Aeotec aërQ Temperature & Humidity Sensor
$36.27
aërQ Temperature and Humidity Sensor
CR2477H 3V Battery
User Guide
Double-sided Tape for Magnetic Mount
The Aeotec aërQ Temperature and Humidity Sensor is an advanced and compact device meticulously engineered to monitor and report the temperature and humidity levels in your home, office, or any indoor environment. Designed for precision, this temperature and humidity sensor ensures that you have accurate data at your fingertips, allowing you to maintain the perfect climate and protect your spaces from environmental damage.
Key Features:
High-Precision Sensing:
The Aeotec aërQ is equipped with state-of-the-art sensors that deliver precise readings, even under extreme temperature or humidity conditions. This makes it an ideal solution for environments that require strict climate control, such as greenhouses, wine cellars, and server rooms.
Wireless Connectivity:
With a robust wireless range of up to 150 meters, the wireless temperature and humidity sensor can communicate seamlessly with your smart home hub or controller, allowing you to monitor conditions from afar. Whether you are in another room or another city, the aërQ keeps you informed in real-time through your smart devices.
Smart Home Integration:
This sensor is fully compatible with Z-Wave and Zigbee networks, ensuring smooth integration with a wide array of smart home systems. Automate your heating, cooling, and ventilation systems based on the sensor's readings to maintain optimal comfort and energy efficiency. The temperature and humidity controller with sensor feature allows it to trigger actions such as turning on fans or dehumidifiers when certain thresholds are met.
Long Battery Life:
Powered by a CR2477H 3V battery, the aërQ sensor is designed for longevity, providing continuous operation for extended periods. The long battery life means less frequent replacements, offering you peace of mind and hassle-free monitoring.
Discreet and Elegant Design:
The sleek, modern design of the aërQ allows it to blend seamlessly into any environment without drawing attention. Its compact size makes it easy to place in any room, and the included double-sided tape for the magnetic mount simplifies installation on walls, ceilings, or any flat surface.
Versatile Applications:
Whether you need to maintain the perfect living environment, protect valuable assets, or manage specialized conditions in commercial spaces, the Aeotec aërQ is up to the task. From ensuring your wine collection stays at the perfect humidity to preventing mold in the basement, this sensor provides reliable monitoring and control.
Usage and Importance:
The Aeotec aërQ Temperature & Humidity Sensor is an essential tool for anyone serious about maintaining a well-regulated indoor environment. It plays a critical role in preventing issues like mold growth, damage to sensitive equipment, and discomfort due to improper temperature or humidity. By integrating this sensor into your smart home system, you can automate responses to changing conditions, ensuring that your space remains comfortable, energy-efficient, and safe at all times.
Package Includes:
- aërQ Temperature and Humidity Sensor
- CR2477H 3V Battery
- User Guide
- Double-sided Tape for Magnetic Mount
The Aeotec aërQ is the perfect addition to any smart home, offering unmatched precision, easy installation, and seamless integration with your existing systems. Maintain control over your indoor environment like never before with this reliable and sophisticated temperature and humidity controller with sensor.
Product Specs:
| Manufacturer Part #: | ZWA039 |
| Z-Wave Chip: | ZGM130 |
| Z-Wave Plus Certified: | Yes |
| Z-Wave Version: | Series 700 and Gen7 |
| Z-Wave SDK: | 7.12 or later |
| Security: | S2 native |
| QR Code Inclusion: | SmartStart native |
| Repeater: | No |
| Beaming: | No |
| FLiRs: | No |
| Battery: | CR2477 3V Lithium (LiMnO2) |
| Battery Life: | With factory default setting up to 2 years |
| Wireless Range: | Indoors: 164 feet (50 m) Outdoors: 492 feet (150 m) |
| Humidity Range: | 0 to 80 percent |
| Temperature Range: | -10 to 65°C (± 1°C) / 14 to 146°F (± 1.8°F) |
| Dew Point Range: | -10 to 65°C (± 1°C) / 14 to 146°F (± 1.8°F) |
| Operating Humidity: | 10 to 95% |
| Operating Temperature: | 0°C to 45°C / 32°F to 113°F |
| Storage Temperature: | -30°C to 70°C / -20°F to 158°F |
| Dimensions: | 35 x 35 x 18 mm / 1.38 x 1.38 x 0.7 in |
| Waterproofing: | IP20 rating |
| Warranty: | 1-Year Limited |
