Communication Security Wire, 18AWG, 6C, Shielded with Drain, 1,000 Ft.
Regular price $526.95
Regular price $526.95 Sale price
The Communication Security Wire 18AWG 6C, Shielded with Drain, 1,000 Ft is the perfect addition to any security system. Made with 18AWG, 6C, Shielded with Drain, and measuring 1,000 feet in length, this wire ensures that your communication lines are protected from interference and eavesdropping.
With its heavy-duty shielding, this wire guarantees that your transmissions remain private and secure. The drain wire allows for easy termination and grounding, making installation a breeze. Whether you're setting up a new security system or upgrading an existing one, the Communication Security Wire is the reliable choice for your communication needs.
Manufacturer Part # 18/6SH-GY
Marking STRUCTURED CABLE PRODUCTS – – – P/N 18/6SH – – – 6 COND 18 AWG STRANDED SHIELDED TYPE CMR/CL2R FT4 75C — (UL) OR C(UL) E198137 CE EU RoHS EC ZONE/DEVICE A B C D E 0 1 2 3 4 5 6 7 8 9 XXXXFT
Regulatory: UL 444, UL 13, NEC Article 760, NEC Article 725
Application Security Cable for Outdoor
Conductor Material Stranded Bare Copper
Size 18AWG X 6C
Construction 16/0.24mm ±0.004mm
Insulation Material PVC
Min. Thickness 0.27mm
Avg. Thickness 0.30mm
Diameter 1.70mm ±0.05mm
Colors Black, Red, White, Green, Blue, Brown
Shield Core Wrap PE Tape
Drain Wire (TC) 7/0.20 ±0.004mm
Shield AL Foil
Jacket Material PVC
Min. Thickness 0.50mm
Avg. Thickness 0.55mm
Diameter 6.50mm ±0.10mm
Rip Cord Nylon
Color Gray
Rating 75°C 300V
Conductor Resistance Max 24.4ohm/km at 20°C
Dielectric Strength Min AC1.5KV
AC Leakage Current Through Overall Jacket AC 1500V Twists Per Foot: 3.0
Cold Bend Test -20°C 4 hours; No Cracking
Insulation Unaged Tensile Strength: 13.8Mpa
Elongation: 150 percent
Aged: Tensile Strength: 11.7Mpa (100°C 168h)
Elongation: 80 percent (100°C 168h)
Jacket Unaged Tensile Strength: 13.8Mpa
Shop Communication Security Wire 18AWG 6C, Shielded with Drain, 1,000 Ft Ezlo
