24G Zigbee Human Presence Detector Smart Human Body PIR Sensor Radar Detectormotion Sensors Support Home Assistant
Product name:Human presence sensor
Installation mode:Ceiling or wall
perating voltage:DC5V/1A
Operating temperature &humidity:-109C~55-C/0%6~9596 RH
llluminance value:0~ 3000 LuX
Please note:Only zigbee version can work with home assistant zigbee2mqt..
And it won't work with tuya zigbee hub.
1.Please choose the correct version.
Wifi version doesn't need zigbee hub to operate.
zigbee version need Zigbee Hub to operate.
You can choose the power by USB or By AC 80-250V.
Wall mount version have zigbee ,it is power by USB 5V1A
Ceiling mount version have wifi and zigbee,it is power by AC 80-250V
Discription:
It use 24G Millimeter Wave techonology.more accurate to detect the distance,time,and motion.
The Millimeter Wave motion sensor can be widely used in lighing,security,home appliance.hotels,garages,buildings.transportation.LOT internet of things and other industries that need to detect human micro motion,motion and control detection distance
Smart Human Presence Detector:the human presence sensor adopts millimeter wave radar,sensing human movement and static presence.It can detect the tiniest movement,even breathing and heatbeat.
Home Security :With human presence detection,you can used to detect intruders,whether it's in your personal home,an office or retail setting or even an industrial environment.
Energy Conservation:It can not only be used to detect moving,but also non-moving people.it enables seamless background features,like the kitchen light turns on once you enter the room and off once you leave.
APP Remote Control:It detect micro/macro motions enables you to detect human presence
ZigBee Hub needed:ZigBee gateway is required for this ZigBee human presence sensor,performing as the center bridge for all ZigBee smart devices with extremely stable signal and a really good necessity for whole-house intelligence.
Note:it can works with t zigbee hub,Home Assistant.
Stationary detection range:0~600 cm
Moving detection range:0~1000 cm
Detection Angle:>90°
Communication:Zigbee3.0/2.4G wi-Fi (Optional)
Product size:60*60*12 mm
Packing list
1.Human Presence Sensor X1
2. Usb cable
3.Manual X 1
4.Bracket X1
