Aeotec Z-Wave Plus Siren 6, Gen5
Regular price $99.95
Regular price $99.95 Sale price
You can use Z-Wave to make your home smarter. You can use Z-Wave to make your home more secure. And you can use Siren 6 to make your home smarter, safer, and more secure. Whether it’s remotely monitored or self-monitored, Siren 6 is the perfect indoor siren for a Z-Wave security system. In the event of an intrusion or break-in being detected by an number of Z-Wave sensors, it can sound any one of up to 15 pre-configured tones at an ear-splitting 105 decibels.
Siren 6 for security
Siren 6 for safety
Enhanced with Z-Wave, Siren 6 isn’t just a part of your home’s security system, but also a part of your home’s safety system. In the event of an emergency, or something you need to be notified of, Siren 6 can be used as an extra speaker for other connected-devices including Z-Wave smoke and leak detectors.
Brimming with features
110db speaker
Siren 6’s ear-splitting 105db speaker is your home’s first line of defence in the event of a break-in. If that’s too loud for your needs, Siren 6 can be configured to sound its alarm at anywhere between 80dB and 105db.
Visual alerts.
Should the audio alerts be unable to get your attention, Siren 6’s visual alerts will. Each siren has multiple strobe LEDs embedded into its face, capable of visually alerting you to an incident with 1,000 lumens of light.
Backup battery
Sometimes it’s the emergency that causes it, such as an intruder preparing for entry. Siren 6 includes an embedded, constantly-recharging backup-battery meaning that it can operate for up to 4 hours even when your power is out.
S2 Z-Wave Plus
It helps to keep your home safe and secure, that’s why Siren 6 is also safe and secure. Using Aeotec’s exclusive blend of Z-Wave Plus and S2, Siren 6 offers 3 different layers of wireless security to prevent hacking or interference by intruders.
Simple to install
Despite being integral to a Z-Wave security system, Siren 6 is a breeze to install. Setting up Siren 6 couldn’t be simpler. Select where you want it to be in your home, plug it into a nearby power outlet, and then sync it with your Z-Wave system.
Once setup, installing Siren 6 can be as easy as placing it on a shelf. It can also be secured and locked in place to a surface, such as a wall or ceiling, using the provided wall-mount plate and screws.
