Zigbee 3.0 device — pairs with any Zigbee 3.0 hub or gateway
Centralite Zigbee 3.0 Rechargeable Motion Sensor CLZ-3370-C
Stop a $5,000+ burglary
before it happens
Effortless Device Control
Voice Control via an application
Connectivity with Multiple Radio Frequencies and Devices
Seamless Automation with MeshBots via MiOS
Built-In Rechargeable Battery: Charge only with a standard 5V Micro-USB charger. Do not puncture, disassemble, or expose the device to fire or extreme heat
Indoor Use Only: Designed for indoor environments within 14°F – 120°F and non-condensing humidity. Keep away from water and direct sunlight
Looking for the full installation manual? A detailed step-by-step setup guide for the Centralite Motion Sensor (CLZ-3370-C) is available in our Support Center.
Enhances home security through advanced infrared detection, offering real-time alerts via the MiOS app and seamless integration with Home Assistant for powerful smart home automation
Advanced Motion Detection
The Centralite CLZ-3370-C uses infrared technology and reliable Zigbee 3.0 to track human and animal movement, effortlessly enhancing your home security
Smart Home Automation
Compatible with major hubs, this sensor turns motion into action. Easily connect it with other smart devices to trigger custom scenarios like turning on lights
Real-Time MiOS App Alerts
Monitor your home from anywhere via the MiOS app for iOS and Android. Its user-friendly interface sends instant, real-time alerts straight to your smartphone
Home Assistant Ready
For ultimate flexibility, the sensor fully integrates with Home Assistant. This enables deep-dive, complex automations and complete control over your smart ecosystem
The Centralite Motion Sensor
The Centralite Motion Sensor CLZ-3370-C uses infrared sensors to detect movement and works in conjunction with smart home hubs which enables smart home automation and app alerts
Motion Detection
Uses infrared sensors to detect movement of people or animals
Enables automation and app alerts for enhanced security
Easy Pairing
Pairs with the MiOS mobile app and other Zigbee hubs
Zigbee 3.0 Connectivity
Integrates seamlessly with Zigbee-compatible smart home hubs
Includes a 3.7V 500 mAh Micro-USB charging port
Flexible Placement
Compact design with adhesive mounting for easy installation
Works With Your Smart Home
The Centralite CLZ-3370-C is a Zigbee 3.0 certified sensor — it plugs straight into the smart home you already have
Home Assistant ReadyIntegrates via any Zigbee coordinator for advanced local automations and complete control
Zigbee 3.0 CertifiedPairs with Ezlo hubs and hundreds of certified Zigbee controllers and devices
MiOS App ControlPair, configure, and get instant motion alerts from your iPhone or Android in minutes
Frequently Asked Questions
A: Yes. The CLZ-3370-C is a Zigbee 3.0 device, so it needs a Zigbee-compatible hub. It pairs seamlessly with Ezlo hubs (like Ezlo Plus) and other major Zigbee controllers
A: Yes. As a standard Zigbee 3.0 sensor it works with Home Assistant through any supported Zigbee coordinator, enabling advanced local automations and full control of your smart home ecosystem
A: The sensor has a built-in 3.7V 500 mAh rechargeable battery with a standard Micro-USB charging port — no battery replacements needed. Just plug it into any 5V USB charger
A: Anywhere indoors. The compact design mounts on any flat surface with the included adhesive — hallways, entryways, and corners work best. Detection reaches 19–26 feet with a 110° angle
A: Yes. With an Ezlo hub your motion-triggered automations run locally, so scenes like turning on lights keep working even during an internet outage. Only remote notifications require connectivity
A: We prioritize data sovereignty. Ezlo devices utilize a US-Based Cloud — your data remains secure and is hosted entirely on compliant servers within the United States
A: We are here to help! For any additional questions or technical assistance, please contact our customer care team at 866-966-2272 or email us at support@ezlo.com
Frequently Bought Together
Trusted Around the World
What's New at Ezlo
