?v=1790322299","url":"https:\/\/www.ezlo.com\/products\/zigbee-smart-door-window-sensor-tuya-magnetic-detector-security-protection-open-closed-alarm-app-remote-works-with-alexa-google","provider":"Ezlo - Property Empowered","version":"1.0","type":"link"}
