Aeotec Z-Wave MultiSensor 7
$85.95
Motion Detection
Temperature Monitoring
Light Level Sensing
Humidity Tracking
UV Index Measurement
Take your smart home to the next level with the Aeotec MultiSensor 7, the ultimate all-in-one Z-Wave sensor. This innovative device seamlessly integrates six powerful sensors into a compact and stylish design, offering unparalleled convenience and control over your living environment.
The Aeotec Sensor Zwave Smart MultiSensor 7 is an advanced and versatile smart device that can detect changes in temperature, humidity, light, motion, and even air quality. With its Z-wave technology, it can seamlessly integrate with your smart home system to provide you with real-time updates and notifications on your smartphone. Its sleek and modern design makes it easy to install and blend in with your home decor. Whether you want to keep an eye on the temperature in your baby's room, track the humidity levels in your basement, or monitor the air quality in your living room, the Aeotec Zwave Smart MultiSensor 7 has got you covered. It's a must-have for anyone who wants to take their home automation to the next level. This aeotec multipurpose sensor is a Symphony of Sensors in One Device
- Motion Detection
- Temperature Monitoring
- Light Level Sensing
- Humidity Tracking
- UV Index Measurement
- Vibration Detection
Product Specs:
| Manufacturer Part #: | ZWA024 |
| UPC: | 810667025403 |
| Z-Wave Plus Certified: | Yes |
| Series 700: | Yes |
| S2 Security: | Yes |
| FLiRs supported: | Yes |
| Power supply: | USB DC 5V Battery power (2 x CR123A batteries, 3V, 1500mAh). Not compatible with rechargeable CR123A batteries (3.7V) |
| Maximum power consumption during a report: | 28mA |
| Voltage input: | USB power: Min Voltage = 4.5VDC Max Voltage = 5.5VDC Battery Power: Min Voltage = 2.6VDC Max voltage = 3.2VDC |
| Repeater: | Battery powered: No USB powered: Yes |
| Sensor Technical Information | |
| Measured Temperature Range: | 14°F to 122°F (-10°C to 50°C) |
| Temperature Accuracy: | ±1.8°F (±1°C) |
| Measured Humidity Range: | 20%RH to 90%RH |
| Humidity Accuracy: | ±5% RH (at 25°C/77°F) |
| Lighting: | 0 LUX to 30000 LUX |
| UV Range: | 0 to 11 UV index |
| Operating Humidity: | 8% to 80% |
| Operating Temperature: | 32°F to 104°F (0 to 40°C) |
| Max Motion Detection Range: | 33ft (10m) |
| Water Proofing: | IP20 rating |
| Battery Life: | ~3 years using 2x CR123A batteries |
| Operating Distance: | Up to 492 feet outdoors. Up to 150 metres outdoors. |
| Weight: | 65 g |
| Product Dimensions: | 45 x 45 x 35 mm |
| Back Mount Plate Dimensions: | 24 x 24 mm |
