Ewelink Zigbee Water Leak Sensor High Precise Water-leakage Tester Mobilephone APP Control History Tracking and Alarm Function
Regular price $15.98
Regular price $15.98 Sale price
Low stock
Shop eWeLink Water Leak Sensor – Your Ultimate Home Protection Solution
Protect your home from unexpected water damage with the eWeLink Zigbee Water Leak Sensor. This Wireless Water Sensor provides real-time monitoring and instant alerts, ensuring you detect leaks before they cause costly damage. Designed for easy integration into your smart home system, this Water Leakage Tester offers peace of mind and reliable performance.
  • Zigbee 3.0 Compatibility: Seamlessly integrates with Zigbee hubs, enabling quick response times and stable connectivity.
  • High-Precision Sensing: Detects water leaks as small as 0.5mm, ensuring fast response to potential water damage.
  • Instant Leak Detection Alarm: Get real-time push notifications via the eWeLink app, allowing you to take immediate action.
  • Wireless and Battery-Powered: No complicated wiring is needed; operates efficiently with a long-lasting battery.
  • Smart App Control: Monitor water leakage history, check battery status, and manage settings through the eWeLink mobile app.
  • Compact and Easy to Install: Place it near sinks, washing machines, water heaters, or anywhere prone to leaks.
Simply place the Wireless Water Sensor in areas vulnerable to leaks. Once moisture is detected, the Leak Detection Alarm is triggered, sending instant notifications to your smartphone via the eWeLink app. Whether it's your basement, bathroom, or kitchen, this Water Leakage Tester helps you prevent potential disasters.
  • Early Leak Detection: By identifying leaks early, you can prevent costly repairs and protect your property from water damage.
  • Seamless Integration: Compatible with various Zigbee hubs and the eWeLink app, this sensor enhances your smart home's functionality.
  • Peace of Mind: With real-time monitoring and instant alerts, you can rest assured that your home is safeguarded against water-related issues.
