{"product_id":"zigbee-tempearture-humidity-sensor-with-probe-temp-optional-7-in-1-water-quality-monitor-tds-ec-sg-salinity-meter-compatible-z2m","title":"Zigbee Tempearture\u0026Humidity Sensor with Probe Temp Optional 7 in 1 Water Quality Monitor TDS EC SG Salinity Meter Compatible Z2M","description":"\u003cdiv\u003e\n\u003cp\u003e\u003cspan\u003ePlatform Compatibility: It currently supports and only works with Zigbee2MQTT through Home Assistant. A compatible Zigbee gateway is required for normal operation.\u003c\/span\u003e\u003cbr\u003e\u003cspan\u003eNOT compatible with Smart Life, Tuya App, eWeLink App, or not work with Zigbee Home Automation (ZHA) at this time.\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e3-In-1:\u003c\/p\u003e\n\u003cp\u003eModel:ZG-105NTH\u003c\/p\u003e\n\u003cp\u003eItem: Zigbee Temperature and Humidity Sensor with temperature probe\u003c\/p\u003e\n\u003cp\u003eDetection Range:Air Temperature,Air Humidty,Probe Temperature\u003cbr\u003eWireless: Zigbee 3.0(need zigbee gateway)\u003cbr\u003eBattery:LR03(AAA) x2 (Not included battery)\u003cbr\u003eProbe Cable Length: 1M\u003cbr\u003eProbe Material:304 stainless steel\u003cbr\u003eProbe Measure Range:-40℃~120℃\u003cbr\u003eOperating Air Temperature:-10°C~60°C\u003cbr\u003eOperating Humidity :0%RH~99%RH\u003cbr\u003eTemperature Resolution :0.1 °C\u003cbr\u003eHumidity Resolution: 0.1%\u003c\/p\u003e\n\u003cp\u003eSize:70*24.5*20mm\u003c\/p\u003e\n\u003cp\u003eProbe length: 1 meter\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e6-In-1:\u003c\/p\u003e\n\u003cp\u003eModel:ZG-101TDS\u003c\/p\u003e\n\u003cp\u003eFeature:Hydroponic and Freshwater High Precision Edition\u003c\/p\u003e\n\u003cp\u003eDetection Range:TDS, Salinity, EC, Water(liquid) Probe Temperpature, Air Temperature,and Air Humidity\u003c\/p\u003e\n\u003cp\u003eProduct Name:Multi-Parameter Water Quality Monitor\u003cbr\u003eWireless Protocol: Zigbee\u003cbr\u003eWorking Voltage: DC3V\u003cbr\u003eBattery Type:LR03-1.5V\/AAA*2 (Not included battery)\u003cbr\u003eStandby Current:≤20uA\u003cbr\u003eProbe Measure Range:0℃~60℃\u003c\/p\u003e\n\u003cp\u003eOperating Temperature: 10℃~60℃\u003cbr\u003eOperating Humidity:0%~99%RH\u003c\/p\u003e\n\u003cp\u003eEC:0~2000μS\/cm,±1%FS\u003cbr\u003eTDS:0~999ppm±1%FS\u003cbr\u003eSalinty:0.0~2.0%,±1%FS\u003c\/p\u003e\n\u003cp\u003eSize:70*24.5*20mm\u003c\/p\u003e\n\u003cp\u003eProbe length: 1 meter\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e7-In-1:\u003c\/p\u003e\n\u003cp\u003eModel:ZG-109TDS\u003c\/p\u003e\n\u003cp\u003eFeature:Dual mode version of seawater and freshwater\u003c\/p\u003e\n\u003cp\u003eDetection Range:TDS, EC (Electrical Conductivity), Salinity, SG (Specific Gravity), Water(liquid) Probe Temperature, Air Temperature, and Air Humidity.\u003c\/p\u003e\n\u003cp\u003e-Dual Mode Optional : Easily switch between Freshwater Mode (Aquariums, Hydroponics, Drinking water) and Seawater Mode (Marine tanks). (Note: Mode must be selected manually).\u003cbr\u003eProduct Name:Multi-Parameter Water Quality\u003cbr\u003eMonitorWireless Protocol: Zigbee\u003cbr\u003eWorking Voltage: DC3V\u003cbr\u003eBattery Type:LR03-1.5V\/AAA*2 (Not included battery)\u003cbr\u003eStandby Current:≤20uA\u003cbr\u003eProbe Measure Range:0℃~60℃\u003cbr\u003eOperating Temperature:10℃~60℃\u003cbr\u003eOperating Humidity:0%~99%RH\u003c\/p\u003e\n\u003cp\u003eEC:0~20000 μs\/cm,±2%FS\u003cbr\u003eTDS:0~13000 ppm ±2%FS\u003cbr\u003eSalinty:0.0~50.0%，±2%FS\u003cbr\u003eSG:1.000~1.050,±0.001\u003c\/p\u003e\n\u003cp\u003eSize:70*24.5*20mm\u003c\/p\u003e\n\u003cp\u003eProbe length: 1 meter\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e--Remote Monitoring \u0026amp; Historical Data TrackingWireless Remotely Monitoring. The system supports data recording and remote tracking, allowing you to review historical trends, set threshold warnings for abnormal levels, and receive smart alerts directly through your home assistant zigbee2mqtt dashboard.\u003cbr\u003e--Ultra-Low Power ConsumptionLong-lasting battery life: Adopting Zigbee 3.0 low-power technology, data is reported every 10 minutes by default, saving power and making it more worry free.\u003cbr\u003e--Widely Application ScenariosTailored for small closed-loop water circulation systems, this sensor is widely applicable to household freshwater aquariums, saltwater marine fish tanks, indoor hydroponic planting systems and other scenarios. It provides precise and stable water quality monitoring for family aquatic breeding and soilless cultivation.\u003cbr\u003eImportant note: Not applicable to swimming pools, large outdoor ponds, industrial wastewater treatment systems and other large-scale water environments.\u003cbr\u003e--Battery Not Included\u003cbr\u003eThe sensor is powered by 2pcs LR03 1.5V batteries. Batteries are not contained in the package and need to be prepared by users independently.\u003cbr\u003e--Smart Water Quality Management for a Healthier Aquatic Ecosystem\u003cbr\u003eMonitor, track and optimize your water environment with precise smart sensing technology. Choose the right version for your smart home system and enjoy effortless, professional water quality control all year round!\u003cbr\u003e--Must read before purchasing (please make sure to confirm before placing an order)\u003cbr\u003eSystem compatibility (extremely important): Currently, this product only supports connection through Home Assistant (Zigbee 2MQTT\/Z2M). Tuya, Smart Life, eWeLink, and ZHA systems are currently not supported.\u003cbr\u003eGateway requirements: This device cannot be directly connected to the internet and must be used with a compatible Zigbee 2MQTT gateway\/coordinator (to be prepared or purchased separately).\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S8a2ca89e48a44a84b571db11b6bafa780.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/Sbf4a73e2d0d1456f9315f0976c7ed76bX.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S080d18bf34e445f6a9f2bb8d67a2aeacr.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S227a0a389d1c4626ba951154595aacafa.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S3095c668d01842218aabe41ad1df886bz.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S5115df6ce59d484fa2af0b684a726854K.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/Sb98d0713778746dab43512a4c9d25032k.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/Secbc880258d8442db3b195f00627d033W.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/Sdf136683dc684273a1fa4744e415b5d16.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/Sad896c2cd65244b2ad2bd54983153fdaE.jpg\"\u003e\u003c\/p\u003e\n\u003c\/div\u003e","brand":"Excellux","offers":[{"title":"3 In 1","offer_id":54440044855589,"sku":"f15faccd-9427-4df1-acfd-3df290518eb8","price":10.79,"currency_code":"USD","in_stock":true},{"title":"7 In 1","offer_id":54440044888357,"sku":"a6aab214-ee22-45d2-b223-49a2547fadc5","price":42.22,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0771\/4632\/5285\/files\/S0fde6bab610c416bb90e5a2ea0878afae.webp?v=1794299883","url":"https:\/\/www.ezlo.com\/products\/zigbee-tempearture-humidity-sensor-with-probe-temp-optional-7-in-1-water-quality-monitor-tds-ec-sg-salinity-meter-compatible-z2m","provider":"Ezlo - Property Empowered","version":"1.0","type":"link"}
