Ewelink Zigbee 3.0 Mini PIR Motion Movement Human Body Detector Sensor Home Burglar Alarm Sensor
Compact Design: Measuring just 35 x 39 x 28 mm, this Zigbee 3.0 Mini Sensor seamlessly integrates into any home environment without being obtrusive
Wide Detection Range: Covers up to 6 meters with a 110° viewing angle, ensuring comprehensive monitoring of designated areas
Seamless Integration: Compatible with the eWeLink app via a Zigbee Bridge, allowing for the creation of smart scenes to automate Wi-Fi devices based on detected motion
Instant Alerts: Sends immediate notifications to your smartphone upon detecting movement, functioning effectively as a Burglar Alarm Sensor
Low Battery Notification: Alerts you when the battery level drops below 10%, ensuring uninterrupted operation
Shop eWeLink Zigbee 3.0 Mini PIR Motion Sensor Burglar Alarm Sensor Human Body Detector Sensor
The eWeLink Zigbee 3.0 Mini PIR Motion Sensor is a compact and efficient device designed to enhance your home's security and automation. Utilizing advanced passive infrared (PIR) technology, it detects human movement with high accuracy, ensuring timely alerts and responses.
- Compact Design: Measuring just 35 x 39 x 28 mm, this Zigbee 3.0 Mini Sensor seamlessly integrates into any home environment without being obtrusive.
- Wide Detection Range: Covers up to 6 meters with a 110° viewing angle, ensuring comprehensive monitoring of designated areas.
- Seamless Integration: Compatible with the eWeLink app via a Zigbee Bridge, allowing for the creation of smart scenes to automate Wi-Fi devices based on detected motion.
- Instant Alerts: Sends immediate notifications to your smartphone upon detecting movement, functioning effectively as a Burglar Alarm Sensor.
- Low Battery Notification: Alerts you when the battery level drops below 10%, ensuring uninterrupted operation.
Ideal for enhancing home security, this sensor can be placed in various locations such as living rooms, hallways, or entry points. Upon detecting motion, it can trigger alarms or automate connected devices, like turning on lights when someone enters a room.
- Enhanced Security: Acts as a reliable Alarm Sensor, providing real-time alerts to potential intrusions.
- Energy Efficiency: Automates lighting and other devices, ensuring they operate only when needed, thereby conserving energy.
- Easy Installation: Comes with 3M adhesive for quick, tool-free setup, allowing you to position it wherever monitoring is required.
Incorporating the eWeLink Zigbee 3.0 Mini PIR Motion Sensor into your smart home setup offers a blend of security, convenience, and energy efficiency, making it an indispensable component for modern living.
