Selling fastlimited stock at this price, order today
See the difference
Ezlo Other Brands
Local Automation
Yes No
Works Offline
Yes No
Multi-Device Automations
Yes Limited
Remote Access Included
Yes* No
10 Years of Remote Access Included*
Your first EzloPi hardware purchase includes 10 years of Ezlo Cloud remote access for every EzloPi device included in that purchase — whether you buy a single device, a two-pack, or a larger multipack.
Remote access for additional EzloPi devices starts at $2.50 per month. Local control remains free on every device
Smart Wi-Fi Dimmer SwitchFrankever · Model FK-SW102-US
Dim your lights from the wall, the app or your car. No hub required
Works with Alexa, Google Home and Home Assistant
$9.95
Bundle DealsIn Stock
1 pack
$9.95
SAVE $1.95
2 packs
$17.95
SAVE $4.90
3 packs
$24.95
Mix & match Any 2 for $17.95 · any 3 for $24.95
Smart Dimmer 2
Smart Switch 1
  • Effortless Device Control
  • App-enabled voice control
  • Connectivity with other smart devices via Home Assistant and Ezlo
  • Seamless Automation with MeshBots via MiOS app
Input voltage:
AC 100-240V
Rated Frequency:
50/60Hz
Wireless standard:
WiFi 2.4G, IEEE 802.11 b/g/n
App support:
iOS and Android (MiOS, Home Assistant)
Max. Current:
10A
Incandescent Bulbs Max:
400W
Dimmable LED Max:
150W
CFL Lights Max:
150W
Operating Temperature:
14°F – 122°F (−10°C – 50°C)
Wiring:
Line, load, neutral and ground required. No-neutral installation is not supported
FCCCERoHSWEEEWi-Fi Certified
Wiring diagram
Specifications
High Voltage Device: Risk of Electric Shock — this device operates on AC 100-240V electricity. Installation requires direct interaction with your home's electrical wiring
Turn Off Power: Always switch off the main power at your circuit breaker before attempting installation
Professional Recommended: If you're not experienced with electrical wiring, we recommend hiring a licensed electrician to ensure a safe and code-compliant installation. If you are unfamiliar with electrical diagrams, line/load identification, or safety protocols, do not attempt to install this device yourself
Looking for the full installation manual? A detailed step-by-step setup guide for the Frankever Smart Dimmer is available on Ezlo Support.
Open the Installation Manual
Upgrade to the Frankever Smart Dimmer for Local Control at the Wall or in the App
Dim Your Lights at the Wall or in the App — even When the Internet Is Down. The Frankever Smart Dimmer puts EzloPi intelligence inside the dimmer for fast, private control that stays in your home
Instant response
Commands run on the dimmer itself, so your lights respond the moment you tap, swipe, or press
Private by default
Everyday control through the Ezlo app or Home Assistant stays on your home network. Only remote access uses Ezlo’s secure US-based cloud
Works through internet outages
If the internet is unavailable, the wall controls and the app on your home Wi-Fi keep working
Control the Ambiance
Control the Ambiance —
With or Without the Cloud
Use the three buttons on the wall to brighten, dim, or turn your lights on and off. At home, you can also control them through the MiOS app on your local Wi-Fi — even when the internet is down. Add Ezlo Cloud remote access to manage your lights when you’re away from home, or use a compatible voice assistant for hands-free control
From a Soft Glow to Full Brightness
Press and hold + to brighten the room or − to dim it. Use the MiOS app to remember your preferred brightness settings or create automations that set the right lighting for reading, movie night, bedtime, and more
True Local Operation
Maximum speed and privacy with zero cloud dependency
US-Based Cloud Operation
Secure remote access hosted entirely on compliant US-based servers when using MiOS. No overseas hops and no third-party relay between you and your home
Remote Control
Control your lights from anywhere, not just from your living room
Product
Automated Schedules
Custom timers and routines that execute locally, even without internet
Home Assistant Ready
Native integration available via HACS. Enjoy seamless BLE onboarding from your phone to configure your devices with absolutely no coding required
Advanced Automation
Complex local routines via seamless MiOS and EzloPi integration
Effortless Home Assistant
Take full advantage of the native EzloPi Home Assistant Integration, available directly via HACS. We've made local control easier than ever:
Zero Coding Required
Build your perfect smart home ecosystem and configure devices without any programming knowledge
Local Control
All device control is handled locally, ensuring fast response times and privacy
BLE Onboarding
Easily onboard and configure devices using your iPhone or Android device
Smart lighting that adapts to your schedule Smart lighting that adapts to your schedule
Ensure your home stays bright even on days that are gloomy and rainy. Adapting to weather conditions is possible for Frankever Smart Dimmer with built-in scripting, which allows it to turn on lights earlier when it's overcast and gradually increase brightness as the day transitions into evening
From one room to the whole floor From one room to the whole floor
Build Scenes in the MiOS app that run the lighting across an office — full brightness through the working day, lower levels in meeting rooms, everything off after hours
Smart night lighting Smart night lighting
Night Mode brings the lights down to a soft level after a set time, so a late trip through the house isn't blinding. Switch them on yourself and you still get full brightness
Frankever on the wall. EzloPi inside
The Open-Source, US-Secure Foundation for Your Smart Home
Choose ultimate control and peace of mind with EzloPi. Our Wi-Fi devices offer secure, local operation, a US-based cloud, and are built to be Home Assistant Ready, ensuring a future-proof, private, and reliable smart home experience
Frequently Asked Questions
Q: Are these compatible with Home Assistant?
A: Yes. The Frankever Wi-Fi devices are "Home Assistant Ready" through the native EzloPi integration available via HACS. Built on the open-source EzloPi platform, they integrate seamlessly for users who want advanced, local control over their smart home ecosystem. Setup is a breeze with simple BLE onboarding from your iOS or Android device—no programming knowledge required
Q: Do I need a hub to use these dimmers?
A: No. The Frankever In-Wall Switches and Dimmers are Wi-Fi enabled (2.4GHz). They connect directly to your home network without needing a separate hub or gateway
Q: Do I need a neutral wire?
A: Yes. Both the Frankever Smart Switch and Smart Dimmer require a neutral wire in the switch box. If your box has only line and load wires, which is common in homes built before the 1980s, these dimmers will not work there. Check the wiring before you buy, or ask an electrician to add a neutral
Q: Will my dimmers still work if my internet goes down?
A: Yes. These devices utilize a "Local-First" architecture. This means your automated schedules, timers, and manual controls are processed locally on the device. Even during an internet outage, your lighting control remains fully functional
Q: How is my data and privacy protected?
A: We prioritize data sovereignty. While many smart devices route data through overseas servers, Frankever devices utilize a US-Based Cloud for backups. Your data remains secure and is hosted entirely on compliant servers within the United States
Q: What if I'm not comfortable doing the wiring myself?
A: Safety is our top priority. The installation involves handling high-voltage wiring (AC 100-240V). If you are unsure about identifying line/load wires or safely installing the device, we strongly recommend hiring a licensed professional electrician to perform the installation
Q: What does the cloud cost?
A: Ezlo Cloud is included free for 10 years on your first EzloPi device with your first hardware purchase. Adding more EzloPi devices starts at $2.50 a month
Q: Who can I contact for technical support or other inquiries?
A: We are here to help! For any additional questions or technical assistance, please contact our customer care team at 866-966-2272 or email us at support@ezlo.com
Download on App Store App Store QR
Get it on Google Play Google Play QR
Add another when you need it
Ezlo Plus Smart
Home Hub
Ezlo Plus Smart
Home Hub
$ 179.95
Shop now ›
Ezlo Smart Z-Wave LED Bulb
$ 10.00
Shop now ›
Ezlo Smart Doorbell Camera
$ 179.97
Shop now ›
Trusted Around the World
What's New at Ezlo
