EISsound In-Wall Bluetooth Audio Receiver with Two 5 In. Speakers and Power Supply, White (U.S.)
$317.95
Wireless Streaming: Stream music wirelessly from any Bluetooth-enabled device with the bluetooth audio receiver
High-Quality Sound: The included two 5-inch speakers provide rich and immersive sound, making it an excellent bluetooth audio receiver with speakers
Easy Installation: Designed for easy in-wall installation, this in-wall bluetooth audio receiver eliminates the need for visible cables and wires
Aesthetic Design: The white finish blends seamlessly with any decor, enhancing the look of your home or office
Complete Package: Includes the Bluetooth audio receiver, two 5-inch speakers, and a power supply for a complete and hassle-free audio solution
Transform your living space into a concert hall with the EISsound In-Wall Bluetooth Audio Receiver with Two 5 In. Speakers and Power Supply, White (U.S.). This sleek and stylish device allows you to stream your favorite tunes wirelessly from your smartphone, tablet, or computer. The package includes two high-quality 5-inch speakers that deliver rich and immersive sound, as well as a power supply that ensures a seamless audio experience with the in-wall bluetooth audio receiver.
With its easy-to-install design, the EISsound In-Wall Bluetooth Audio Receiver is perfect for home theater systems, office spaces, and any room where you want to enjoy high-fidelity audio without the clutter of cables and wires. The white finish seamlessly blends with any decor, making this receiver a functional and aesthetic addition to your home or office.
Benefits, Characteristics and Features:
- Wireless Streaming: Stream music wirelessly from any Bluetooth-enabled device with the bluetooth audio receiver.
- High-Quality Sound: The included two 5-inch speakers provide rich and immersive sound, making it an excellent bluetooth audio receiver with speakers.
- Easy Installation: Designed for easy in-wall installation, this in-wall bluetooth audio receiver eliminates the need for visible cables and wires.
- Aesthetic Design: The white finish blends seamlessly with any decor, enhancing the look of your home or office.
- Complete Package: Includes the Bluetooth audio receiver, two 5-inch speakers, and a power supply for a complete and hassle-free audio solution.
- Seamless Integration: The in-wall bluetooth audio receiver fits perfectly into your walls, providing a clean and uncluttered look.
- Versatile Use: Ideal for home theater systems, office spaces, and any room that requires high-quality audio.
- Enhanced Audio Experience: Enjoy a rich and immersive audio experience with the high-quality 5-inch speakers.
- Convenient and Easy to Use: Stream your favorite music wirelessly from your devices with ease.
- Bluetooth Range: Up to 33 feet
- Speaker Size: Two 5-inch speakers
- Finish: White
- Power Supply: Included
- Compatibility: Bluetooth-enabled devices
Installation:
The bluetooth audio receiver with speakers is designed for quick and easy installation, fitting seamlessly into your wall for a clean look.
Sit back, relax, and let the EISsound In-Wall Bluetooth Audio Receiver fill your space with beautiful sound. Upgrade your audio experience today and enjoy high-fidelity music streaming with the convenience of Bluetooth technology.
Product Specs:
| Manufacturer Part # | 52809 |
| UPC | 8436031618662 |
| Outputs | Stereo Line, Right Speaker, Left Speaker, Amplifier Trigger |
| Speaker Impedance | 4/8/16 ohms |
| Speaker Output | 5W stereo max. |
| Speaker Color | White |
| Other Connection | Volume limitation and mono/stereo jumpers |
| LED Display | Off: Disconnected and Audio Off |
| Bluetooth | Blue Flashing – searching BT Device Blue On – BT connected |
| Audio-In | Red On – Audio-In Activated |
| Voltage Terminals VDC, GND | Normal: 15Vdc, Max: 16Vdc |
| Consumption Demand Bluetooth Operation | Minimum: 22mA, Normal: 111mA |
| Consumption Demand Jack 3.5mm | Minimum: 22mA, Normal: 99mA |
| Input Signal Jack 3.5mm | Normal: 100mVrms, Maximum: 550mVrms |
| Input Impedance Jack 3.5mm | Minimum: 7Kohms, Maximum: 60Kohms |
| Output Signal Output 4 ohm | Maximum: 5Wrms |
| Output Signal Output 8 ohm | Maximum: 2.5Wrms |
| Output Signal Output 16 ohm | Maximum: 1.5Wrms |
| Line Output Signal Terminals 65, 66, 4 | Maximum: 1.82Vrms |
| Line Output Signal Terminals 65, 66, 4 Output Impedance | Maximum: 50ohm |
| Amplifier Trigger Signal Terminals 62, 4 | Maximum: 14Vdc |
| Amplifier Trigger Signal Terminals 62, 4 Output Impedance | Maximum: 1Kohms |
| Left/Right Channel Separation | Normal: 58dB |
| Passband | Minimum: 45Hz, Maximum: 20,000Hz |
| Distortion | Normal: 0.1% |
| SNR | Normal: 84dB |
| Bluetooth Identification Number | Minimum: 0000, Maximum: 9999 |
| Bluetooth | Class2 BT2.1 + EDR A2DP 1.2 AVRCP 1.4 |
| Wireless Transceiver | 2.4GHz RF Power Transmitter: 7 dBm |
| Dimensions (Exterior) | 1.77 x 4.17 x 1.77 inches (45 x 106 x 45mm) |
| Dimensions (Cavity) | 1.77 x 1.77 x .41 inches (45 x 45 x 36mm) |
| Dimensions (Face Cover) | 1.30 x 2.60 inches (33 x 66mm) |
| Range | 33 feet (10m) |
| Warranty | 2-Year |
