31 Sensors already found their owners
See the difference
Ezlo Other Brands
Local Automation
Yes No
Works Offline
Yes No
Multi-Device Automations
Yes Limited
No Subscriptions
Yes No
Door/Window SensorCentralite · Model CLZ-3372-C
Prevent $5,000+
burglary before it happens
$19.95
  • Free shipping over $50
Bundle DealsIn Stock
1 pack
$19.95
SAVE 15%
3 packs
$50.50
SAVE 20%
5 packs
$78.95
  • Effortless Device Control
  • Voice Control via an application
  • Connectivity with Multiple Radio Frequencies and Devices
  • Seamless Automation with MeshBots via MiOS
Model Number
CLZ-3372-C
Battery Specifications
Replaceable CR2032 coin cell battery
Operating temperature
14°F – 120°F
Operating humidity
10% – 90% RH (no condensation)
Environment
Indoor use only — keep away from water and direct sunlight
Wireless Connectivity
ZigBee 3.0
Compatibility
Pair with Ezlo hubs or any compatible Zigbee hub
Installation
Mount on door or window, align magnet with the sensor at no more than ½ inch away
FCCCERoHSZigbeeULWEEE
Centralite Door/Window Entry Sensor — quick FAQ
Coin Cell Battery: Contains a replaceable CR2032 coin cell battery. Keep batteries away from children — if swallowed, seek immediate medical attention. Do not puncture, disassemble, or expose the device to fire or extreme heat
Looking for the full installation manual? A detailed step-by-step setup guide for the Centralite Door/Window Entry Sensor (CLZ-3372-C) is available in our Support Center.
Open the Installation Manual
Centralite
Secure your home with the CLZ-3372-C, a Zigbee 3.0 wireless sensor that alerts you when doors or windows are opened
Door & Window Security
Detects the opening and closing of doors and windows using a magnetic alignment setup for effortless home monitoring
Smart Home Automation
Uses Zigbee 3.0 connectivity to work seamlessly with smart hubs, triggering custom automated scenarios based on door/window events
MiOS App Control
Remotely monitor and manage your home from anywhere using the intuitive MiOS app, designed for easy automation and real-time tracking on iOS and Android devices
Home Assistant Ready
Integrate effortlessly with Home Assistant to unlock powerful, deep-dive automations and custom smart home routines across your entire ecosystem
Centralite Door/Window Entry Sensor on a window frame
The Centralite CLZ-3372-C Door/Window Sensor tracks every open and close event to keep your home secure. Connect it to your smart home hub to trigger instant app alerts and automated routines the moment a door or window opens
Instant Door/Window Detection
Provides immediate alerts when a door or window is opened
Smart Home Security
Enables app alerts and automation for security enhancement
Compact Design
Discreet and fits seamlessly into any home decor
Zigbee 3.0 Connectivity
Easily connects with Zigbee-compatible hubs
Wide Compatibility
Works with Ezlo and other Zigbee-compatible smart home hubs
Easy Installation
Simple mounting on doors or windows
Works With Your Smart Home
The Centralite CLZ-3372-C is a Zigbee 3.0 certified sensor — it plugs straight into the smart home you already have
Home Assistant ReadyIntegrates via any Zigbee coordinator for advanced local automations and complete control
Zigbee 3.0 CertifiedPairs with Ezlo hubs and hundreds of certified Zigbee controllers and devices
MiOS App ControlPair, configure, and get instant door/window alerts from your iPhone or Android in minutes
Instant Notifications Instant Notifications
Stay informed about any doors or windows left open by mistake. The Centralite Door/Window Entry Sensor sends real-time alerts directly to your smartphone
Everything Under Control Everything Under Control
Protect your medicine cabinet, toolbox, or any storage containing hazardous items. If they are opened, Ezlo app will notify you instantly
Automatic Light Control Automatic Light Control
The Centralite Door/Window Entry Sensor is ideal for spaces where lights need to turn off when a door closes. After a set period of time, it will automatically switch the lights off
Frequently Asked Questions
Q: Do I need a hub to use this sensor?
A: Yes. The CLZ-3372-C is a Zigbee 3.0 device, so it needs a Zigbee-compatible hub. It pairs seamlessly with Ezlo hubs (like Ezlo Plus) and other major Zigbee controllers.
Q: Is it compatible with Home Assistant?
A: Yes. As a standard Zigbee 3.0 sensor it works with Home Assistant through any supported Zigbee coordinator, enabling advanced local automations and full control of your smart home ecosystem.
Q: What battery does it use and how do I pair it?
A: The sensor runs on a standard replaceable CR2032 coin cell battery. To pair it, pull the battery tab or hold the reset/pairing button for 5 seconds, then follow the MiOS app instructions.
Q: How do I install it on a door or window?
A: Mount the sensor on the frame and the magnet on the moving part using the included adhesive, keeping them within ½ inch of each other when closed. Make sure the magnet sits on the side of the alignment mark.
Q: Will my automations work if the internet goes down?
A: Yes. With an Ezlo hub your door/window-triggered automations run locally, so scenes like turning on lights keep working even during an internet outage. Only remote notifications require connectivity.
Q: How is my data and privacy protected?
A: We prioritize data sovereignty. Ezlo devices utilize a US-Based Cloud — your data remains secure and is hosted entirely on compliant servers within the United States.
A: We are here to help! For any additional questions or technical assistance, please contact our customer care team at 866-966-2272 or email us at support@ezlo.com.
Download on App Store App Store QR
Get it on Google Play Google Play QR
Frequently Bought Together
Ezlo Plus Smart
Home Hub
Ezlo Plus Smart
Home Hub
$ 179.95
Shop now
Ezlo Smart Z-Wave LED Bulb
$ 10.00
Shop now
Ezlo Smart Doorbell Camera
$ 179.97
Shop now
Trusted Around the World
What's New at Ezlo
