Runs on the Z-Wave mesh network — reliable, low-power and interference-free
Ezlo Z-Wave Smart PlugModel EZL-ZW-PLUG-US
Stop paying for wasted energy
before it hits your bill
Plug-and-Play Setup — no tools or wiring required
Real-Time Energy Monitoring — track watts & kWh usage
Z-Wave 800 Series — superior range and reliability
Works with Alexa, Google Assistant & Home Assistant
Maximum Load Warning: This smart plug is designed for appliances up to 10A (1200W).
Do Not Overload: Ensure the appliance you plug in does not exceed this rating (e.g., avoid heavy-duty industrial equipment).
Over-Current Protection: The device includes built-in protection to cut power if the load becomes unsafe.
Looking for the full installation manual? A detailed step-by-step setup guide for the Ezlo Z-Wave Smart Plug is available in our Support Center.
Instant Smart Control for Any Outlet
Make your appliances smarter and your energy bills smaller with the Ezlo Z-Wave Smart Plug
Plug-and-Play
Instantly upgrade lamps, heaters, and appliances — no tools or wiring required.
Energy Monitoring
Track real-time power usage (watts & kWh) to spot inefficiencies and save money.
Superior Range
Built on the Z-Wave 800 series for the fastest, most reliable connection possible.
Switch the AC output on or off via your hub's app or Home Assistant or by using the power button on the smart plug
Energy Reporting
Supports power and energy meter reporting
Remote & Manual Control
US-Based Customer Care
Enjoy peace of mind with US-based, real-person customer support ready to assist you whenever you need help
LED Indicators
RGB LED shows Z-Wave network range and load power status
Home Assistant Ready
Works perfectly for simple use or deep-dive automations within Home Assistant and other smart home environments
Voice Activation
Compatible with Amazon Alexa and Google Assistant, allowing for hands-free control of associated devices
Smarter Control, Lower Energy Bills
The Ezlo Z-Wave Smart Plug turns any outlet into an intelligent device — instantly, without any wiring or tools.
Plug-and-Play SetupJust plug it in and go. Instantly upgrade lamps, heaters, and appliances to smart control — no electrician, no tools, no hassle
Real-Time Energy MonitoringTrack live wattage and accumulated kWh usage directly from the app. Spot energy-hungry appliances and start cutting your utility bills from day one
Superior Z-Wave 800 RangeBuilt on the latest Z-Wave 800 series technology for the fastest, most reliable connection — reaching over 328 ft outdoors and strengthening your entire Z-Wave mesh network
Your Home's Energy, At a Glance
Real-time control and monitoring, right from your phone
With the MiOS app, you can see exactly how much power any plugged-in device is drawing — live wattage, accumulated energy, voltage — all from your chair. Set automations to turn devices off on a schedule, get alerts when something's been left on, or simply switch it off remotely. The Ezlo Z-Wave Smart Plug puts your energy data where it belongs: in your hands
Frequently Asked Questions
A: Yes. Unlike our Wi-Fi line, this is a Z-Wave 800 Series device. It requires a Z-Wave compatible hub (such as a Home Assistant or other Z-Wave gateways) to function and receive commands.
A: No. This device is 100% Plug-and-Play. Simply plug it into any standard wall outlet, and then plug your lamp or appliance into the smart plug. No tools or wiring are required.
A: Yes. The plug features robust Energy Monitoring. It tracks real-time wattage and accumulated kWh usage, allowing you to identify energy-hungry appliances and lower your utility bills.
A: This plug is built with the latest Z-Wave 800 Series technology, which supports Z-Wave Long Range. It offers superior connectivity, reaching more than 328 ft outdoors and significantly improving signal strength indoors compared to older Z-Wave versions.
A: Yes. The Ezlo Z-Wave Smart Plug is "Home Assistant Ready." It utilizes standard Z-Wave Plus (S2 Security) protocols, making it easy to include in Home Assistant or other open Z-Wave environments.
A: If you need assistance with pairing or configuration, our team is here to help. Please reach out to customer care at 866-966-2272 or email us at support@ezlo.com.
Orchestrate your home with ease. With automation, you can shut off the lights from your car or control your thermostats from anywhere in the world. The only limitation is your own imagination.
Frequently Bought Together
With over 10 years of experience, Ezlo has developed a platform trusted by dealers, builders, utilities, and real estate companies across the globe. Our technology processes 1.2+ billion smart events each month, powering over 1 million connected devices—all designed to work seamlessly together.
Trusted Around the World
Ezlo's solutions are used in 60+ countries and trusted by some of the biggest global brands. Our international team works every day to deliver reliable, scalable technology that transforms how people interact with their spaces.
What's New at Ezlo
New this season: Ezlo Sense health-aware sensing, Centralite Zigbee sensors, Frankever Wi-Fi switches and dimmers, and the Ezlo Water Valve Kits
