Ecolink Z-Wave Plus Wireless Motorized Single Toggle Light Switch-Single
$45.95
  • Effortless Installation: The Ecolink Z-Wave switch installs over your current toggle light switch, eliminating the need to access high-voltage wires. Simply remove the..
  • Seamless Integration: Compatible with popular Z-Wave hubs such as SmartThings, Vera Ezlo, and HomeSeer, this switch ensures smooth integration into your smart home eco..
  • Preserved Manual Control: Despite its advanced capabilities, the switch maintains the manual functionality of your existing single toggle switch, allowing traditional ..
  • Extended Battery Life: Powered by two AA batteries, the switch boasts a battery life of up to one year, providing long-lasting performance without frequent replacements
The Ecolink Z-Wave Plus Wireless Motorized Single Toggle Light Switch is an innovative solution designed to seamlessly integrate smart home technology into your existing lighting system. This device allows you to automate your lighting without complex rewiring, making it an ideal choice for homeowners and renters.
  • Effortless Installation: The Ecolink Z-Wave switch installs over your current toggle light switch, eliminating the need to access high-voltage wires. Simply remove the existing wall plate, mount the device using the provided screws, insert the included AA batteries, and pair it with your Z-Wave hub.
  • Seamless Integration: Compatible with popular Z-Wave hubs such as SmartThings, Vera Ezlo, and HomeSeer, this switch ensures smooth integration into your smart home ecosystem.
  • Preserved Manual Control: Despite its advanced capabilities, the switch maintains the manual functionality of your existing single toggle switch, allowing traditional operation alongside smart control.
  • Extended Battery Life: Powered by two AA batteries, the switch boasts a battery life of up to one year, providing long-lasting performance without frequent replacements.
By upgrading to the Ecolink Z-Wave Plus Wireless Motorized Single Toggle Light Switch, you can:
  • Enhance Convenience: Control your lighting remotely through your Z-Wave hub or associated app, enabling you to turn lights on or off from anywhere.
  • Simplify Installation: Avoid the hassle of rewiring or replacing existing switches; this device installs directly over your current toggle light switch, making it renter-friendly and perfect for those seeking a straightforward smart home upgrade.
  • Maintain Aesthetics: The over-the-switch design preserves the look and feel of your traditional single toggle switch, ensuring your home's decor remains unchanged.
