Communication Security Wire, 18AWG, 2C, Direct Burial, Shielded with Drain, 1,000 Ft.
$362.95
The Communication Security Wire, 18AWG, 2C, Direct Burial, Shielded with Drain, 1,000 Ft is the ultimate solution for ensuring secure communication between devices. Designed with 18AWG, 2C, Direct Burial, and Shielded with Drain, this wire provides high-quality protection against interference and signal loss.
The 1,000 ft. length makes it perfect for large installations and long-distance communication needs. The wire is also Direct Burial rated, making it suitable for outdoor use and harsh environments. The Shielded with Drain feature ensures that any unwanted signals or noise are grounded and drained away, ensuring clear and secure communication. With the Communication Security Wire, you can have peace of mind knowing that your communication lines are safe and secure.
Manufacturer Part # 18/2SH-DB
Marking STRUCTURED CABLE PRODUCTS ——— 18/2SHDB ——— 2 COND 18 AWG STRANDED SHIELDED LLDPE JKT OUTDOOR/DIRECT BURIAL ——— CE EU RoHS EC ZONE/DEVICE A B C D E 0 1 2 3 4 5 6 7 8 9 ***FEET
Standards NEC Article 760 & NEC Article 725; CE, EU, RoHS, EC
Construction Characteristics Conductor Material: Stranded Bare Copper
Size: 18AWG X 2C
Construction: 16/0.254 ±0.004mm
Insulation Material: PVC
Min. Thickness: 0.24mm
Avg. Thickness: 0.26mm
Diameter: 1.70 ±0.05mm
Colors: Black and Red
Shield Core Wrap: PE Tape
Drain Wire: 7/0.20 ±0.004mm
Shield: AL Foil
Filler: Waterproof
Jacket Material: LLDPE
Min. Thickness: 0.54mm
Avg. Thickness: 0.60mm
Diameter: 5.40±0.20mm
Rip Cord: Nylon
Color: Black
Electrical & Physical Characteristics Operating Temperature Range: -20°C to 70°C
Conductor Resistance (18AWG): Max 22.8 ohm/km at 20°C
Dielectric Strength: Min AC1.5KV
Rated Voltage: Max 300 Volts
Insulation (PVC) Unaged:
Tensile Strength: 13.8Mpa
Elongation: 100 percent
Insulation Aged:
Tensile Strength: 11.7Mpa (100°C 168h)
Elongation: 50 percent (100°C 168h)
Jacket Unaged:
Tensile Strength: 9.8Mpa
Jacket Aged:
Tensile Strength: 9.2Mpa (100°C 168h)
