16A Wifi Smart Switch 2 Way Control, Smart Home WiFi Switch Module, DIY Light Switches Support Alexa Google Home Yandex Alice
  • Simplify your daily life by scheduling lights and appliances with the WiFi Switch Module
  • Enhance energy efficiency by controlling devices remotely or setting automation schedules
  • Perfect for smart home integration, it is a must-have for those using Mini smart switch setups
Upgrade your home with the 16A WiFi Smart Switch—a versatile solution designed to bring convenience, efficiency, and modern technology to your fingertips. This WiFi Switch Module enables seamless control over your lighting system from anywhere using your smartphone or voice commands. Whether you want to integrate smart lighting into your daily routine or simplify control over electrical devices, this compact and efficient Mini smart switch is perfect for DIY installations. Compatible with Alexa, Google Home, and Yandex Alice, it empowers you to create a smarter, energy-efficient home effortlessly.
The 16A WiFi Smart Switch offers a cutting-edge solution for smart home enthusiasts. Designed with 2-way Control Switch functionality, this device allows you to manually and remotely manage your lights or devices. Its compact size makes it a Mini smart switch, ideal for tight spaces and DIY installations.
  1. 2-Way Control Switch: Operate your devices manually or via remote control, ensuring flexibility in usage.
  2. WiFi Switch Module: Seamlessly connects to your home network, enabling remote access through apps.
  3. Voice Compatibility: Works with Alexa, Google Home, and Yandex Alice for hands-free operation.
  4. 16A Capacity: Capable of handling high-power devices, ensuring robust performance.
  5. DIY-Friendly: Easy to install, saving time and money on professional setups.
  • Simplify your daily life by scheduling lights and appliances with the WiFi Switch Module.
  • Enhance energy efficiency by controlling devices remotely or setting automation schedules.
  • Perfect for smart home integration, it is a must-have for those using Mini smart switch setups.
Why Choose This Smart Switch?
With a durable design and advanced features like remote control and voice command compatibility, this 2-Way Control Switch is a valuable addition to any smart home. Its user-friendly app interface and wide compatibility make it an excellent choice for those seeking convenience and efficiency.
Elevate your home's functionality with the 16A WiFi Smart Switch, a reliable and innovative solution for modern living.
