Devices to Include in Your Home Alarm Automation System
In old science fiction movies, we often hear the phrase “Intruder Alert!” being repeated by virtual assistants whenever someone bypasses a main character’s safe haven. But, security features like this isn’t just a thing on sci-fi movies anymore, you can now incorporate this technology on your home and have a home alarm automation system of your own.
A home alarm automation system is made up of various devices. The role of each device is to counter every known threat to home security. Read on to find out what these devices are and their roles in home alarm automation system.
Motion Sensors in Your Home Alarm Automation System
Motion sensors are one of the most essential devices in a home alarm automation system. They could trigger the alarm when it detects movements it did not recognize.
Motion sensors are also powerful devices in a home alarm automation system. Some models of motion sensors could detect any movement as far as 12 meters away!
Motion sensors are also usually hidden in any burglar’s plain sight. So, once it triggers the alarm, the burglar would panic.
Even the movements of homeowners could be detected by motion sensors. So, home owners have to disalarm the home alarm automation system first. They could do so by typing a security code in a keypad. Such a set up are common in home security system packages.
Smoke Detectors in Your Home Alarm Automation System
Burglars might be your reason in setting up a home alarm automation system. But, there are other threats to your property that you should mind too, such as are fires.
Back in 2017, there had been over 1.3 million cases of fires in the United States. And that number costed $23 billion in damages. A prevalent use of a home alarm automation system could help reduce this number.
But how?
Smoke detectors could be integrated in your home alarm automation system. There are home security system packages that include smoke detectors.
Smoke detectors could help you prevent any fire from getting big. These devices can do this by detecting the most subtle warning of a fire which is the smoke.
Some smoke detectors are even equipped with heat detecting system as well. It detects excessive heat and warns you with an alarm once it detects one.
Carbon Monoxide Detectors in Your Home Alarm Automation System
Carbon monoxide detectors are not as popular as smoke detectors, but it is also important to include them in your home alarm automation system. Like residential fires, carbon monoxide is also deadly. More than 400 people die in the United States every year as a result of exposure to carbon monoxide. This is according to the US Centers for Disease Control and Prevention.
These deaths are usually caused by car engines left open to heat up in the garage. The continuous combustion of the engine creates carbon monoxide. Carbon monoxide is odorless and colorless. There is virtually no way a person could detect it with their bare senses. But, carbon monoxide detectors could.
Door and Window Sensors in Your Home Alarm Automation System
Door and window sensors could also be added to your home alarm automation system. They could be important devices too in securing your home.
These devices are put on doors and windows. A closed circuit is formed by these devices when the doors and windows are closed. The circuit breaks, though, when the doors and windows are open. This will trigger the alarm.
Doors and windows are possible entry points in your home, so make sure to secure them. Locking these entry points would already tighten your security. But adding sensors to them would step up your home alarm automation system.
Glass Break Detectors in Your Home Alarm Automation System
Some burglars enter homes through an unlocked door or window. In fact, 30% of them do. But, some save themselves time and just break the window glass instead.
The glass parts of your home are known weak points. Just a little force are enough to break them.
Windows are not the only parts of your house that is usually made of glass. You could have a glass sliding door leading to the backyard.
So, how will you make them secure if they are also some of the weakest points in your house?
You can add security to them by installing glass break detectors near them. These devices could sense the sound of shattering glass and trigger the alarm when it senses one. They could be valuable addition to your home alarm automation system.
Sirens in Your Home Alarm Automation System
Of course, all your sensors and detectors are useless without a decent alarm. Sirens are an essential feature in a home alarm automation system.
Some models of sirens could have five different alert tones. The alert tones depend on what detector or sensor triggered it. This makes your home alarm automation system centralized and organized.
Some good models of sirens could also emit noise that could be as loud as 106 dB. Anyone who would hear it would be alarmed himself or herself. This will encourage immediate action to anyone who hears it. Any burglar would also get panicked when he or she hears it.
Threats to your safety are everywhere. And this is one of the reasons why the home automation movement sprang. It aims to give homeowners a sense of security in their own homes.
Are you planning of building your own home alarm automation system? You could call Vera Control at +1 (866) 966-2272 and we are willing help you with it. You may also reach us at info@getvera.com.
See Also
How to Use a Smart Key
Home Automation Security System
Shop Alarm System
Rating LoaderLoading...
