BroadLink FastCon SR4D Door Sensor Smart Home Security System Magnetic Anti-theft Alarm Door Window Sensor
Real-Time Monitoring: The SR4D sensor detects the open or closed status of your doors and windows, sending instant notifications to your smartphone if any unauthorized..
Smart Home Integration: Compatible with Alexa and Google Home, allowing you to check the status of your doors or windows using voice commands
.Automation Capabilities: Set up custom scenes to trigger other smart devices when the sensor detects a change, such as turning on lights when a door is opened
Low Battery Notification: The device features a changeable system with low battery notifications, ensuring continuous operation without unexpected power loss
Shop BroadLink FastCon SR4D Anti-theft Door Window Sensor
Enhance your home security with the BroadLink FastCon SR4D Door Sensor, a smart device designed to monitor your doors and windows' open or closed status. This Door Window Sensor integrates seamlessly into your smart home ecosystem, providing real-time alerts and automation capabilities.
Key Features:
- Real-Time Monitoring: The SR4D sensor detects the open or closed status of your doors and windows, sending instant notifications to your smartphone if any unauthorized access is detected.
- Smart Home Integration: Compatible with Alexa and Google Home, allowing you to check the status of your doors or windows using voice commands
- .Automation Capabilities: Set up custom scenes to trigger other smart devices when the sensor detects a change, such as turning on lights when a door is opened.
Low Battery Notification: The device features a changeable system with low battery notifications, ensuring continuous operation without unexpected power loss.
Benefits:
- Enhanced Security: Receive immediate alerts on your smartphone if a door or window is opened unexpectedly, allowing for prompt action to prevent unauthorized entry.
- Convenient Automation: Automate your home by linking the sensor to other smart devices, creating a more responsive and intuitive living environment.
Easy Installation: The sensor can be easily installed using adhesive stickers, eliminating the need for complex tools or professional assistance.
Usage:
- Installation: After pairing the sensor with the BroadLink FastCon app, use the provided adhesive stickers to mount the sensor and magnet on the door or window and its frame.
- Integration: Connect the sensor to your preferred smart home platform, such as Alexa or Google Home, to enable voice control and automation features
- Customization: Set up custom scenes and notifications within the app to tailor the sensor's behavior to your specific needs, enhancing both security and convenience.
Incorporate the BroadLink FastCon SR4D Door Sensor into your home to experience a smarter, more secure living space. Its advanced features and seamless integration, including a magnetic anti-theft alarm, make it an essential component of any modern smart home security system.
Model
SR4D (Without GW4C hub)
Battery
DC 2.7-3V (2x AAA Batteries) -Buyer procurement
Working Related Humidity
≤85% RH
Working Temperature
-10℃-45℃
