The idea of living in a smart home is alluring. Everything or most of the things in your house will be automated. But, careful planning is an ingredient in how to create a smart home system.
How to build a smart home system is like building the house itself. There should be careful planning and consideration. There are steps you should follow to be able to build one.
How to Create a Smart Home System Step #1 — Identify the Problem
As has already been said, careful planning is an important part of how to build a smart home system. Nobody builds a smart home for no reason. A significant amount of effort and resources are needed to create a rigid smart home system.
A homeowner should first define why he or she wants to build a smart home. He or she should be able to identify the problems that he or she encounters in-home living. All problems should be addressed, no matter how big or small they are.
By doing so, he or she could figure out how to create a smart home correctly. The plan of the smart should be designed in a way that corresponds to the problems.
Common problems that households encounter concerned security and energy issues. Burglary is still a huge problem in some states. Authorities may have tried their best in keeping neighborhoods from burglars. But, they may have to ask for your help in doing so.
Small problems such as leaving the lights on are trivial. But, they could make a significant impact if done routinely or collectively.
Thus, identifying the problems you encounter in your home is part of how to create a smart home system. Doing so would help you design a plan for your smart home.
How to Create a Smart Home System Step #2 — Choose Devices
You have identified your everyday problems at home. Now, you have to design a plan for your smart home to deal with these problems. This is the next step in how to create a smart home system.
Planning a smart home involves choosing smart devices that will make up the system. Each smart device has a role in a smart home system. It corresponds to a specific problem. For this reason, it is important to identify your problems before choosing devices. Here are some smart devices and their uses in the smart home system:
- Camera in How to Create a Smart Home System. Security cameras provide surveillance for your home. There are camera models designed for outside and inside surveillance. Even the mere presence of a camera could scare off burglars away from your home.
- Motion Sensor in How to Create a Smart Home System. The motion sensor could detect motion even as far as 12 meters from the device in some models. It could detect unrecognized movements and alert your security. It could also be used to automate other devices.
- Thermostat in How to Create a Smart Home System. Thermostats are important in smart homes, especially in colder parts of the country. These devices could help you regulate your home’s heating, as well as the energy used to produce heat.
- Smart Lock in How to Create a Smart Home System. Smart locks are a step up of your ordinary mechanical lock. You could lock and unlock it remotely using an application or passcode. A lot of smart lock models are keyless. Thus, this device cuts down cases of losing or forgetting keys.
- Fire Alarm in How to Create a Smart Home System. Fire alarms could either be smoke detectors or heat detectors or even both. They could detect smoke or excess heat that could be an indication of a fire. It would alert you once it detects one to prevent any huge fire breaking out.
How to Create a Smart Home System Step #3 — Choose the Means of Control
Now, you have your smart home plan. It is now time for you to move into the next step of how to create a smart home system. And that is finding a way to control things around. Below are some of the ways you could control your smart devices. You could use one of them or integrate them all into your home.
- Virtual Assistant in How to Create a Smart Home System. Virtual assistants could direct tasks to your smart devices by commanding them so. Virtual assistants are gaining popularity among smart homeowners. Examples of virtual assistants include Amazon Alexa and Google Assistant.
- Application in How to Create a Smart Home System. Some smart devices and the smart home package comes with an application. The app allows you to control your smart home using your home. One such example is Vera Control’s VeraMobile™.
How to Create a Smart Home System Step #4 — Installation
Now, that you have designed your smart home, you can install your devices. Make sure that you the places and the devices go well. Some parts of your home may allow little signal to pass through. Watch out for these spots. You may alter some of your plans as upon installation. But, trial and error are in the vocabulary of how to create a smart home system.
See Also
