A&D Wireless Upper Arm Blood Pressure Monitor with Wide Range Cuff, 8.6" to 16.5"
Regular price $68.95
Regular price $68.95 Sale price
Introducing the A&D Wireless Upper Arm Blood Pressure Monitor with Wide Range Cuff, the perfect solution for keeping track of your blood pressure from the comfort of your own home. With a wide range cuff that fits arm sizes from 8.6" to 16.5", this device ensures accurate readings every time. The wireless connectivity allows you to easily sync your readings to your smartphone or tablet via Bluetooth, allowing you to easily track your progress over time. The large, easy-to-read display makes it simple to see your readings at a glance, and the one-touch operation means you can use it with ease. With its sleek design and reliable performance, this blood pressure monitor is the perfect addition to your health and wellness routine.
Package Includes
Upper arm blood pressure monitor
Blood pressure cuff
Instruction manual
Quick start guide
Carrying case
(4) AA batteries
Manufacturer Part #: UA-651BLE-TM
UPC: 093764603327
Measurement Method: Oscillometric
Memory: Memory can be set to 0 or 30 measurements with protocol
Cuff Size: 9-14.6" / 23-37 cm
Measurement Range: Pressure: 0-299 mmHg
Systolic pressure: 60-279 mmHg
Diastolic pressure: 40-200 mmHg
Pulse: 40-180 beats / minute
Measurement Accuracy: Pressure: ±3 mmHg
Pulse: ±5%
Power Supply: 4 x 1.5V batteries (R6P, LR6 or AA) or AC adapter (TB-233)
Number of Measurements: Approx. 700 times LR6 (alkaline batteries)
Approx. 200 times R6P (manganese batteries)
Monitor Dimensions: 3.8 x 2.7 x 5.1 inches (9.6 x 6.8 x 13 cm)
Monitor Weight: 8.8 oz without batteries
Display Size: 1.4 x 2.1"
Clinical Test: ISO81060-2: 2013
Operating Conditions: +50°F to +104°F (10°C to 40°C) / 15% to 85% RH / 800 to 1060 hPa
Storage/Transport Conditions: -4°F to +140°F (-20°C to 60°C) / 10% to 95% RH / 700 to 1060 hPa
Data Outputs via Integration: Systolic, diastolic, pulse, date and time, mean arterial pressure, body movement detection,
cuff fit detection, irregular heartbeat, pulse rate rang, measurement position detection,
battery status, serial number, bluetooth address
