Ecolink Flood & Freeze Sensor with Flood Probe
$44.95
  • Advanced Detection Technology: The Ecolink Flood & Freeze sensor uses cutting-edge technology to provide precise and timely alerts for both flooding and freezing c..
  • Compact and Versatile Design: The sensor's compact design makes it ideal for placement in high-risk areas such as under sinks, next to toilets, or in basements. Its un..
  • Real-Time Notifications: Receive instant notifications on your smartphone or other connected devices when the freeze sensor detects low temperatures or rising moisture..
  • Flood Probe for Enhanced Protection: The included flood probe extends the sensor's reach, providing additional protection in areas that are prone to water leaks or flo..
  • Early Warning System: The Ecolink Flood & Freeze sensor with flood probe provides an early warning system for potential water damage and freezing temperatures, hel..
Protect Your Home from Water Damage and Freezing Pipes: Shop Ecolink Flood & Freeze Sensor with Flood Probe
The Ecolink Flood & Freeze Sensor with Flood Probe is your flood sensor and freeze sensor all-in-one solution, offering double the protection for your home. This Flood & Freeze sensor with flood probe is designed to detect both water leaks and dangerously low temperatures, helping you prevent costly water damage and burst pipes.
Benefits & Features of Ecolink Flood & Freeze Sensors:
  • Advanced Detection Technology: The Ecolink Flood & Freeze sensor uses cutting-edge technology to provide precise and timely alerts for both flooding and freezing conditions. This ensures you are always aware of potential risks to your home.
  • Compact and Versatile Design: The sensor's compact design makes it ideal for placement in high-risk areas such as under sinks, next to toilets, or in basements. Its unobtrusive size ensures it fits seamlessly into any environment.
  • Real-Time Notifications: Receive instant notifications on your smartphone or other connected devices when the freeze sensor detects low temperatures or rising moisture levels. This allows you to take immediate action to prevent damage.
  • Flood Probe for Enhanced Protection: The included flood probe extends the sensor's reach, providing additional protection in areas that are prone to water leaks or flooding.
  • Early Warning System: The Ecolink Flood & Freeze sensor with flood probe provides an early warning system for potential water damage and freezing temperatures, helping you avoid costly repairs.
  • Easy Installation: Simple to install and configure, this sensor is user-friendly and requires minimal setup.
  • Peace of Mind: Ensure your home is protected from environmental hazards with reliable and accurate alerts from the Ecolink Flood & Freeze sensor.
