Aeotec Z-Wave illumino Switch
Regular price $44.99
Regular price $44.99 Sale price
The Aeotec Z-Wave illumino Switch is a smart home device that allows you to control your lights with ease. This switch is compatible with Z-Wave technology, which means it can be integrated into your existing smart home system. The illumino Switch has a sleek and modern design that will blend seamlessly into any home decor using Aeotec Z-Wave illumino Switch.
With this switch, you can turn your lights on and off, dim them, and even set schedules or scenes for different times of the day. The illumino Switch also features energy monitoring, so you can keep track of how much electricity your lights are using. This switch is easy to install and use, making it the perfect addition to any smart home. the specs of Aeotec Z-Wave illumino Switch is follow
Package Includes
Illumino Switch
Manual
Manufacturer Part #: ZWA038-A
UPC: 810667025502
Wireless Technology: Z-Wave
Z-Wave Plus: Yes
Series 700: Yes
Repeater: Yes
Beaming: Yes
Security Class: S2 auth, S2 unauth, Non-Secure
SmartStart: Yes
Input Voltage: 110/120 VAC 50/60Hz
Max Standby Power: 0.6W
Continuous Maximum Load: 960W LED, CFL, Halogen, Incandescent
1/2 HP Motor
1800W (15 A) Resistive
Power Type: Wired
Operating Temperature: 32°F to 122°F (0°C to 50°C)
Operating Humidity: 8% to 80%
Operating Distance: 35m Indoor, 150m Outdoor
Product Dimensions: 4.13 x 1.8 x 1.57 inches (105 x 46 x 40 mm)
Product Weight: 0.33 lbs (150g)
Aeotec Z-Wave Plus v2 illumino On/Off Wall Switch, Gen7
