BroadLink BestCon RM4C Pro IR and RF433/315 Smart Wi-Fi Universal Remote Control Works with Alexa Google Home, IFTTT
Comprehensive Compatibility: This Broadlink Remote is compatible with a wide range of devices, including TVs, air conditioners, and audio equipment, supporting both IR..
Voice Control Integration: Works with Alexa and Google Assistant, allowing you to control your appliances using simple voice commands for a hands-free experience
User-Friendly App Control: Manage all your devices through the intuitive BroadLink app, available for both iOS and Android, providing centralized control and customiza..
Learning Function: Equipped with a learning mode to capture and replicate signals from your existing remotes, ensuring compatibility with various devices
The BroadLink BestCon RM4C Pro is a versatile Smart Universal Remote that consolidates control over your home appliances into a single, user-friendly device. By supporting both IR and RF frequencies (433/315 MHz), it enables seamless management of TVs, air conditioners, set-top boxes, and more, directly from your smartphone.
- Comprehensive Compatibility: This Broadlink Remote is compatible with a wide range of devices, including TVs, air conditioners, and audio equipment, supporting both IR and RF frequencies for extensive control.
- Voice Control Integration: Works with Alexa and Google Assistant, allowing you to control your appliances using simple voice commands for a hands-free experience.
- User-Friendly App Control: Manage all your devices through the intuitive BroadLink app, available for both iOS and Android, providing centralized control and customization.
- Learning Function: Equipped with a learning mode to capture and replicate signals from your existing remotes, ensuring compatibility with various devices.
- Simplified Control: Replace multiple remotes with this single Broadlink WiFi remote, streamlining your home entertainment and appliance management.
- Enhanced Convenience: Utilize voice commands or the BroadLink app to control devices from anywhere, adding flexibility to your daily routines.
- Smart Home Integration: Incorporate the RM4C Pro into your smart home ecosystem, creating automated scenes and schedules for improved efficiency and comfort.
Specifications
- Communication Mode: Wi-Fi 802.11 b/g/n (2.4GHz)
- Power Supply: DC 5V ≥0.5A (Micro USB)
- Infrared Frequency: 38KHz
- Infrared Control Range: Up to 8 meters
- RF Frequency: 433MHz, 315MHz
- RF Control Range: Up to 50 meters (line-of-sight)
- Dimensions: 85 x 50 x 65 mm
Weight: 95 grams
Elevate your home automation experience with the BroadLink BestCon RM4C Pro, the ultimate Smart Universal Remote that brings convenience, efficiency, and smart control to your fingertips.
Model
RM4C Pro
Material
Infrared transmission material
Rating Power
5V DC / 1A
Infrared Direction
Multiple-direction infrared
Infrared Frequency
38kHz
Communicaiton Mode
Wi-Fi 802.11b/g/n(2.4GHz)
Supported OS
Android 4.0 / iOS 9.0 and above
Adaptor Types
No adapter in package, Compatible with all 5V USB adapters
Certification
CE
ROHS
Contains FCC ID: 2ACDZ-BL3336-P
Dimension(mm/pc)
45.7*50.1
