Ecolink ZigBee Flood Sensor
Regular price $48.95
Regular price $48.95 Sale price
Shop Ecolink ZigBee Flood Sensor
The Ecolink ZigBee Flood Sensor is a reliable and high-quality water leak detection device designed to protect your home from potential water damage. Seamlessly integrating with your ZigBee Flood Sensor home automation system, this device offers early detection of water leaks or flooding, ensuring you receive instant alerts on your smartphone or other connected devices. Whether it's from burst pipes, leaking appliances, or heavy rainfall, the Ecolink ZigBee Flood Sensor provides around-the-clock protection to safeguard your home and valuables.
With its advanced sensing technology, this Smart Flood Sensor is engineered for maximum reliability, detecting even the smallest traces of water. Its compact design makes it easy to install in any location prone to water leaks, such as bathrooms, basements, kitchens, or laundry rooms. Once water is detected, the sensor triggers an immediate notification, enabling you to take quick action and avoid extensive damage.
This Ecolink ZigBee Flood Sensor not only helps protect your home from water-related issues but also provides peace of mind, especially when you're away. With the sensor in place, you can rest assured that your property is being monitored for water damage at all times.
Key Features:
  • ZigBee Flood Sensor: Integrates easily with your ZigBee-enabled home automation system for real-time monitoring.
  • Immediate Alerts: Sends instant notifications to your smartphone or other devices upon detecting water.
  • Smart Flood Sensor: Automatically detects and alerts you of potential leaks, floods, or moisture build-up.
  • Easy Installation: Compact and versatile design allows for easy placement in high-risk areas such as basements, under sinks, or near water heaters.
  • Reliable Protection: Built with advanced technology for fast and accurate water detection, preventing costly water damage.
Benefits:
  • Early Leak Detection: Prevent significant water damage by catching leaks early with the Ecolink ZigBee Flood Sensor.
  • Remote Monitoring: Stay informed no matter where you are with real-time notifications on your mobile device.
  • Effortless Integration: Works smoothly with ZigBee home automation platforms, allowing you to connect it with other smart home devices for added security.
  • Cost-Effective Solution: Protects your home and valuables from water damage, potentially saving you from expensive repairs and insurance claims.
Secure your home today with the Ecolink ZigBee Flood Sensor, and enjoy peace of mind knowing your property is protected from water hazards 24/7.
