Ezlo Z-Wave Water Control Kit – 1¼
Regular price $634.95
Regular price $634.95 Sale price
Introducing the Ezlo Water Control Kit – Ezlo Water Control Kit – 1¼ Your Comprehensive Solution for Smart Home Water Management! Revolutionize your home's safety and efficiency with the Water Control Kit, a robust bundle featuring the Ezlo Plus Smart Home Hub, the Ezlo Smart Water Shut-Off Valve, and three Z-Wave leak sensors. Enhance your water management capabilities with the Ezlo Smart Water Shut-Off Valve. This Z-Wave enabled water shut-off valve seamlessly integrates with the Ezlo Plus hub, allowing you to remotely control and shut off your water supply from anywhere. Experience peace of mind knowing that you can prevent water damage by taking immediate action through the MiOS App. Strategically place these sensors in high-risk areas, and they will communicate directly with the Ezlo Plus hub through the Z-Wave protocol. Receive instant notifications on the MiOS App when a leak is detected, allowing you to respond promptly and prevent potential damage.
This bundle comes with the Ezlo Plus Smart Home Hub, Ezlo Smart Water Shut-Off Valve, 3x Ecolink Flood & Freeze sensor with flood probe and the 1¼" Ball Valve. If your home has a different pipe size, please choose the correct valve size from this catalog.
Manufacturer Part #: ESWV2-US / EzloPlus-US-SHFL / EZLS1-US / EZLO-BV-1.25
UPC: 850010801018
Description: Gen II Automated Water Shut-off Valve - Z-Wave Client / Ezlo Plus Smart Home Hub / Ezlo Flood & Freeze sensor with flood probe
Weatherproofing: IP67 Rating
Z-Wave module: Z-Wave 800 Series Chip / Z-Wave 700 Series Chip
Approvals: FCC
Ezlo Z-Wave Water Control Complete Kit: Hub, Sensors and Water Valve – 1¼
