Fibaro Swipe Gesture Controller
The Fibaro Swipe is a breakthrough smart home product. Swipe is the first gesture-control pad that allows you to control devices in your Z-Wave network or connected smart products without touching anything. It can recognize six different gestures: up, down, left, right, circle to the left, circle to the right. With these gestures, you can freely control your home: turn the lights on/off, lower/raise the blinds DIM/brighten lights, control music like Bose or Sonos, etc. Gestures can also be used to run scenes. Swipe perfectly matches any interior and resembles a picture frame. The device can be personalized with your own picture that can be replaced as often as you like. The device is equipped with an optional buzzer and visual LED indicator that confirms the performed actions happened.
For the Fibaro Swipe Vera supports the following hand gestures: swipe up, swipe down, swipe left, swipe right, clockwise and counter-clockwise. This makes the Fibaro Swipe trigger up to 6 different scenes on your Vera controller.
