Ewelink Zigbee 3.0 Water Sensor Alarm Water Flood Leak Detector Remote Monitoring Overflow Security Alarm System Support ZHA Z2M
Product name : zigbee water detector / zigbee water leak sensor
Battery: CR2032 (Included)
Zigbee hub required: Ewelink hub(not included)
App: Ewelink App
Wireless: zigbee3.0
Product size :50mmx16mm
Waterproof : IP66
Working Temperature: -10°C~55°C
Standby Current:<8uA
Working voltage: 3V
Package : 1PCS
【Real-time detection】
A water immersion sensor that can detect water leakage in the environment in real time. When water immersion is detected, the detector will send an alarm signal to the host and report the information to the user's mobile phone. When the water level at the detection point reaches 0.5mm, the water intrusion sensor will report the water condition.
【Scene linkage & Smart Home Automation 】
The preset security scene is realized through the mobile APP. Once the monitored water level reaches the preset height, the alarm will be raised remotely. When the early warning water level is reached, the linkage gateway will send out a local sound and light alarm, and the mobile phone will receive the APP push reminder to let you know in time, and the mobile phone can close the water outlet by the remote electromagnetic valve.
【Long battery life】
The battery can supply power for 1 year (if the reminder is 10 times a day)
【Multi-scene application】
The water leak detector can work normally in houses, hotels, shops, offices and apartments. Protect every moment.
【Work together with other EWelink Zigbee devices】Work together with other EWelink Zigbee devices under same gateway
