EISsound KBSOUND Auxiliary Amplifier
$117.95
The EISsound KBSOUND Auxiliary Amplifier is the perfect addition to your audio setup. This amplifier allows you to connect any audio device with a 3.5mm jack, such as a smartphone or tablet, to your existing audio system. With crystal clear sound quality and easy installation, this amplifier is a must-have for any music lover. The compact design allows for easy placement, and the durable construction ensures that it will last for years to come. Upgrade your audio experience with the EISsound KBSOUND Auxiliary Amplifier.
| Manufacturer Part # | 13204 |
| UPC | 8436031617610 |
| Dimensions | 200 W x 53 H x 56 D mm |
| Voltage | 85 to 264 VAC |
| Frequency | 47 to 63 Hz |
| Consumption Demand | 10 to 60W terminals F,N |
| Input Signal | 0 to 30 Vrms |
| Output Signal |
2.5W terminals L, R (16 ohms) 5W terminals L, R (8 ohms) 10W terminals L, R (4 ohms) |
| Passband | 20 to 22000 Hz |
| Distortion | 0.3 percent |
| Crosstalk | 68 to 85 dB |
| Warranty | 2-Year |
