{"product_id":"zigbee-wifi-smart-garage-door-opener-dc5v-with-door-magnet-433mhz-rf-wireless-controller-work-with-tuya-alexa-google-home","title":"Zigbee Wifi Smart Garage Door Opener DC5V with Door Magnet 433Mhz RF Wireless Controller Work with Tuya Alexa Google Home","description":"\u003cdiv\u003e\n\u003cdiv\u003e\n\u003cp\u003eYou may encounter these problem\u003c\/p\u003e\n\u003cp\u003eDo you always drive to work and forget to close the door?\u003cbr\u003e\u003cbr\u003eYour kid forgot to bring his keys when he went out to play\u003cbr\u003e\u003cbr\u003eThere is a courier and you need to go downstairs by yourself\u003cbr\u003e\u003cbr\u003eThere's a party at home, a friend is driving, and you need to go downstairs to open the garage door\u003cbr\u003e\u003cbr\u003eIf you run into these problems regularly, you need a smart switch like this to control your garage door\u003cbr\u003e\u003cbr\u003eAre you tired of the inconvenience of traditional switches？then you need such a smart switch.Make your life smarter and more relaxed\u003c\/p\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eChecklist before using the device\u003c\/p\u003e\n\u003cp\u003eYou need to have a Zigbee gateway ZIGBEE HUB.\u003cbr\u003eTry to be close to the Zigbee gateway when pairing.\u003cbr\u003eIt can not connect directly to a WiFi network\u003c\/p\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/Se461704fe2194fd39ffbf7036b2b1228q.jpg\"\u003e\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eNote before Order, please test compatibility\u003c\/p\u003e\n\u003cp\u003ePlease check if your garage controller is compatible with our module.\u003cbr\u003e\u003cbr\u003eTake a wire with both ends stripped or a straightened-out paper clip to short-circuit the wall button terminal on the opener (I marked with red color). If the garage door opens or closes, it can work with our smart controller.\u003c\/p\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S0c3054f17dfd4f92995d3e68d6e8784b3.jpg\"\u003e\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eGarage door opener controller features:\u003c\/p\u003e\n\u003cp\u003eZIGBEE Smart Garage Door Controller and Garage Open Close Monitor Compatible With Alexa Echo , Google Home voice control No Hub Require\u003cbr\u003e\u003cbr\u003eREMOTE MONITORING: You can open or close the door by the APP. You can check the garage door open or closed state in real time. You can authorize multiple people to access your garage. \u003cbr\u003e\u003cbr\u003eEASY TO USE: Instantly control the garage door by tapping the TUYA or SMART LIFE app on your smartphone. Just connect the smart opener to the 2.4G WiFi network.\u003cbr\u003e\u003cbr\u003eVOICE CONTROL: You can activate your garage door opener by placing a voice command to your Alexa or Google Assistant device or driving near the garage door \u003cbr\u003e\u003cbr\u003eWIDE COMPATIBILITY: You can only use one controller per garage door opener. Compatible with most general garage door openers.Please check the our list.\u003cbr\u003e\u003cbr\u003eTIMER FUNCTION: You can set schedules to open and close your garage door. Quick \u0026amp; easy installation as well without the need of a professional. No Hidden Mon\u003cbr\u003e\u003cbr\u003eCOUNTDONW FUNCTION: You can set the countdown time to close or open the garage door.\u003c\/p\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S29642ac25ed14b04baea970fe3f27c73T.jpg\"\u003e\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eRemote control via RF and WIFI\u003c\/p\u003e\n\u003cp\u003eControl your home curtains anytime,anywhere\u003c\/p\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S9290940ab2c2415d9650382da1eecbf2u.jpg\"\u003e\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eReal-time door opening and closing display\u003c\/p\u003e\n\u003cp\u003eYou need to have a Zigbee gateway ZIGBEE HUB.\u003cbr\u003eTry to be close to the Zigbee gateway when pairing.\u003cbr\u003eIt can not connect directly to a WiFi network\u003c\/p\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S21874eaf0920480f9041b9ccd91510013.jpg\"\u003e\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eTiming Function\u003c\/p\u003e\n\u003cp\u003eyou can the time to turn on lights and turn on the fans in the office\u003c\/p\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/Sa53279d8f00548fbb4cbb2c7156904edl.jpg\"\u003e\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eFamily Sharing\u003c\/p\u003e\n\u003cp\u003eShare the control with family member.Enjoy the convenience and happiness together\u003c\/p\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S5db76b9ab58b486493585ebe6d120011Z.jpg\"\u003e\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eHands-Free Voice Control\u003c\/p\u003e\n\u003cp\u003eCompatible with Alexa \u0026amp; Google Home,the smart switch allows you to control lights on\/off with your voice\u003c\/p\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S14fab5d8e4614969b34f81880cc27d71U.jpg\"\u003e\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eEasy to install\u003c\/p\u003e\n\u003cp\u003eJust aked you connnect the red \u0026amp; black wire with the same port as your wall switch\/consloe .and Install the wired door sensor on your garage door\u003c\/p\u003e\n\u003cdiv\u003e\n\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/Saf608c5c0abb498d9a40e3a813b17838b.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S478df5d9367b4cf6bfb1ce382a5a537a5.jpg\"\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eWired door sensor mount\u003c\/p\u003e\n\u003cp\u003eFind a proper position on the garage door to mount the sensor(You can use the included double-sided adhesive tapes, screws or brackets\u003cbr\u003e for sensor fixation). Please make sure the distance between the two sensors is less than 20mm when the garage door is closed, and the two sensors are well separated when the garage door is open.\u003c\/p\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/Saace375de37c418cbbaa3b39c7ba546fD.jpg\"\u003e\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003eWith door sensor\u003c\/p\u003e\n\u003cdiv\u003e\n\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S7b9ec709513c4d0a947ddb3ce757a00bD.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S9dee72354dbd4ea4bf47a2541392cc65f.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S835e169d3295438582cc90b7cfdf7f27j.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/Sc1c0942479664573a608dbbf35122f43k.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S7fabd75dcd59454892c905e561159dc20.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/See49b9fed96048f3a5d376739bdaec1cT.jpg\"\u003e\u003cimg src=\"https:\/\/ae-pic-a1.aliexpress-media.com\/kf\/S7a3db7b6a1204288b74c3eb41427ae0dD.jpg\"\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003c\/div\u003e","brand":"Garage Tech Pro","offers":[{"title":"Zigbee Switch","offer_id":53726813421861,"sku":"362a1ef0-2983-4354-a0aa-932a70255999","price":53.99,"currency_code":"USD","in_stock":true},{"title":"Zigbee Switch Rf","offer_id":53726813454629,"sku":"693e8b7e-2bbe-4340-946b-dc5a9459acbe","price":60.91,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0771\/4632\/5285\/files\/S7fabd75dcd59454892c905e561159dc20.webp?v=1788345611","url":"https:\/\/www.ezlo.com\/products\/zigbee-wifi-smart-garage-door-opener-dc5v-with-door-magnet-433mhz-rf-wireless-controller-work-with-tuya-alexa-google-home","provider":"Ezlo - Property Empowered","version":"1.0","type":"link"}
