Effortless Device Control
App-enabled voice control
Connectivity with Multiple Radio Frequencies and Devices
Seamless Automation with MeshBots via MiOS
Frankever Smart Dimmer
Set the mood in every room
smooth WiFi dimming from your phone
High Voltage Device: Risk of Electric Shock — this device operates on AC 100-240V electricity. Installation requires direct interaction with your home's electrical wiring
Turn Off Power: Always switch off the main power at your circuit breaker before attempting installation
Professional Recommended: If you are unfamiliar with electrical diagrams, line/load identification, or safety protocols, do not attempt to install this device yourself. Please hire a licensed electrician to ensure a safe and code-compliant installation
Control Your Lights Forever: Local-First & Open-Source
Upgrade to the Frankever In-Wall Switch for lightning-fast response times and smart control that prioritizes your privacy
Local Device Speed
Processes commands directly on the device to eliminate lag. Continues working during internet outages
Open-Source Freedom
Built on the EzloPi platform, giving you transparent, customizable control
Privacy Focused
Operates locally, on your Home Assistant, or on the Ezlo US-based Cloud, ensuring your data never leaves US soil
Cloud Independent
Designed to work with any cloud, ensuring your home automation is never disabled by server downtime
Atmosphere Control,
With or Without the Cloud
The integrated, precision touch slider gives you total control over lighting intensity, effortlessly setting the perfect mood. Manage dynamic dimming from the sleek panel, remotely via the MiOS app, or through convenient voice commands, all with or without an active cloud connection
Transform room ambiance effortlessly—from warm hues for relaxation to vibrant colors for entertainment
True Local Operation
Maximum speed and privacy with zero cloud dependency
US-Based Cloud Operation
Secure remote access hosted entirely on compliant US-based servers when using MiOS
Home Assistant Ready
Native integration available via HACS. Enjoy seamless BLE onboarding from your phone to configure your devices with absolutely no coding required
Automated Schedules
Custom timers and routines that execute locally, even without internet
Remote Control
Control your lights from anywhere, not just from your living room
Advanced Automation
Complex local routines via seamless MiOS and EzloPi integration
Effortless Home Assistant
Take full advantage of the native EzloPi Home Assistant Integration, available directly via HACS. We've made local control easier than ever:
Zero Coding Required
Build your perfect smart home ecosystem and configure devices without any programming knowledge
Local Control
All device control is handled locally, ensuring fast response times and privacy
BLE Onboarding
Easily onboard and configure devices using your iPhone or Android device
Frankever Smart Switch
Smart lighting that adapts to your schedule
Ensure your home stays bright even on days that are gloomy and rainy. Adapting to weather conditions is possible for Frankever Smart Switch with built-in scripting, which allows it to turn on lights earlier when it's overcast and gradually increase brightness as the day transitions into evening
Advanced automation Ezlo MeshBots
Smart night lighting
Frankever Smart Switch can provide soft light during the night by reducing brightness after a set time in Night Mode. The full brightness stays active until the light is turned off, so it won't get in the way of late evenings or gatherings
Powered by the Open-Source EzloPi platform
The Open-Source, US-Secure Foundation for Your Smart Home
Choose ultimate control and peace of mind with EzloPi. Our Wi-Fi devices offer secure, local operation, a US-based cloud, and are built to be Home Assistant Ready, ensuring a future-proof, private, and reliable smart home experience
Frequently Asked Questions
Frequently Bought Together
Trusted Around the World
What's New at Ezlo
