Features a Home Automation Security System Must Have
Home automation is a rapidly growing industry. Allied Market Research reported that it will earn $81.65 billion by 2023. Businessmen find the industry profitable. So, home automation service providers are being created every now and then. So, how would you know that you are getting the best home automation security system?
Here are some insights about what are the features of the best home security system.
A Home Automation Security System Must Be Environment-friendly
Today, there is ever-worsening global warming. Large chunks of ice are seen floating away from the poles. The melting of these ice chunks could cause sea-level rises. And we will have hotter and hotter summers.
Nowadays, it is our duty to make a lesser environmental impact. Thus, we should make our home automation security system as environment-friendly as possible.
The average American household emits 7.5 tons of carbon dioxide into the atmosphere per year. Over 23,000 pounds of carbon dioxide are produced by heat from electricity.
Creating less environmental impact is one of the concerns of the smart home movement. That is why light bulbs that use less electricity is a common sight among smart homes. Creating a lesser carbon footprint is also the feature of a smart thermostat.
Being environment-friendly must also be looked for in a home automation security system. I mean, what’s the use of protecting ourselves when we can’t even protect our own planet?
The best home automation system is one that creates less environmental impact.
A Home Automation Security System Must Enable DIY Installation
When you hire a home automation security system provider, they will give you tips on how to run security. Their job falls mostly on giving advice only. Their job should stop there though.
The home automation security system provider can’t just tell you everything you had to do. That is because you need room to personalize your home. It’s your own home anyway.
So, find a home automation security system that can be installed in a do-it-yourself way. The automatic lock must be easily installed so you could install it anywhere you want. Same with other smart devices such as motion sensors and security cameras.
Personalization is not just the reason why you need DIY installation. No one knows your home more than you do. So only you know better where to put these smart devices better.
For example, you need to install security cameras. Only you know the best spots in your home to install a camera.
A Home Automation Security System Must Be Energy-Efficient
Perks of an energy-efficient home automation security system is more than being environment-friendly. An energy-efficient home automation system also helps you cut down bills.
On average, Americans pay a total of $104 per month for their electricity bills. That means that Americans pay more than $1,200 for electricity bills per year. You can have an idea of how much electricity a typical American uses every month.
Energy-efficiency is one of the things that a smart home movement wants to maximize. A home automation security system must be energy-efficiency. This is one of the features you should look for. You will always find this feature in the best home security system.
For example, some motion sensors operate on a battery that could last for a whole year!
A Home Automation Security System Must Be Responsive
One of the main reasons for installing a home automation security system is to keep burglars out. Home security systems across the world are built to fight burglary.
Even if not the best home security system, your system must still be responsive in times of burglary. What is the use of home security systems if it can’t be responsive in burglary anyway?
Thankfully, devices in a home automation security system is not ordinary. They are smart devices after all.
For example, the motion sensor in one of the most active parts of a home automation security system. It detects movement that it does not recognize. It will then report it to your home automation security system. The system then will report it back to you.
When you’re finding a home automation security system, simply look for the best.
A Home Automation Security System Must Be Threat-Proof
What else could be a mortal enemy of the home automation security system other than burglars? Physical property isn’t just the only thing that could be stolen from you. Your own privacy can also be taken away from you by bad elements.
Hackers are quite experts in finding loopholes in systems. They exploit these loopholes to take your data. Once your data has been taken, they could turn them against you.
One type of malware called ransomware takes hold of your data and hide it from you. It will only give your data back if you pay for a certain price. Experts warn that a similar scheme could be done by hackers to smart buildings.
For example, security cameras nowadays are connected to the internet. Hackers could find loopholes in your security camera system and hack it. They could then use the camera to invade your privacy.
But, don’t worry, such attacks are not that too prevalent. Yet, You should find a home automation security system that resists cyber threats.
Looking for the best home automation security system? We could give you expert insights on how to built your very own home security system. If you’re ready, give us a call at +1 (866) 966-2272. You may also send us your word at info@getvera.com.
Related Resource:
Best Home Automation System
