The EISsound Audio Control Unit, US is an advanced audio device designed to deliver unparalleled control over your sound system. Perfect for both home theaters and high-end audio setups, this unit offers precise adjustments, ensuring that you get the best possible audio experience, no matter what you're listening to. Its sleek design and compact size make it a stylish yet unobtrusive addition to any room, blending seamlessly with your existing decor.
Features:
Precise Audio Control: The Audio Control Unit provides easy-to-use knobs and buttons for fine-tuning sound settings, allowing you to adjust volume, bass, and treble to your exact preference.
Compact and Sleek Design: The unit's modern and compact design ensures it fits seamlessly into any audio setup without taking up too much space.
Wide Compatibility: The EISsound Audio Control Unit is compatible with a wide range of audio devices, making it versatile and easy to integrate into any existing sound system.
High-Quality Sound Output: Designed with audiophiles in mind, this unit delivers crystal-clear sound, enhancing your overall audio experience.
Durable Construction: Built to last, the unit features high-quality materials and robust construction, ensuring long-term reliability and performance.
Uses:
Home Theater Systems: Enhance your movie-watching experience by finely tuning the audio to suit your environment, whether itâs for powerful action scenes or subtle dialogues.
Music Listening: Perfect for audiophiles, the EISsound Audio Control Unit allows you to adjust your sound settings to achieve the perfect balance for any genre of music.
Public Speaking and Presentations: Ideal for events, conferences, or presentations where clear and controlled audio output is crucial.
Benefits:
Enhanced Audio Experience: Achieve optimal sound quality for any activity, whether you're watching movies, listening to music, or hosting events.
Versatile Integration: The unitâs wide compatibility means it can be easily added to any existing audio setup, providing immediate benefits without the need for extensive modifications.
User-Friendly Design: With its intuitive controls, anyone can easily adjust the audio settings, making it accessible for all users, regardless of technical expertise.
Aesthetic Appeal: The sleek design not only provides functionality but also adds a touch of modern elegance to any room.
Manufacturer Part #:
9204
UPC:
8436031618440
Dimensions:
4.17 H x 1.77 W x 1.77 D inches (45 W x 106 H x 45 D mm)
Voltage:
11 to 15.5 VDC
Consumption Demand:
31 to 59 mA
Input Signal:
1.82 Vrms terminals 15, 16 mode IN BT
0.32 Vrms terminals 15, 16 mode IN OTHER (TV...)
33 Kohm terminals 15, 16 input impedance
Output Signal:
1.5W terminals 05, 06, 04 mode OUT 8 ohm
1.82W terminals 05, 06, 04 mode OUT AMP
