10G Human Motion Sensor for Z2M /Tuya Zigbee Mmwave Radar Detector with Luminance Temperature Humidity Sensor Replace PIR Sensor
*What is the difference between (for tuya version) and (for Z2M version) ?
For tuya version: you can use it for tuya zigbee gateway ,use for tuya app or for smart life app.
For Z2M version : You can use it for zigbee2mqtt on home assistant ,not work for ZHA .
*What is the difference between (2 In 1) and (3 In 1) ?
Only motion sensor: it is only motion detection function .
2 In 1: Zigbee motion sensor with luminance detection
3 In 1: Zigbee motion sensor with luminance detection,with temperature and humidty detection .
*What is the difference between this 10g mmwave motion sensor and other pir motion sensor ?
Answer: This 10g mmwave motion sensor is built-in 10g mmwave radar ,detect the human motion. Please kindly know that it is not a presence sensor nor PIR sensor .
*How to create intelligent scene ?
Answer: If you want to create smart scene,please understand that the sensor can only work basing on the motion .
Product Name : Human Motion Sensor
Battery Type:2pcs*LR03/AAA(Not included)
Wireless Protocol: Zigbee3.0 (need to work with zigbee gateway)
MW Frequency:10.525GHz
Detection Angle:110°±10°
Detection Distance:0.5~10meter(z axis)
Luminance Meter:0~3000Lux
Temperature Resolution :0.1°C
Humidity Resolution :1%
Temperature Measurement Accuracy:±0.3°C
Humidity Measurement Accuracy:±3%
Working Voltage: DC 3.0V
Standby Current :≤80uA
Standby Time:≥8 Months
Working Temperature:-10°C~55°C
Working Humidity : max 99%RH
*Temperature and humidty parameters,products with only temperature and humidty sensor (only 3 in 1 version have this function )
