2GIG Door Window Sensor 345 MHz
$27
  • Ezlo Secure
  • Vera Secure
The 2GIG Door Window Sensor 345 MHz is designed for use on doors, windows, and other objects that open and close. Its Wireless Door Contact sensor communicates with the control panel using the 345 MHz frequency. When the magnet (which is mounted near the sensor) moves away from or closer to the door contact’s sensor, signals are transmitted to the control panel.
The Wireless Door Window Sensor also has an external input that accepts connections from normally closed (NC) dry contact devices. For added protection, it is also equipped with a cover tamper.
Compatible with:
